12-28 Cassette
Quoted: 8 Post(s)
12-28 Cassette
Hello All,
I was told that a 12-28 cassette may help me while riding. There seems like I'm missing a gear when riding the rolling hills of Ga. If I shift down, it appears to easy, however when I shift up it appears to hard of a gear. He recommended a 12-28. I have a 50-34 and sram red groupset.
Thoughts?
Thanks
Thoughts?
Thanks
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
A Shimano 12-28 has the following cogs: 12-13-14-15-16-17-19-21-23-25-28. This establishes a tight progression with less than a 12% change in cadence with any shift of the cogs. This is a very tight increment between cogs.
What cassette are you using now?
Bikes: Spooky Mulholland
Quoted: 52 Post(s)
Liked 17 Times
What are you currently running? if you are in the more todays standard 11-28 cog, the ranges are 11,12,13,14,15,17,19,21,23,25,28. A 12-28 cassette has cog ranges of 12,13,14,15,16,17,19,21,23,25,28. So You would be gaining a 16T, which I don't think you would use as much on hills. I think where you are running into issues is the jumps between 21-23-25. There is a chance you have a 11-25 which if thats the case then you may indeed what to try either a 11-28 or a 12-28
Semi-Pro Bowler
Bikes: ‘02 LeMond Tete De Course Titanium (road), ‘98 Gary Fisher Hoo Koo E Koo (mtb), ‘88 GT Mach One (BMX)
Quoted: 101 Post(s)
The benefit of an 11 or 12-28 is it will give you a better low range but the larger spread comes at a cost - larger jumps between cogs. So it might just make your problems worse.
What cassette are you running now? What gears do you find yourself between?
I live in the rolling hills of northern NJ and I’ve found 2 things help -
1) figure out which cog you wish you had and buy another cassette and mix and match cogs until you have what you want. This’ll take a couple of shots - first time I tried this I ended up with a terrible result.
2) hope this doesn’t sound elitist (very much not that kind of guy) - being between gears like that points to maybe not enough “cadence tolerance”. Keep riding and mix in some low cadence days where you grind out on a smaller cog than normal, then spend a couple days here and there spinning a larger cog at higher cadence than normal. Eventually your legs will build a tolerance to the broader range.
Low cadence needs more leg strength (fast twitch muscle fibers) and high cadence recruits more cardio... might be the solution.
Hello All,
Thoughts?
Thanks
Thoughts?
Thanks
Quoted: 8 Post(s)
running 11-28. Its a middle gear that I feel that I'm missing. Not on hills but on slight elevations.Seems like a large gap(like I'm missing a gear)
Semi-Pro Bowler
Quoted: 101 Post(s)
Are you ever desperately in need of that 28T cog? If not, perhaps you could buy the 12-25 and have even better resolution where you need it. If you stick to the exact brand and level cassette, you could always swap the 28T back in.
Like mcourse said above... you’re probably missing the 16T or possibly the 18T. So In that case, moving from 11-28 to 12-28 might just work for you.
Bikes: 1979 Raleigh Team 753
Quoted: 3377 Post(s)
Liked 372 Times
I have a 12-28 and my wife rides it. I road a 14-27 today and find that perfect as an older guy.
11-18 to 12-28 is a pretty small difference.
Liked 372 Times
Or 12-13-14-15-16-17-19*-21*-23*-25*-28*T
I think the 18-19-21 could be put on the 12-28 for a 12-13-14-15-16-17-18-19-21-25-28 which is for real purposes quite useful.
2018-2019 SHIMANO Product Information Web
I road today Recon 14,15,16,17,18,19,20,21,23,25,27 but they change.
Ultegra has
Combination 5 14-15-16-17-18-19-20-21-23-25-28T
Combination 4 12-13-14-15-16-17-18-19-21-23-25T
https://www.ritzelrechner.de/?GR=DERS...&SL=2.3&UN=KMH
Me? I would get the 11-32 to gain one more low gear from the big ring.
https://www.ritzelrechner.de/?GR=DERS...25,28&UF2=2135
Quoted: 4717 Post(s)
Liked 1,882 Times
Don't make me count. You can get DA Combination 4 - 12-13-14-15-16-17-18*-19*-21*-23*-25*T
Ultegra has
Ultegra has
Quoted: 18596 Post(s)
Liked 16,096 Times
Based on posts #8 & #9, this seems highly personal.
Semi-Pro Bowler
Quoted: 101 Post(s)
Ok, we finally some of the info we need. SRAM red 11-28 has 11,12,13,14,15,16,17,19,22,25,28. So it must be the 18 or possibly the 20/21 your legs are wishing for.
as mentioned above, shimano’s 6800 ultegra 14/28 solves this issue as it has a straight block from 14-21 and plus a 23 and maintains the 28 granny cog.
This comes at the expense of top end speed, missing the 11-13 cogs, but really this will only come into play descending under power.
Edit: Honestly, eliminating the 11-13 is a really drastic change. Perhaps drop the 28 and go with the ultegra 12-25, which has 12, 13, 14, 15, 16, 17, 18, 19, 21, 23, 25
Bikes: Synapse, Slate
Quoted: 56 Post(s)
Liked 12 Times
Or buy a 105 (or Ultegra) 12-25 and 11-28 and make your own 12-28. Then you can use the leftovers on a trainer wheel. Would still probably come out cheaper than getting a DA 12-28
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 649 Post(s)
Liked 139 Times
12-28 is the perfect cassette IMO. At least for my riding style and terrain (and fitness). For every 1 time I may wish I had an 11t, there's 5 or 6 times I'm glad to have the 16t. Every other cog is the same on these two cassettes. If it's right in that perfect zone of 15-19 where you feel you are missing a gear, then yeah, the 16t will make a difference. If it's above the 17t, it's the same cassette, so anything above that will be the exact same, and you will feel no difference.
