Sekai Bicycle Database
#402
Sekai 4000 Serial number
I have a Sekai 4000 Professional which I purchased new as a frameset in 1983. The serial # is M8M 22913. It was black when new, has Shimano SF vertical dropouts, Champion #2 Tubing, Heart cutout lugs, brake bridge diamond reinforcements and a full wraparound seat stay attachment. It had the green Champion tubing sticker. Is this a 1978 Miki produced frame?
#403
Quoted: 4722 Post(s)
Liked 3,038 Times
Retrofaction, the odds of it not being Miki are negligible, given that Miki was a known manufactrer of these frames and the serial number format is consistent with Miki. Unless you made a mistake on the serial number it was manufactured in 1978.
#404
Bikes: 1981 Sekai 2500 Grandtour
Picked up a new to me Sekai 2500 Grandtour today! It's pretty crusty, paint is in the worst shape. I road a lower model Sekai throughout college that I saved from a dumpster so excited to fix this one up.
Serial Number is YOL8103.
Says it's Tange Peerless, which I've never heard of.
#405
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
The ones I have seen were high ten steel with veey nice components. Seat post OD will tell more, TMar probably knows it regardless
#406
I'm a noob and don't know what Seat post OD means, lol. It has stem Shimano shifters, a rear rack, SunTour VX front and rear derailleurs, Dia-Compe brakes and levers, and a super maxy crank with a 52/40.
#407
Liked 3,038 Times
Tange Peerless is new to me, too. The serial number indicates it was manufactured in 1980 by Yamaguchi, though it should be a 1981 model. I don't believe there are any in the database from the very early 1980s. The very late 1970s versions used Tange #101, while circa 1983 they were Tange #2 . Consequently, I'm also interested in the clue from the seat post outer diameter, which is typically stamped somewhere below the insertion mark, format 26.x, where x is an even number.
#408
Thanks T-Mar, I found it! The seat post says Max.HT 26.2 and then L-80. The Peerless stamp says high tensile double butted.
#409
Liked 3,038 Times
#411
Bikes: Tommasini Super Prestige, Bottecchia unknown model in MiniMax tubing, Sekai 4000 (tbc), Beraudo
T-Mar any further thoughts on whether this Miki built frame is a Sekai?
#412
Folks: I am a newbie on this forum. After storing my late brother-in-law's Sekai I am getting it cleaned up to ride and trying to understand what I have. Serial Y0L9353 with a made in Japan sticker. As best I can translate the serial number from this thread it is somewhere in the 1980-85 range. Can anyone help me understand more clearly how to decipher the serial number code?
#413
Liked 3,038 Times
#415
I am in middle of cleaning up my Sekai GT2700 and I believe the seatpost tube diameter that came with is not the right size.
Does anyone know what is the right size of the seatpost?
#416
Quoted: 12 Post(s)
Hi. may you help me identify my friend's serial number frame
1. located on a straight bottom bracket and there are 2 ellipse holes Y5M85031285 / YSM85031285
and is on the top right head tube E5 E5
and head tube left top down 73 61
then there is a hole holder for the road bike shifters left and right on the frame
example of the shape of a bottom bracket hole
2.there is a straight bottom bracket M23751
there are 3 small round holes forming a triangle. and there are also serials in the drop-out chainstay but I don't know. then the road bike shift holder left and right are bolt pivots
its all have doible bidon
Is this one of the sekai or the other
Please help. Thanks
Please help. Thanks
#418
18 speed
Colour: Dark Red
Frame: 21”.
Front & Rear Derailleur: Suntour Mountech
DT Shifters: Suntour
Crankset: Sugino GT
Chainrings x 3
Pedals: MKS GR8 (Japan)
Hubs: Suzue
Rims: 27” No identifying labels but assumed to be original
Brakes: Dia Compe
Serial No. 365450
Made in Japan sticker
Interestingly the serial number is very close to dougb’s 2500 in post #285. Identical colour & decals so may be part of same batch.
18 speed
Colour: Dark Red
Frame: 21”.
