Planning a city bike build
Those are nifty dropouts. But, despite their adjustability they seem to me to be very impractical for IGH use. You need to be able to slide the wheel back. You can't acheive proper chain tension unless you adjust both those dropouts everytime you remove and reinstall the wheel. Eff that noise.
I applaud your ingenuity, but you have chosen a poor frame for the duty you describe.
The X-RF5 can be spaced to 130 or 119 depending on the nuts you use (which are included with the hub).
I just bought the drum RD5. It is 130mm. Haven't got a bike set up yet.
The problem that needs to be fixed is the flat part of the SA axel attachment. He needs to file the existing DO flat on the upper contact, which is questionably workable, or get new DOs custom machined.
Good luck with your build OP.
QUESTION: I just measured my seat tube, and it looks to be 27.2-27.3mm. Is that possible/plausible? I would really like a Miche Supertype seatpost, which is 27.2, but I didn't think it would fit one of these older frames.
Wookie Jesus inspires me.
I agree that it's the wrong kind of frame for this, but I do think the build will be really cool. I like deep Vs... very rugged.
As for fenders, you can do a custom fender install by chopping the fender at the bridge and using struts to connect them. Doesn't look the best, but doesn't look bad. I think raceblades suck... They keep the stripe off your back, but they do nothing for keeping your pants dry.
Bikes: Schwinn Voyageur '89
Quoted: 10 Post(s)
I totally hate those clip-on half fenders. I used them for over two years on commuters and finally made the switch to full fenders and have never been happier (with my fender situation). River city bikes in Portland makes this neat bracket that should facilitate mounting full-fenders on racy frames. https://rivercitybicycles.com/product...ackets-737.htm
Quoted: 7352 Post(s)
Liked 2,479 Times
And there are other methods for mounting full fenders on tight bicycles. I've read about many of them in the Mechanics section of bike forums.
I used a digital caliper. I just really thought that the older Italian frames had a different dimension for the seatpost. It seems like there are unexpected gotchas all over the place when it comes to sizes for this stuff, and I'm wondering if there's some kind of catch - maybe I'm missing something.
Quoted: 443 Post(s)
Liked 27 Times
Palmer
Quoted: 1671 Post(s)
Liked 1,826 Times
Yep, Sturmey-Archer part number HMW534, "Lock Washer for Vertical Dropout".
About the XRF5(W): This new-ish (W) hub design uses a gear selector key like the older Sprint series of hubs, rather than the ball-locking selector scheme of more recent Summit series (despite what the erroneous product descriptions say on some web sites). Like the Alfine 11 IGH, the 5(W) is sensitive to cable adjustment and most have found it works more reliably with full-run cable housing and 'gentle' cable routing.
Fair enough. That's my intended usage, although it probably doesn't really fit the classical definition of the genre. Just like in the hot rod world, one person's grocery getter is a beat up old Civic, and another's is a '65 Nova with a blown 454.
Fat Guy on a Little Bike
Bikes: Two wheeled ones
Quoted: 1254 Post(s)
Liked 345 Times
The difference being that the hot rod can pick up groceries without too much inconvenience.
The better analogy is that your grocery getter is a formula one car with no trunk space.
Palmer
Liked 1,826 Times
BTW, "proper chain tension"? It's an IGH, not a fixed gear.
Senior member
Quoted: 943 Post(s)
Liked 659 Times
Not that they're any more available than the Sturmey part, probably less so, but washers from a Sram iMotion 9 will fit as well.
In a pinch, Shimano washers can be made to fit with a bit of filing.
Quite a number of modern factory bike frames use vertical dropouts with IGHs, either with sliding (adjustable) dropouts or eccentric bottom brackets. I've never heard of anyone having to readjust their sliding dropouts or eccentric bottom bracket everytime they removed and reinstalled the rear wheel.
But, yes, there is a proper chain tension even for an IGH. With those dropouts adjusted and/or a half link, the OP can hopefully acheive proper chain tension.
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
Quoted: 443 Post(s)
Liked 27 Times
Syscrush, Keep us updated on this build, I like it. I think when time and money allows a set of 1/4" steel or 3/8" aluminum horizontal dropouts can be manufactured with a little more adjustment range (perhaps including more tire and fender clearance?). It would also clean up the rear a bit without the RD hanger (which, IMHO, shouldn't be sawn off). The twist grip shifter might also give a leaner, cleaner visual.
Brad
Brad
There are lots of bikes out there running with slack chains and they're probably fine, but I wouldn't be satisfied with it.
Bikes on Flickr
Bikes on Flickr
Quoted: 443 Post(s)
Liked 27 Times
I believe that those sliding dropouts will provide for pleanty of room for adjustment. I found when i built my "magic gear" single speed that it takes very little movement to tighten the chain.
One link is 10mm, and the dropouts provide 8mm of adjustment. Adding or removing 1 link would make a ~5mm difference at the axle, so I am confident that it'll be fine.
Liked 2,479 Times
A link is 12.7mm, not 10mm!
