Affordable lighter steel road bikes with 27 wheels
Edumacator
Quoted: 2441 Post(s)
Liked 3,136 Times
Predominantly yes...
And I can say that when I converted the Trek Elance over to 700Cs, there was a bit more tire clearance. I think I put 28s on there with no issues.
The touring variety bicycles from the 70s/80s will fit even wider tires in the rear with 700s since you steal a bit of angle of the stays...but need longer reach brake calipers in the back... the big thing is if they have cantilevers, which limits you a bit.
Hopefully explained this right...
Quoted: 211 Post(s)
Liked 199 Times
The first year Schwinn Prelude, I think 1985 has 27in wheels.
I have one.
VERY SMOOTH and LIGHTWEIGHT
You do not see these for sale that often though.....at least in my area.............
I have one.
Quoted: 823 Post(s)
Liked 1,395 Times
The tire selection argument has always felt bogus to me. So long as Panaracer makes the Pasela, there is at least one good tire at least as good if not better than anything sold back during the heyday of 27-in wheels. There are a lot of tire widths I have no use for, tire colors that I would never use, and general marketing garbage I have learned to ignore. For non-competitive, non-extreme riding, 27 x 1 1/4 is an awesome tire size, especially with a decent tire. Ian Hibell rode all around the world on them, and so did many of the Rough Stuff Fellowship folks. It's a 32 mm wide tire that with a decently supple casing rolls very nicely.
I'm not entirely joking when I suggest that it's a tire size awaiting a 650B-esque renaissance. All that it needs is some marketing pizzazz and some coolio nickname. I propose The Dirty Six-Thirty, but I'm sure someone will come up with something equally inane when the time comes.
I understand the history - it was originally a Dunlop proprietary size built to compete with 700C, and while for many years it was THE performance wired-on tire in the Anglophone world, the whole globalization/standardization of 700C make the 622 more logical from a supply-chain perspective. On the other hand, there were millions and millions and MILLIONS of bikes sold with 27-in wheels, and someone is always going to market rubber and hopefully rims, because it's just too big a market to walk away from entirely.
My turning point came when I rode the Clunker Challenge a few years back on a '75 Motobecane Grand Touring with cheap IRC 27 x 1 1/4 tires at 70 psi to accommodate the vintage hookless rims. It was so smooth, and when I rode the same route the next day on a bike with 700 x 28s there was no appreciable difference in speed. I have been known to take advantage of the 27-inch-BAD fallacy - my full 531 Allegro was relatively cheap in part because the bike shop selling it assumed that 27-in wheels were entry level. They'd obviously never seen an early 70s Paramount.
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour, Surly Cross Check, 2021 Giant Talon 2
Quoted: 202 Post(s)
Liked 71 Times
check out the Frugal Average Bicyclist
Frugal Average Bicyclist The goal here is to help you keep cycling on a budget.
Quoted: 3811 Post(s)
Liked 6,716 Times
I sorta remember that when Jan Heine was first working with Panaracer to produce supple, wider tires, he queried the CR list to gauge interest in 27” versions. Went over like a lead balloon.
Bikes: 2011 Handsome/ Twin Six Speedy Devil, 2006 Soma Groove, 1991 Haro Impulse Comp, 1987 KHS Montana Pro, 1986 Ross Mount Hood, 1986 Mongoose ATB, 1985 Shogun Prairie Breaker I, 1973 World Voyageur, 1941 Schwinn DX "Klunker"
Quoted: 83 Post(s)
Liked 96 Times
World voyageurs came with 27in wheels if you are lucky enough to find one for sale.
Likes For MrK.:
Quoted: 823 Post(s)
Liked 1,395 Times
I'm actually not too surprised. I've been a member of that list since it started, and I went to the very first Cirque when it was held in the parking lot of the old store - and there has always been a bias on that list towards the zippier, lighter, speedier, SPENDIER bikes. And 27-in has long been regarded as passe, which is too bad, really. I wouldn't say go out and build a new bike using it, but it's still a surprisingly versatile wheel size.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
IMO- there's nothing better or worse about 630/27" as a wheel size compared to 622/700C. You can go on and on about the theoretical advantages and disadvantages of the wheel size- but they're so close they're effectively identical. At this point- the standard for wheel size has changed to 700C. Where you get into the difference is the tires.
