Why would hydraulic brakes fail after 6 mos in storage?
Klaatu..Verata..Necktie?
Quoted: 10507 Post(s)
Liked 12,054 Times
If you'd asked me, that time we met on Canada Rd, I'd have lent you my multitool with the 5mm allen key and you could have fixed it right there and then.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,324 Times
That was not because he found it innovative. It was because people just don't do that.
Quoted: 3986 Post(s)
Liked 7,441 Times
Liked 12,054 Times
Likes For genejockey:
Quoted: 2730 Post(s)
Liked 488 Times
I said “what did you think of how I fixed my brake?” When I noticed that they had fixed it, and he said something like “well, I cannot say it wasn’t inventive” or something along those lines.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,324 Times
I was wrong. He was being diplomatic.
Quoted: 245 Post(s)
Liked 469 Times
Brake bleeds are pretty easy once you get the hang of it. There are also some simple shortcuts to removing air bubbles without having to do a full bleed. Just make sure you are using quality syringes and can maintain an air tight seal on the line once you open it up. When finished pumping the go-go juice (aka mineral oil or DOT fluid) through the line close off the port at the caliper first, then close the port at the shifter. It's easy to ruin a perfectly good bleed if you close the port at the shifter before closing the port at the caliper.
Lastly, it should go without saying that you need to remove the brake pads and insert a bleed block before performing the bleed, but I've seen people perform this task with the pads in place and it usually doesn't end well. Best of luck! Learning to perform your own bike maintenance is a beautiful thing .
Liked 488 Times
No, but it took me a long time and many attempts to get it adjusted perfectly and once I had it how I liked it I was not keen on revisiting it, even after genejocky pointed out the bolt I needed to loosen. "If it ain't broke don't fix it"
I am potato.
Quoted: 1806 Post(s)
Liked 1,661 Times
SRAM DOT brake system?
Every single brake system I have seen that has the behavior that you describe has been a SRAM DOT system.
The fluid, although supposedly higher performing (resistant to boiling) when new, is very hydroscopic. It literally sucks moisture through the seals and quickly, quickly degrades becoming a greater volume of fluid...and poorer performing that mineral oil. Since the system is a fixed volume the pistons push out.
The "fix" is regular fluid replacement and bleeds.
You could also simply get a mineral oil based system like every other manufacturer that is not SRAM.
Car dependency is a tax.
Liked 7,441 Times
The correct phrase in this case is "If it's still broke, why fix it?"
Liked 12,054 Times
But, you know, a brake that doesn't brake IS broke.
Liked 12,054 Times
What he's saying is that he didn't MIND that it didn't brake.
Liked 488 Times
The caliper arms both still actuated, even though im grabbing it by one of the arms and fighting the adjustment bolt, it would still actuate and brake fine. Rim brakes are a robust braking system, if i tried something similar with disc brakes I wouldn't have a chance
Quoted: 682 Post(s)
Liked 455 Times
I saw it in person. It could not. The whole brake was twisted off center so that one caliper arm couldn't reach the rim, and the other - which had been rubbing on the rim - was tied to the seatstay with twine, so it couldn't reach the rim either.
Good grief. And he said he lives on a steep hill too. I guess it would be ok half the time.
Quoted: 682 Post(s)
Liked 455 Times
I quite like rim brakes for their aesthetics and nuanced feel, in the summer. I have them on my main road bike. But there's no question that discs are far superior at stopping - especially in the wet. And they're still pretty straightforward to maintain.
Quoted: 4505 Post(s)
Liked 4,994 Times
Noisy pads were probably down to contamination just before going into storage. Maybe rust forming on the discs. Clean, dry discs and pads can sit happily for 6 months without issues. Calliper pistons can sieze up though if left unused for a long time.
I am potato.
Liked 1,661 Times
Maybe the difference is that you use your regularly? I don't know the physics on that. Maybe any moisture in the piston/caliper area isn't left to stagnate? I'm sure someone on the Internet has a better theory
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,324 Times
I have both SRAM and Shimano brakes and neither need bleeding on a regular basis and certainly not after just 6 months sitting in the garage. Humidity is pretty high here too.
Last edited by Chuck M; 12-16-23 at 08:41 AM. Reason: Self moderated trollish comment.
Liked 4,994 Times
I'm sure they probably don't. Just reallying my experience with a small handful of bikes that were unused and exposed to the elements. A couple, like 4vor 5, and the fluid always came out in really poor condition. I have yet to experience any piston push out due to fluid degradation with any mineral oil system. The common denominator has been DOT. So, I thought it worth mention.
I rarely have to bleed brakes of any type. For example my 2019 MTB SRAM brakes have never needed bleeding and have spent 4 whole winters sat unused in the garage. The brakes still feel good and the pad clearance is normal. You could argue that the fluid needs changing to restore maximum braking performance in extreme use (higher fluid boiling point), but I don't overthink it. If I get a spongy lever then I bleed them and this doesn't happen very often IME. At least not with the current crop of brakes. I remember having to do more regular brake bleeds on older brakes from the early 2000s, regardless of fluid type.
Liked 12,054 Times
Do you have a photo of this miracle of materials science? I want to know how something that's tied with twine with enough force to hold it out of its resting position can then move against that pull.
