18650 Batteries for bicycle lights
I remember charging them fully before storing them, but i think they were stored for a few months without use. These battery specs indicate that they hold 90% charge for 5 years but i suppose they don't if they are stored in a case, even if the cable is detached from the light itself.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
I think they would be about 4 years old or so. The light was used only a handful of times with these batteries and it worked great but i think the manufacturer recommends using protected batteries with this light, however the ones i have are unprotected.
Quoted: 840 Post(s)
Liked 336 Times
I only use unprotected ones. Those with protection will often fail to fit into spaces, so are in practice less versatile. The typical protection acts as a fuse against high current. Sometimes there may be high temperature or high pressure protection, nothing that you expect for slow discharge.
Likes For 2_i:
Quoted: 840 Post(s)
Liked 336 Times
I managed to bring back NiMH batteries from the dead successfully, using a combination of chargers and the 'Refresh' mode in the intelligent ones. However, when I did it with lithium, they usually went dead again soon.
Quoted: 840 Post(s)
Liked 336 Times
I have 2 Panasonic cells that were left in the battery case for a few months without use and they don't take charge anymore. I don't know much about batteries except for higher mah lasts longer, but wonder if these cells would've still worked if they had protected circuit.
Just another thought. I had a watch type Sony lithium battery die several days after putting it into a device. Sure the batteries were lying around for several years, but something like this never happened to me before. I did some digging around and realized that I was conned those few years and sold counterfeit Sony batteries. I look around my stock and found still another tear strip package with another type of fake coin Sony batteries. Interestingly when I used those batteries shortly after their purchase their counterfeit nature was not apparent, just their premature death provided a cue. Anyway, I am normally very careful when buying batteries, but was obviously not careful enough.
Quoted: 166 Post(s)
Liked 252 Times
NIMH are pretty inscrutable really.. We used to almost catch them on fire over charging them when racing RC's, then we would totally discharge and dead short packs for storage. I only saw a couple of them explode from abuse and other than sounding like a shotgun going off it was way less scary than LIPo fires. lol.
Bottom line is, if you are going to be responsible and closely monitor your li-ion cells, perhaps unprotected is the way to go. If not, you might be safer going with protected cells.
Also regarding Li-Ion protection circuits: Many li-ion battery packs, like the ones used for power tools or laptops, use unprotected cells, but wire into the packs protection circuits which momitor each individual cell. If any individual cell drops below a pre-determined voltage, the protective circuit disables the complete battery pack, rendering it un-usable. This is done to prevent battery fires due to the thermal runaway condition I mentioned above. Certain brave (and hopefully knowledgeable) individuals have used this knowledge to harvest working 18650's from dead battery packs. This is not something the average person should do, however. I'm not 100% on this, but I think that the protective circuitry on protected 18650s may also provide this functionality. Should the cell ever fall below the preset voltage, it may disable it to prevent usage. I have many flashlights that run on 18650, 18350, 14500 and other li-ion batteries. Some are protected, some are not, depending on the application. I personally rely on the braintrust at Budget Light Forums. There you will find a lot of people who are far more well-informed that I am who are very friendly and willing to share what they know. If you are looking for sources for batteries, chargers, flashlights, they are a great source. You will also find gear (flashlight, chargers, battery, etc...) reviews and just all around great people. There are even members who have designed and produced (in collaboration with major manufacturer) their own flash lights. I own several of their BLF branded lights and the ones I own are simply incredible.
Quoted: 2497 Post(s)
Liked 741 Times
Why oh why do people who know jack about a given subject spend money BEFORE they start a thread? Surely the answer for the o.p. was just to purchase a built up battery PACK from a reputable source. Unless you don't need to ask. Homemade batteries can KILL you.
