LOOK 753, from frame prep to fnished build. An evolving pictorial.
Quoted: 7352 Post(s)
Liked 2,479 Times
If the derailleur doesn't hold long-term, I suggest a shim made out of metal.
Yes I did see the TDF with the MASSIVE crash at the end. Does anyone know of any live streaming for the tour? At work they have a projector for whimpy world cup cry baby because he touched, "pushed" me but not the I am going faster than a car and a dog made me fall and road rash my entire right-side of the body and I think I have a broken collar bone but I'm going to keep riding and stay competitive. [/vent]
Mostly Mischief
Worked on the chainline. As it turned out just mounting the crank and checking the measurements was all that was required.
From a point halfway between the rings to the center line of the frame is about 43mm.
The rear spacing is 130mm (with the hub spreading the original 126'ish mm). So from the center line of the hub to the inside face of the drop is 130 divided by 2 = 65mm. From the same hub center line to the idealized chainline we measured 43mm at the crank.
65 minus 43 = 22mm, which should be the distance from the inside face of the right drop to the middle of the cluster.
Now all I need is to go find a 10 speed chain.... anybody know if I can keep using my old chain breaker on these narrow ones?
Señor Member
Quoted: 1492 Post(s)
Liked 1,096 Times
You're cold setting a 753 frame? Danger Will Robinson!! I've seen people with unimpeachable credentials as builders saying it's sure to result in catastrophe.
Mostly Mischief
For some reason I think I will loose less sleep over such a bold and daring act, than even considering riding a carbon fork.
Anyway, the rear on this bike is more like 127mm, and although having not measured the hub over the lock nuts, I can say that inserting the rear wheel is completely effortless.
Quoted: 835 Post(s)
Liked 2,138 Times
Now that is ingenuity. I'd be worried about the FD slipping, but if it holds then more power to you! Just a thought: Maybe fill the gap above the PVC with wax to keep the gunk out. Btw, I think it's comical that I needed some spacers to get the Avocet on my LOOK and settled on a piece of irrigation tubing, and you resorted to PVC for spacing your FD. Who knew the plumbing isle had so much to offer the bicycle mechanic.
-Randy
'72 Cilo Pacer • '72 Peugeot PX10 • '73 Speedwell Ti • '74 Nishiki Competition • '74 Peugeot UE-8 • '86 Look Equipe 753 • '86 Look KG86 • '89 Parkpre Team Road • '90 Parkpre Team MTB • '90 Merlin Ti
Avatar photo courtesy of jeffveloart.com, contact: contact: jeffnil8 (at) gmail.com.
-Randy
Mostly Mischief
Gaucho, did I mention that your story was pivotal in my sudden urge to try one of these frames?
Señor Member
Liked 1,096 Times
I use my chain breaker on 9 speed chains. Never had the opportunity to use a 10-speed chain.
My Bianchi project is awaiting SRAM shifters but the current dt frictions shift 9/10 cogs buuut that's a longer story. LBS jammed the last cog on and torqued the lock ring so I'm going into the shop AGAIN . They've been very good so far .
Señor Member
Liked 1,096 Times
Jan, as you didn't have to wrestle with the frame to fit the wheel in, I'm pretty sure you'll be fine. Attempting to force 753 is not a good idea. If you have any doubts, ask Hilary, or John Thompson about the dangers. I'd sure not wish to read about any further mishaps involving you.
Dolce far niente
Quoted: 20 Post(s)
Liked 17 Times
Mine looks like this:
"Love is not the dying moan of a distant violin, it’s the triumphant twang of a bedspring."
S. J. Perelman
S. J. Perelman
Liked 10 Times
Jan, if you are using a Campagnolo chain, it is not advised to re-use a pin. You are better off using a Campy specific 10 speed quick link.
I have used my old park CT-3 chain breaker to shorten the chain to proper length, but have since bought the new CT-4.2 chain tool.
https://www.parktool.com/products/det...=5&item=CT-4.2
I know you don't have an aversion to picking up a new tool now and again.
Quoted: 835 Post(s)
Liked 2,138 Times
-Randy
-Randy
Granted, I have limited Campy 10s chain experience...but...my Veloce 10s chain is running well after sizing it with a standard Park tool and joining it with an SRAM Powerlock.
FWIW...
FWIW...
Liked 10 Times
I used to just size it right the first time and use the supplied extra pin, now I use one of the compatible removeable links, and carry an extra one in my seat bag as well. I use a Campy chain, and a KMC Missing Link, 2 for $10: https://www.probikekit.com/display.php?code=A0309
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Don't try it at home unless you have a disposable 753 frameset and some time to waste.
Mostly Mischief
Okay, all you 753 owners: Don't cold set your rear spacing!!
This I take to mean OVER-bending, with or without the help of levers, bars, muscle etc, until the frame springs back only as far as the new wider drop out spacing, and stays there.
Very different from the permanent adjustment procedure of cold setting is the benign act of simply inserting a rear hub 3-4mm too wide. I would be very surprised if this can cause any adverse effects on the La Vie Claire LOOK frame in question, given the moderate amount of force needed. In fact the rear wheel slipped in so easily that I had completely forgotten about spacing issues until I read the posts above.
Actually, I wonder how many of us really bother cold setting when 'upgrading' a 126mm frame, of any type of steel, to modern drive trains.
Señor Member
Liked 1,096 Times
Sorry to have sidetracked the thread a bit, but I feel better knowing you're not the next Dr. Strangelove, riding a bomb to your doom.
Bikes: Ruckelshaus Randonneur, Specialized Allez (early 90's, steel), Ruckelshaus Path Bomber currently being built
Actually, that was Major "King" Kong, played by Slim Pickens.
Hey, just found this thread, this is a lovely build, gonna be awesome when its finished.
Subscribed !!!
Sorry to hear about your injury, get well soon
Subscribed !!!
Quoted: 34 Post(s)
Liked 22 Times
[Actually, I wonder how many of us really bother cold setting when 'upgrading' a 126mm frame, of any type of steel, to modern drive trains.[/QUOTE]
I've got an old magazine where Shimano said they designed the first 130mm 8 speed Dura Ace hub to be forced into 126mm spaced frames. Remember, when Shimano first came out with 8 speed nobody was making 130mm frames.
Bikes: 1973 concord fixie conversion, 2001 canondale
Man I'm now in love with these look frames. Im now officially on the lookout for 1. I can't wait to see how this build turns out. I love the paint jobs that were put on them. Reminds me a lot of mondrians art.
Super Course fan
Location: Lost on the windswept plains of the Great Black Swamp
Liked 8 Times
Beautiful bike Jan,
I've cold set a few frames using one of my Jorgensen clamps, I won't recommend that anyone in their right mind do it though.
But I've also bent a 20-30 raleigh back into shape by clamping the chainstay and dropout to my woodworking bench and leaning on the frame. With wooden faces in the vices of course. Definitely not something I'd try with a frame made of R531or better!
I have a white PX-10, a Green Dawes Galaxy and an Orange Falcon, now I'm done.
