Simple Green Or Something Else?
Bikes: 1980's Royce Union "fixed wheel", 1995 Trek 370, 406 -wheeled " shopper/minivelo"for running errands, SS Raleigh M60
Quoted: 44 Post(s)
Liked 58 Times
Warning
Although Simple Green might be safe, I'm sure that most lubricants and greases are not, and if you dip or rinse your brushes/sponges/rags in it, your're contaminating it. Also, prolonged/repeated exposure increases the concentration of the by-products/chemicals into the soil making it unfit in the long run. Hope it's not into veggies or spices. Just my 2 cents
Quoted: 303 Post(s)
Liked 136 Times
My preferred degreaser is also simple green or equivalent. Water solubility is a factor as is lack of flammability. Undiluted it
is excellent for chains/cogs/chainwheels and after most of the crud is removed I use 50% dilution and then rinse with water.
I just use auto soap in water for the rest of the frame. Yes the removed grease is in the discard but in the larger scheme of
things is a miniscule contributor to environmental pollution compared with cars/trucks and larger machinery. Compared with
dealing with contaminated petroleum solvents, simple green is a much better choice.
Black Magic Bleche-White in a spray bottle at most automotive stores.
My preferred method: spray it on, let it sit a moment, scrub with a brush, run the chain through a chain cleaner with the Bleche-White, rinse thoroughly, blow off excess water with an electric leaf blower. Put the bike in your garage with a box fan blowing on it, spin the cranks every hour or so then leave it overnight. Get up the next morning and lube the chain.
I know people will pitch fit over this but I've been doing this for well over a decade without issues.
Two wrongs don't make a right but three lefts do! Unknown
