[Dahon/Tern] Brompton-like baggage block?
#176
Now, If and only if brompton can also have a QR system rear rack ...
H&H with Klickfix GTA QR platform
No hand still balance. Must be over 20Kg
Klickfix GTA system
#177
Quoted: 575 Post(s)
Liked 119 Times
10kg in the front already helps for the groceries.
In the back, a rack/trunk bag is a lighter alternative:
- Ortlieb Trunk-Bag RC, Bike Basket
- Agu Yamaska Rack Pack 475
#179
Quoted: 575 Post(s)
Liked 119 Times
It works fine even with a $50 aluminium rack, though ;-)
https://www.aliexpress.com/item/Alum...843884992.html
#181
Quoted: 575 Post(s)
Liked 119 Times
I might get a second-hand Strida, and was wondering if the Brompton luggage block could be doctored to fit on that frame :
For those who have engineering experience, do you think drilling a couple of holes to hold the block in place with hose clamps + a piece of inner tube might do the trick?
Thank you.
Thank you.
#182
Maybe not just a hole, Im thinking too thin .. but instead set some riv-nuts
at least no fork steering tube behind it , which is why Brompton brazes on a piece of steel to the outside of the head tube .. screw does not touch the fork turning within the head tube..
I'm guessing i don't own one of those, but it looks like steering is the hinge behind it's steering column.
is that just a hollow pipe?
#183
Originally Posted by Winfried
For those who have engineering experience, do you think drilling a couple of holes...
And also you hopefully did not overlook that you're putting weight on the steering - and not on the main frame.
#184
Quoted: 575 Post(s)
Liked 119 Times
The drilling would occur in the Brompton luggage block, and thus, would not affect the frame.
The sterring might be slightly affected while the overall stability might be improved by adding weight on the front wheel (wheelies when riding uphill).
#185
Stardust
Thank you.
Thank you.
you south parts suffer!
#186
And a bit later you published at Stridaforum the question
Drilling through headtube to add Brompton luggage block?
- how does that match, are you just kidding or what?
Once again:
Do not attempt to drill ANY additional hole into the Strida frame tubes!
I advice that after over eight years of intensively studying Strida technics - jfyi.
You have been warned.
#187
Quoted: 575 Post(s)
Liked 119 Times
Because generally speaking, I like to check all my options before making a decision. Is this wrong?
#ChillOut
As for putting weight on the steering: This is exactly what the Klickfix adapter does… as well as front panniers. Why would that be terrible on the Strida?
#ChillOut
#188
Stardust
#ChillOut
#ChillOut
the frame is so stiff that the private parts does suffers a lot in potholes...
#189
Quoted: 575 Post(s)
Liked 119 Times
I have a simple solution that I've used for a few years now with my Brompton: I ride around potholes.
Low tech is good tech®
#190
or I failed to point out the difference here between Brompton and Strida - therefore I give it another try in different words.
You really want to put weight on the moving parts of the steering?
I mean that is a bad idea always - totally independent of the brand.
That is what clickfix does, correct - but that must not mean it is in fact convenient to ride.
And this is NOT what the Brompton block does, as the block is connected to the frame it won't affect the steering behaviour.
On a Strida there is no front frame (part) existent - all we have is the (moving) front tube.
Therefore it is impossible to mimic the technical function of a Brompton block on a Strida bike.
You can glue it, screw it, weld it, whatever - it will not work like that on a Brompton.
Btw, you wrote earlier in this thread
Rixen and Kaul/Klickfix doesn't provide a way to contact them:
Rixen & Kaul, KLICKfix Adaptersysteme Fahrradzubehör, Solingen, Taschen, Körbe, Werkzeug
False - for bikes newer/including Strida 5.
(At least in Canada, Europe and Korea are all parts available.)
Please blame your local distributor for parts suffer (or perhaps yourself for being too lazy to search the www?)
- but not the manufacturer/brand!
Thanks.
Hey my friend, my suggestion is to try strida before you buy.
Your price - you won the Strida distributorship for Brasil...I believe...
#191
Quoted: 575 Post(s)
Liked 119 Times
2. Besides Klickfix, touring bikes often have front panniers, which both affect steering.
In practise, would it be so terrible to carry a few kgs at the lower end of the head tube on the Strida? Have you tried it?
Edit: I don't have a single-speed Strida handy to check, but at least on the EVO, adding a Brompton block or Klickfix adapter doesn't look like a good idea, as it'd have to be quite high up the steering tube anyway, which would make it even more uncomfortable. And considering the size of the rear rack, it looks like riding a Strida EVO = backpack.
#192
Quoted: 27 Post(s)
Well that's a huge bummer... I worked really hard on developing this adapter and bikegang just swoops onto eBay with a copycat product and undercuts my price? Nice. It's not like I'm making any significant income on this, just a jerk move. But I guess that's the world we live in...
For the record, I explored the angled interface and found that tilting the bag forward put the bag out in the wind too much, and even with my handlebars all the way down braking/shifting performance remain unaffected with it straight. What do you guys think? Am I wrong?
#193
Here is another commercially available one newly out, made by a bag maker who wants to fit the bags between bikes. Prettier than hand milled but probably too expensive to sell by itself.
#195
#196
Stardust
The adapt we made for brompton block to work on dahon frames are strong and solid.
realy make the bike more usefull and are way better than blickflix alternatives
#197
Quoted: 575 Post(s)
Liked 119 Times
#198
Stardust
#199
Quoted: 575 Post(s)
Liked 119 Times
Unless it's further back in the thread, you posted pics but no link.
Googling for "BromptonINrio instructables" returned nothing.
Also, is a 3D-printed design solid? I wouldn't want to have it break on me while travelling.
#200
Stardust
Also, is a 3D-pinted design solid? I wouldn't want to have it break on me while travelling.
to use brompton block on dahon lugs i tryed 2 methods and bolth has proven solid:
first is to use a regular brompton front carrier blocks and enlarge the holes to fit dahon bolt spacing.
after, you need to fill down about 7mm of dahon lug welded in bike.
in the end the two bolts need to go in the proper angle and the carrier block need to fully embrace the dahon lug.
second is to buy and adapter:
Here you can find many in all materials https://www.shapeways.com/product/QLHYDKUBE/brompton-carrier-adapter-for-tern-or-dahon-folders
The last subject is that if you can print either your carrier block or your adapter block...and you can pri t bolth.
