**Report issues with the June 21, 2016 BF software migration here**
#276
Jeff Vader
I can't insert video anymore.
We are all a litter of piglets in the barn fire of life - Piney McKnuckle
#278
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 649 Post(s)
Liked 139 Times
photo test message
edit: still can't post pictures into a message? comes in as attached thumbnail of a significantly reduced size.
I also see the weird yellow light fade on each message on multiple monitors...not sure it's a monitor problem.
#279
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times
So wait, BF was moved to PREVIOUS version of vB??? That seems really odd right??
#280
Quoted: 1186 Post(s)
Liked 289 Times
|| # vBulletin 3.9.3.0 Patch Level 5
#281
Quoted: 4249 Post(s)
Liked 2,961 Times
Yeah, that isn't an error. I don't know why they took away the default white background and just left us with this mess, but that's the only choice at the moment. Unless you want it to look like the mobile site and lose some functionality - I've actually considered that.
#282
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
And when I said bottom of the page, I mean between the last post & quick-reply box where they were previously.
It's a natural place for a quick link back to the forum index that requires no further scrolling, and I basically use it every singe time.
It's also much easier on mobile devices to hit that instead of thumbing all the way to the bottom of the page and trying to hit that tiny link in the extreme corner.
#283
Liked 2,961 Times
Check the the forum jump pull down box on the lower right. That should do what you want.
#284
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
also, have you SEEN that list of forums in the drop menu?
Besides, when you finish reading the last post in a thread, or when you've just posted and the page auto-loads t display your post right front and center, the breadcrumbs are right there where your mouse pointer already most likely is.
Maybe I'm lame, but it's a long way down to the bottom right corner.
#286
Administrator
Quoted: 223 Post(s)
Liked 224 Times
Two little issues experienced with Chrome in Android using full site version.
1. the above Quick Links drop down menu doesn't work.
2. on the following page (and those similar), when i select a particular forum, its link is greyed and becomes smaller in size:
Bike Forums - Bike Forums
when i select it again, the selected forum opens.
#287
Bikes: 1997 Kona Hahana Race Light, 2010 Surly LHT(deceased), 1999 Rocky Mountain Turbo
Quoted: 86 Post(s)
I use the desktop format on my android device (Moto X Play XT1563, Version 6.0.1) and drop down menus work for me?
#288
Administrator
Quoted: 223 Post(s)
Liked 224 Times
Mine too. When I try to unsubscribe to threads I get this message.
Invalid Redirect URL (https://outlook.live.com/)
#290
***RETIRED*** Do Not Contact
In answer to your specific question, NEW POSTS is a link dead center at the top of the page in the blue menu bar.
#294
Jeff Vader
#295
Quoted: 676 Post(s)
Liked 13 Times
Not sure if this has been posted or not, but I used to be able to do Ctrl-B, Ctrl-U and Ctrl-I to place Bold, Underline, or Italics tags with the cursor in between. Doesn't appear to be working now.
#297
Administrator
Bikes: Peugeot 87
if you go to your usercp and edit options, you can select an enhanced text editor which will allow you to do wysiwyg editing.
#298
Quoted: 676 Post(s)
Liked 13 Times
Another thing, links in threads to specific posts within the thread don't seem to be working, such as the links in the first post of this thread. They all just open a new tab and show the first post again:
https://www.bikeforums.net/road-cycli...ew-wheels.html
#299
Quoted: 676 Post(s)
Liked 13 Times
I don't know - in the past the Quick Reply box had Font and Color options along the top, and I think if I hit Quote on a post, a Quick Reply box would appear right below that post. Over in the Commuting Mileage thread, we usually post the text with Courier New font to keep everything aligned. I tried all the different text editor options, and all of them just showed a standard font with FONT tags, COLOR tags, etc. all showing. It wasn't WYSIWYG, even on the two enhanced options.
Try hitting Quote below this last post to see what happens. It used to Quote the text but display it in the correct Courier New font.
https://www.bikeforums.net/commuting/...l#post18876115
#300
Quoted: 676 Post(s)
Liked 13 Times
Yuck, both "Enhanced Interfaces" are not WYSIWIG at all. With the WYSIWIG interface, if I select text and specify a font, it doesn't actually change the font. It just wraps "TEXT" tags around the selected text. That's going to make it difficult to keep numbers lined up in that Commuting Mileage thread. In the CKEditor interface, there's not even an option to change text font.
So as it stands all the text editor interfaces are less functional than what we had before.
