Got brake-checked by a driver!
I'm guessing the drivers who do this don't have the foresight to anticipate what would happen if things went wrong. It could cost them a paint job or some body work.
Capt Sensible
Bikes: Kona Sutra, Cramerroti 650C
+1 to not reacting to provocation and letting the cops deal with the homicidal loonies, but not sure what else I could've done in this case.
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
What about your paint and body? If you use a large heavy blob of steel as a threat or weapon you may have a breaker tripped.
Life Feeds On Life
Bikes: Too many Motobecanes
Quoted: 4446 Post(s)
Liked 4,553 Times
I’m lucky to have easy going country folks living where I ride gravel and paved roads. Many times when taking a break people have stopped to see if I needed anything and have been offered rides when fixing a flat tire. There is not much through traffic where I ride so most vehicles are residents so I would guess that would be a factor. Generally the people don’t care about sharing rural roads with cyclists so I haven’t encountered any road rage incidents.
Poseur Extraordinaire
Quoted: 41 Post(s)
Motorists like to complain about cyclist, but it seems to me that motorist have a lot to answer for themselves. People like to think themselves as rational beings, but I’ve witness horrible, irrational behavior from motorist more times than I can count; including outright assault. But as long as I am uninjured, I’m not going to let somebody else’s problems become my own; so do my best to just let it go.
Randomhead
Liked 3,720 Times
Just hit the car, it's satisfying. Works best if you are riding a crummy bike and they have a car with a vertical rear end.
Quoted: 659 Post(s)
Liked 7 Times
"cars can generally stop quicker than bikes if both are going the same speed."
That's not my experience. I understand that not every rider has the same reaction speed or bike handling skills. Bike-commuting on busy roads has done a lot for me, both looking out for the dumb driver maneuvers and keeping my spidey-senses keen.
Quoted: 663 Post(s)
Liked 496 Times
There are a surprising number of maladjusted and angry people in the world. the worst is that their numbers seem to be on the increase.
meh
Quoted: 1111 Post(s)
Liked 1,013 Times
This has nothing to do with reaction times. The basic physics of bicycle geometry limits your maximum deceleration based on where your center-of-gravity is relative to the contact patch of your front tire. Fat bikes may be a bit better than typical road bikes, but unless you can first move your weight back from the normal position your maximum deceleration is limited by the tendency of the rear of the bike to lift and eventually toss you over the bars. OTOH, a car's deceleration is just limited by the coefficient of friction between the tires and road.
Honestly, it's not just with fatbikes, but with larger contact patches and huge rotors you do have more stopping power. However, I can attest to having had cars aggressively stop in front of me and been able to stop quicker. Maybe the driver didn't apply 'full' braking power ... didn't get to ask.
Yes, you have to get out of the saddle and get your weight over the rear wheel, and that is the reaction-speed... how quickly you shift your weight - and bike handling to modulate the brakes to avoid the OTB. I've lifted the rear wheel off and maintained control, scary as *** but not an automatic launch over the bars.
If you really want to dive in on this subject, here's an old thread: Bike braking distance vs car braking distance
Quoted: 659 Post(s)
Liked 7 Times
A typical cars requires 45 feet to stop from 30 mph; a bike can do it in 35 ft.
But a car with decent tires should be able to stop at about 1g, good sport or race car tires can do even better. In that case, stopping from 30 mph (44f/s) should take 44/32 = 1.375 sec during which it travels 30.25' with no particular driver skill being needed.
And note that in the case you're discussing where the driver initiates a brake check there's no reaction time involved in the case of the driver, but the cyclist has to first recognize that the car is braking, then position their weight far back to avoid an endo, and finally apply the brakes to the point of almost, but not quite skidding the front wheel. Even if all that is done perfectly in zero time the bike will still lose if the car has decent tires and the driver does a hard stop.
I don't doubt your personal experience since I don't think most brake-checkers are actually aiming to create serious injury (who really wants dents and blood all over their trunk lid). So they may well have held off on their braking. But I wouldn't advise anyone to rely on that in all such situations.
meh
Liked 1,013 Times
I already participated in that thread - see post #2. It seemed to me I was in the majority and the group with the most facts and figures in supporting that, in general, the car can stop faster. Now if you have a very skilled cyclist, he has enough pre-warning to get into the right position, and the car has lousy tires, then sure the bike might stop quicker.
It is totally true that a person driving needs no skill to push the brake to the floorboard and a person on bike will need strong skills to manage max force braking. I wouldn't suggest every person on a bike can brake faster than a car... and if the car is high-performance, the car will brake faster than even the best biker.
Lastly, I agree, when encountering brake-checkers (in car and on bike), they are typically trying to make you mad... they don't want a collision. It would take a person with murderous intentions to brake-check me and cause a collision.