Crankset: Sugino GT
Chainrings x 3
Hubs: Suzue
Brakes: Dia Compe
Serial No. 365450
#419
Liked 3,038 Times
18 speed
Colour: Dark Red
Frame: 21”.
Crankset: Sugino GT
Chainrings x 3
Hubs: Suzue
Brakes: Dia Compe
Serial No. 365450
18 speed
Colour: Dark Red
Frame: 21”.
Crankset: Sugino GT
Chainrings x 3
Hubs: Suzue
Brakes: Dia Compe
Serial No. 365450
#421
1977 2500 Grandtour 64cm
Figured I'd post this before I sell it.
Picked up this one and another Sekai off craigslist back in the day. Sold the other one right away for more than I paid for the pair but kept this one.
Figured I'd post it before it dissapears
This Sekai 2500 Grandtour 64cm with 27in tires. Chrome moly, double butt, hi-tensile construction, Raleigh handlebars, SunTour Cyclone gearing, brakes,etc.
Sekai Grandtour 2500
64cm (25.25")
58.5cm top tube
27 in wheels
27 x 1 3/8 Kenda tires
Suntour AR LI derailer
Suntour Cyclone front derailer
Suntour Power shifters
Moxy cranks
Sekai seat (not so great condition)
Raleigh headset
Raleigh handlebars
Dia-Compe break levers
Dia-Compe front and rear brakes
Serial# 77G90258
I cant post photos as I dont have 10 points I guess.
64cm (25.25")
58.5cm top tube
27 in wheels
Moxy cranks
Raleigh headset
Raleigh handlebars
Serial# 77G90258
#422
Bikes: 1974 Sekai 2000 Special
Quoted: 11 Post(s)
Hi All - I'm new to this forum and thread. I recently found what I hope was a solid pick up off craigslist - a Sekai of some type for $60. This is my first rebuild and I'm hoping to get some help from this thread. I can't identify exactly the make and year based on the info earlier posted - but I've taken the bike apart and hope the info I'm sharing will be enough for someone to help me. I've also started to collect parts to clean up/tune up the bike. New brake wires, new chain, new bar tape. I'd like to consider converting the Barcon shifters to downtube or stem...is that dumb? I'm just going to use this bike to cruise around my city, nothing crazy, no real long rides. Any and all help/advice is welcome! I want to post picture but i don't have 10 posts yet...
Frame Sekai 2000 Special? Not sure!
Serial # K8H03368
Handlebars Sakae Custom
Shifters Suntour Ratcheting Powerthumb Barcon Shifters
Front Deraileur Suntour Compe V
Rear Deraileur Shimano Crane GS DR-102
Cassette Maeda (suntour) Perfect 8.8.8 PF 5 speed.
Crankset/Arm Sugino Maxy 165 Arm 52
Brakes Silver Dia-Compe 610
Brake levers Weinmann Red Dot Type 500
Bearings Suzue SATN 0.5
Rims Ukai 27"x1.25" W/O LA
Pedals Lyotard 136R
Saddle Selle Italia Touring
Frame Pump Primus
#423
Liked 3,038 Times
Frame Sekai 2500 Special? Not sure!
Serial # K8H03368
Pedals Lyotard 136R
Frame Pump Primus
Serial # K8H03368
Pedals Lyotard 136R
Frame Pump Primus
#424
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
Models list updated
Known year to serials list updated
Links added for Don Gillies photo collection as well as catalog scans added to thread
Added info blurb from T-mar to initial post
#425
Sekai serial # Help
I've recently purchased serial number K9AU3795 . I'm thinking USA market 1979 ? The bike is silver with a Sugino Mighty Competition 2 chainwheel crankset. The rear is a five speed. It has aluminum 27 x 1 1/4 ARAYA wheels. A sticker on the seat tube saysG3445 seamless hi tensil steel throughout. It has Suntour bar end shifters and Suntour Cyclone deraillers front and rear. Suzue hubs. Maeda Industries Perfect freewheel?Also the front fork has a sticker that says SKV. The model sticker is gone so I'm not sure what I have here. Any help would be appreciated. Thanks
