Need to diagnose problem
Quoted: 1529 Post(s)
Liked 718 Times
One way to check that - jam little squares of card in the crossings.
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
Here’s an update. I followed most of your suggestions. Tightened the cleats, lubed and tightened the pedals, chainrings and other driveline components. Made sure the FD cable was out of the way. Checked the seatpost and more.
Problem is is still there. It doesn’t show until after about 10 miles but it’s still there. It’s more prominent under heavier load and relatedly up hills. The sound is between a creak and a click and is worse as the load increases like in the big ring, 13 tooth sprocket. Any more thoughts?
Does the click occur at the same point in the clock relative to the pedal positions, and if it is, does it change if you change gears ? Or is it completely random when the noise occurs?
To fully eliminate pedal/cleat possibility, you could swap in some platform pedals and see what happens.
Did you try 1-legged cycling?
I can’t imagine it’s the pedals or cleats. I used the same combination for 500 miles before this issue started.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4394 Post(s)
Liked 3,017 Times
Well, YMMV, but recently I was convinced that I had BB creaking and it turned out to be in the stem. Yeah, under heavy load you may be leaning on the bars more, and the front end becomes suspect.
When I took the bike into the LBS, the mechanic said, "everybody always thinks its the BB, but it could be anywhere."
And that's the point, it can *sound* like it's coming from the cranks or BB, but it could be anywhere.
Unless you are really good, I suggest a trip to the LBS.
Liked 718 Times
I try all sorts of stuff to reproduce the sound off the bike, then you have a chance of narrowing it down.
Likes For cecu:
You sir or madam are in my debt. If you are in SE Michigan I owe you a beer or 2. There are others with the same suggestion if I recall. Thanks to you all.
I feel foolish, dismissing these suggestions, but it finally clicked. Loose skewer, flexy rear triangle, especially under load. Duh! Just came back from a ride and the angels sang once again.
Señor Blues
Glad I could help, enjoy the quiet.
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 339 Post(s)
Liked 229 Times
In the vintage steel frame days you would've torqued the wheel into the chainstay.
I may know that from experience..... Or not..
illusiumd
3
06-20-15 07:37 PM