Quoted: 622 Post(s)
There is one time though you can't have a safe following distance, the exact situation the OP faced. When a car passes you (no difference between you being on a bike or in your own car) and cuts back in just a few feet in front of you and immediately slams on the brakes, there is zero time to back off to a safe distance prior to the sudden stop/slow.
meh
Liked 1,013 Times
I hate to say how many people in cars have given me the brake test while I'm on my bike.
It honestly makes me laugh, a bike (even a fatbike) will stop much quicker than any car and is more maneuverable. I've been know to overtake the "brake check" drivers with a smile and friendly wave. I won't let them ruin my ride/day!
It is stressful to have a driver do something stupid and hateful like a brake check. Not everybody on a bike has the ability to handle their bike the same and not all bikes are equally maneuverable. Also if the person driving that car really wants to run down a person on a bike... there's very little chance you'll avoid that murder.
In my experience*, a defensive rider with a well-maintained bike and decent bike handling skills will be able to avoid most collision (except the aforementioned murder), just like the OP avoided a wreck.
* Decades of bike-commuting, year-round, in rush hour traffic does a lot for your ability to read traffic and hone your bike-handling. Also many years driving for one of the best trained fleets in commercial driving did a lot for my defensive driving/riding.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
In general at the same speed, modern cars can stop faster than bikes can. Also factor in your reaction time; they're already braking at the beginning of your reaction time.
Work: the 8 hours that separates bike rides.
meh
Liked 1,013 Times
Let me try a different angle on this dialog: has anybody on BF rear-ended a car/truck that did a brake-test?
I openly admit, that I have no idea if I can out braked a car/truck. I have come to a very fast stop when a vehicle stops in front of me. Also, I have used braking and maneuverability to avoid collisions when a vehicle hits the brakes.
My one experience rear-ending a vehicle was purely rider error - back when I was a dumb college kid, a city bus was in front of me making a right turn, I was going straight and moving fast, I wanted to get around the bus on the left. It was a busy city road at rush hour so I was looking over my left shoulder and failed to see that the bus came to a complete stop. I clipped the bus with my right shoulder, knocked me down, happy the bike didn't hit the bus so I was able to get back up and ride the rest of the way home.
In summation, with 5,000 to 6,000 miles of riding a year in urban and suburban environments, I've been brake-tested many times and the only collision I had wasn't a brake-test and was my fault for not being a defensive rider.
Quoted: 622 Post(s)
I'm not sure if a car can stop more quickly or if a bike can stop more quickly. Not going to test it myself. But one good point was brought up. Mechanical speed is not the entirety of the factors at play. The driver of the car in front of you has already mentally planned how close in front of you he's going to cut back in and then immediately slam on the brakes. You are not going to be aware of it until after the brake lights come on. Typically most people who brake like that are only slowing down 5-10 mph quickly, so not only is the person behind having to react to brake lights on, the person also has to realize how hard the stop is. If you default to "they are always going to fully stop" then you will be slamming on your brakes too much for every quick slow down and you'll be the one smacked in the rear end at some point due to your own bad defenses.
To my shame I used to know a couple of people that were hot headed enough and drove crappy cars and would teach someone behind them a lesson by forcing a rear end collision. Cutting in far too close and slamming on the brakes hard. Assuming the couple of people I know are average for people who do that, they don't care if they get hit in the rear by a car. Why would they fear a bicycle hitting them if they are ticked off enough? No amount of defensive bicycling will avoid such an encounter if the motorist decides to teach the bicyclist a lesson in a way that might get them off the hook legally.
meh
Liked 1,013 Times
I feel so special that you read my posts and cherry-picked text that makes me look foolish... like I've ever needed anybody's help to look stupid.
Since you read the posts, I know you understand the point - there's no way to know if the person driving in front of you make a full force stop or just 80% force.
I know that I've never collided with a vehicle when the driver slams the brakes; it's happened to me a lot over the years and I've been able to stop and/or maneuver around the vehicle without a collision.
To repeat earlier posts: if the person driving wants to cause a collision, they will likely cause a collision. That kinda hateful person is thankfully rare.
Happy now?
Happy now?
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,544 Times
Bikes: '93 911 Turbo 3.6
Quoted: 109 Post(s)
Been Around Awhile
Quoted: 12 Post(s)
Liked 1,544 Times
Quoted: 150 Post(s)
pretty much every car will stop quicker than a bicyclist will, at least at the speed it matters, 20mph and up
pretty much every motorcyclist will stop quicker than a car, at pretty much any speed
but obviously if some $#&* cut into your path, youd go around em, dont try to outbrake
