More gasoline on the fire - Electronic Shifting
#151
Quoted: 4518 Post(s)
Liked 1,652 Times
Yes, I am weak and need push button shifting.
My excuse is lame. On a cross country race, a pickup mirror hit my shoulder sending me into a corn field putting a dime sized chip in my shoulder. A dog bit me calf the next day and the day after about 200 miles and 26,000 feet into the day or night, two dogs took me down and torn my rotator cuff. Foolishly, I did the last 600km and 30,000 feet trying to ride with one arm. Shifting mechanical is hard for this pu$$y
You might also suggest that I am racist against the French for developing electronic shifting.
Likes For Kontact:
#152
Quoted: 3980 Post(s)
Liked 7,429 Times
When I push the levers on my mechanical shifters, they shift. When I push the levers on my electronic shifters, they shift. Mechanical does not offer better “control” of the timing.
Likes For tomato coupe:
#153
Liked 1,652 Times
You've never noticed that you can shift onto the big ring slowly and with less force if you want to? You can.
Likes For Kontact:
#154
Advocatus Diaboli
Quoted: 4759 Post(s)
Liked 1,538 Times
Which is faster.. rolling up the window with a crank or with an electric push-button? That seems the net crux of this thread.
#155
Liked 7,429 Times
#156
Liked 1,652 Times
The usual expression is feathering, and it is something people do when they are shifting under tremendous loud, have wear or damage on the chainrings or have concerns about dropping the chain at a key time.
#157
Liked 7,429 Times
You can call it anything you like, but the fact is slow shifting means the chain is rubbing more on both the derailleur and the chain ring. There is no benefit.
#158
Liked 1,652 Times
It is always refreshing to take a break from reality and read about what people on Bike Forums are substituting for it. Your statement isn't as interesting as the ones about how springs work in this thread, but they are interesting.
#159
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
#160
Liked 7,429 Times
Reality is alive and well in my world, where shifting works best when you minimize the time spent in transition. I don’t think you will find an engineer in the cycling business that thinks it’s a good idea to slowly grind your way onto another chain ring.
#161
Liked 1,652 Times
Or I could just write down the whole insensible conversation and you can go back to pretending you don't have any experience easing a shift.
Likes For Kontact:
#162
Liked 7,429 Times
So we could have one of those back and forths where I patiently explain that it isn't just grinding away but feeling for the spot where the chain will go up with the least effort. And then you'll reply as if you've never experienced this, insist that what I'm talking about doesn't actually exist and then mischaracterize my initial post as saying that everyone should be shifting this way every time.
#163
Likes For ummed:
#164
Advocatus Diaboli
Liked 1,538 Times
#165
Quoted: 7666 Post(s)
Liked 3,530 Times
As for mechanical shifting and "rubbing' .... maybe y'all have forgotten the days of friction ....
Gently lifting the chain off the middle ring and depositing it perfectly onto the teeth of the big ring was a supreme skill .... At the time I was riding a lot and i got very good at shifting at just the right time to lift and drop the chain with minimal time and minimal grinding .... getting just enough of the chain to wrap that it would pull itself onto the chain ring but not to waste a moment, or momentum.
Something similar is possible with an indexed brifter because it is still a mechanical connection ... I can pull the lever a certain amount or speed and adjust, if say, the indexing is a little off (usually I just adjust the barrel adjuster but sometimes they stick and need two hands and I am not going to crash for adjusting a shifter.)
This does not equate to grinding.
Is this in any way better or worse than electronic, which pretty much does everything with a speed and precision equal to or better than even a skilled rider?
I simply don't care. Fight away to be the king of the Internet hill.
Likes For Maelochs:
#166
Liked 3,530 Times
And ... whether or not my (potential) next bike has electronic shifting, you can believe this---it will not have hand-cranked, roll-up windows. I am no Luddite.
#167
Quoted: 3253 Post(s)
Liked 2,541 Times
Likes For seypat:
#168
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Also, I trust myself to not drive off a bridge. More concerned with being able to do things while, you know, driving normally.
#169
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
#170
Quoted: 2333 Post(s)
Liked 2,097 Times
I don't think you are racist, I think you are weak.
#171
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2693 Post(s)
Liked 3,239 Times
Haven't read the thread, just want to weigh in on my experiences. Etap 11 user for a few years (TT bike, 1x up front) and recently Ultegra Di2 12 speed on my TCR (~8 months). I think the potential downsides are being a bit heavier and having to remember to charge them occasionally. The benefits greatly, greatly outweigh them IMO. I'll report back if/when I have other issues. I like not having to work on my bikes.
"Your beauty is an aeroplane;
#172
Liked 2,541 Times
Back around 2015-2017 a friend fo mine who was a hardcore triathlete won a new bike in a giveaway from his tri club. Nice bike with a SRAM group on it. He hadn't had it very long when we did this ride listed below. Throughout that ride, the FD would not shift correctly. At every SAG, the mech crew would have to work on it. They finally got it on the small ring at one point and told him to keep it there the rest of the ride. I don't remember the story of the bike after that.
https://ridewithgps.com/routes/29030456
#173
Liked 2,541 Times
That was a true story? I apologize, I didn't know. Epic read either way.
#174
Liked 1,652 Times
Why do you think the word "handicapped" is rude? Or is it like "gay", where it is an okay label for other people, but offensive if someone implies that it applies to you?
What's rude is that some people in this thread started talking about other people's shifting choices as if those others were cheap or stupid. And everything that's been posted since is a result of that.
I think your personal attack was weak.
Likes For Kontact:
#175
Administrator
Quoted: 11989 Post(s)
Liked 6,712 Times
Let’s drop it right now, you two!
