How often to you get a flat tire?
Bikes: Diamondback Copperhead (hardtail, winter bike), 2014 Giant Rapid 2, 2015 Kona Big Rove ST
Primary commuter has Bontrager Race Lite hard case tires. In the beginning I got 1 flat about every 2 months @ 60-70 psi. Flats were a result of mainly glass and staples. I go through a lot of industrial areas. Installed tire liners (same tires) and haven't gotten a flat in 2 years.
LHT has ghetto tubeless Big Apples 26x2.35" @ 35 psi and there were 2 instances over the past 3 years where I rolled over something that resulted in the tire being punctured and it sealing itself.
Bikes: 2012 Trek Allant, 2016 Bianchi Volpe Disc
No flats since I started commuting last July. Do about 60-70 miles a week. I use 700x32 inflated to 70psi.
Bikes: 2011 Jamis Hudson 4600
But I will tell you what I have. 26"X2.0 65PSI Serfas Survivor series. A set of two will set you back approx $80.00. I also use some very heavy dudty tubes (can't remember the name). The Serfas ride like a dream & almost feels like the bike is driveing its self. I've had my share of suddenly having to go deep in the gutter to avoid a side swipe with an "arse-wipe" in a car that can't stay in their lane.
Its then that I'm so greatful for the presents of mind to only use high tires & tubes......cause I can hear the SNAP CRACKLE AND POP of every razor sharp stone being smashed by my tires.
So I don't want to jinx myself cause my commute in on a 15mile bike path with no lights & half of it cuts through deep woods & believe me when I tell you its PITCH BLACK with only star, moon, & the lights from your LEDs that will light the way. I don't want to tempt the hand of fate & get stuck in the dead of night with all maner of animal life moveing about.......watching me....
Dirt junkie.
Bikes: Surly Ice Cream Truck, Peacock Groove road bikem, Salsa Fargo
Liked 6 Times
I've had one flat on my 700X32 Tserv PTs in about 3500 miles, and another flat on my Maxxis cx tires in about 750 miles of use. After a string of punctures with cheap tires about ten years ago, and a horrible crash due to a flat front tire about 4 years ago during a race, I spring for the tires with a good layer of protection.
I'm running 700x28c Kenda Kwests on both of my bikes (with Mr. Tuffy's on my primary/wet weather commuter) and I haven't had a flat since the end of November, which is about 1100 miles ago (and I didn't have the Mr. Tuffy's at that stage).
i don't know how many miles, but i've been riding since 2003 and i've never had a flat tire. i even carry a pump, spare tube, and patches just in case. never needed them.
i probably will now.
Bikes: Windsor Carrera Sport, Fuji Absolute 3.0, Cannondale H400
I have a schwinn confort bike I ride at work (yes, I know it's a cheap bike. I've replaced the bottom bracket and cassettee. So far so good). I ride cheap, metro brand slicks, 1.5 inch tires to 60 lbs. 875 miles in ten months with one flat, a thorn. My ride to work bike is hybrid cannondale with Connies 32s at 70 lbs. about 1000 miles with no flats. Before I had cheap slickes, at 80 lbs. on this bike and got a flat going over a broken bottle once in 570 miles of use.
I run Michelin City 28c F, 32c R. Rear tire is good for at least 15K miles. About one flat every 8K miles (usually rear tire). I try not to hug the right shoulder when riding. Past punctures were caused by small steel wires and roof staplers.
Location: born in DC, . . . . . . . . . . . raised in MD, living in the OC. . .
Bikes: TREK 2300 carbon Frame|-&-|LEADER 735T
Quoted: 5 Post(s)
i use the forte pro+ ...from preformancebike they hold up nice, 1 flat since i got them 5 months ago, inner ture got pinched, so i bought a thorn resistant tube and no issues since.
im looking into the strada-k tire for my fixie, they are like 14$ a tire.... the pros were 20ish i think.
i would like to try gatorskins and thickslicks, but dont want to dish out the money prior to trying them...
wish someone had a pair to give forth.
flats happen, i try to avoide the stuff on the ground, but ive hit some narly rocks on my 700x23 tires, glass and pot holes and the pro+ holds up.
I guess the first rule of flats is 'You don't talk about flats.'
Pedaled too far.
Quoted: 11 Post(s)
Liked 7 Times
It varies. I've gone years without a flat and had both tires go flat within a fraction of a second of each other; the strangest was getting a flat tire at a major intersection on my way to work, and getting another flat tire at the same intersection on the way home from work the same day. I just keep a flat kit on me and don't worry about it.
"He who serves all, best serves himself" Jack London
Bikes: Trek 7.3FX, Diamondback Edgewood hybrid, KHS Montana
Quoted: 12 Post(s)
I have a weird scenario;
I have the stock Kenda Cross 700x40c tires on my bike. The are rated up to 85psi.
If I inflate to over 80psi, the tube will blow out, as long as I stay under 80 then it's the typical road hazards I have to be concerned with.
One way I reduced my number of flats was to quit riding the shoulder and get out on the roadway. In my worst week I had three flats in two days. I haven't had a flat (knocks wood) since the week of Thanksgiving since Lowering air pressure and riding in the lane ,
Bikes: Sultan 29
I switched to tubeless 9 years ago and have not had a flat since. I ride a mountain bike 4 days a week on some tough trails. Kenda Nevegal 2.35 front Small Block 8 2.1 rear.
