Higher end gravel bikes- e.g., Warbird and...what else?
#77
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4394 Post(s)
Liked 3,017 Times
I've ridden the bike a fair bit on pavement, and I like it a lot. Of course, the April gravel events are all cancelled. And to make a long story short, the current circumstances make it difficult for me to access gravel on my own a the moment. So, provisionally, the bike is great, but I haven't been able to use it for its original purpose.
Adjusting to the subcompact chain rings (48/36) is a little strange when riding on mostly flat paved roads, I'll appreciate that setup more on gravel and hills.
#78
Bikes: Obed Baseline, Cannondale Topstone, Specialized Roubaix, Cannondale Synapse
Quoted: 37 Post(s)
Liked 12 Times
Well, the situation is not what I thought it would be....
A couple of questions: You have 48/36 chain rings? I thought the bike came with a 46/30? And are you using the stock tires -- Taravail Cannonball 42mm according to the Salsa website? Any thoughts on those?
Thanks. And good luck with everything.
Better fred than dead
#79
Quoted: 3242 Post(s)
Liked 2,090 Times
I budgeted for and purchased a 2nd set of wheels specifically to keep a road setup. I swap from a wheels set that has the 11-34 cassette and 37 (or 45) gravel tires, to the "road" wheelset, with a 12-25 cassette and 28mm road tires - that ended up as 31mm when used on a wide 23mm rim. As this road setup is also my fast commute setup, it works great.
#80
Liked 3,017 Times
Thanks for the update. When things loosen up, and I presume they will eventually, I hope you get out for a bunch of nice gravel rides.
So far I'm using the stock tires. The bike rolls surprisingly well with on them on pavement. I don't plan to make any changes until I get some experience on actual gravel.
#81
Quoted: 37 Post(s)
Liked 12 Times
Thanks.