Most of my bikes have 27" wheels. I almost made it a point of pride that I was running 27s. I changed a 700C bike to 27" to suit a set of brakes- and I was proud of that. I rode Paselas or Pasela TG or PT models and have one set of Sand Canyon tires. The one bike that I had that was 700C had Paselas on it. Around 4 years ago I decided to change to 700C on one of my bikes. I used Compass 35s. There was not just a noticeable difference... It was a full on different bike. It had nothing to do with the wheel size- it was all about the tire. As I get things more stabilized and settled in- I've been replacing 27s with 700C. And using good tires. Paselas are fine tires. But there's better. Much much better.
Until there's supple 27" tires with the options like there are for 700C- the 27" wheel is purely legacy.
Commence to jigglin huh?!?!
Quoted: 202 Post(s)
Liked 71 Times
Anyone have an estimate of what years quality steel framed road bikes with 700 wheels would of been common?
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,000 Times
I have this Raleigh Record Ace from 80 with 27" wheels, full 531 Reynolds steel.
In the top pic it has Kenda 27x1 1/4 tires in the bottom pic it has the original Blumel fenders and 27x 1 3/8 tires I brought from Cambodia. it would be better with the 1 1/4 tires and the fenders or the 1 3/8 tires without.
Likes For bwilli88:
Quoted: 2364 Post(s)
Liked 1,751 Times
While you're looking at shifters, also look for a frame with brazed-on mounts (instead of a band/clamp) for the downtube shifters. Generally a sign of a higher-quality build.
FIFY
FIFY
Likes For madpogue:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
You should do some reading here on Randy's old site
https://cycle.haus/mytenspeeds/FREE_...TRODUCTION.htm
Likes For dedhed:
Quoted: 202 Post(s)
Liked 71 Times
I was under the impression that 700 wheels didn't start getting common until the late 70s or early 80s. And it seems like steel bikes lost popularity in the 90s? That's not all that much overlap.
Quoted: 202 Post(s)
Liked 71 Times
Liked 6,716 Times
I also suggest you look through the catalogs in this thread: The Official Vintage Bicycle Manufacturer Catalog List w/Links
You'll see who offered road bikes with 27" wheels and where those models fit in the hierarchies.
Quoted: 823 Post(s)
Liked 1,395 Times
My perception is that there were more and more brazed on fittings in the late 70s and early 80s.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Dura Ace candy....
CC Bicycle Gallery: Jim Vasapoli's Nishiki ONP
I'll second the super le tour for OP topic. My '85 is pretty sweet.
Liked 1,703 Times
Generally.
Quoted: 202 Post(s)
Liked 71 Times
Ah, man...no way...lol.. My '82 Trek 614 (27" wheeled) came full cyclone mkII with symmetric band clamp shifters. There's plenty of other high quality bikes that didn't come with braze ons, either; miyatas, univegas, nishikis. other trek models.....
Dura Ace candy....
Dura Ace candy....
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 532 Times
Not mentioned so far is a quick way to I.D. a light weight (Quality) frame would be presence of forged rear dropouts, especially with axle adjusting screws, or at least the holes where they used to be. I have only once seen both on a mild steel frameset (was an entry level Sekai). Don
Likes For ollo_ollo:
Quoted: 3464 Post(s)
Liked 2,831 Times
27" wheels and tires had the same evolution that 700c did, the introduction of hook bead rims allowed higher pressures.
Unfortunately they also arrived when narrow was "better"
The clearances tightened up too save for dedicated touring bikes.
Paselas are fine. I run the non-PT ones with latex tubes on my '83 Miyata 710. But higher-end models do have a tangible edge on them.
27" is almost exactly the same radius as 700c, its existence as a separate road size would create supply chain permutation overhead, and I'm not sure what the proposed benefit would be. Both cyclists and the manufacturers would be hurt by this.
Quoted: 5224 Post(s)
Liked 3,585 Times
I was very happy riding this 1985 LeTour for several years (2010-2016). it wound up being my summer commuter for at least one of those years. in 2016 I donated this bike to a bicycle coop & they gave me $20.
the seat tube decal read:
cro moly
4130
stays
double butted
main tubes
frame built in America
cro moly
4130
stays
double butted
main tubes
Likes For rumrunn6:
Bikes: A bunch of old bikes.
Quoted: 278 Post(s)
Liked 873 Times
The "Super Le Tour 12.2" got the lighter weight in the late 70's.
Likes For daverup:
