Road cycling with a heart rate monitor
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Because once it creeps up over LT it's indicative I'm above threshold power and will soon burn out. Or more specifically, the threshold power has dropped below the power I'm holding.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Second, heart rate drift over time is normal and to be expected. Given the wide range of heart rates that threshold power can elicit, it doesn’t make sense to me to use HR to limit effort. Since fatigue is always multifactorial, it makes sense to evaluate the state of fatigue only on a similar multifactorial, holistic basis.
Quoted: 18883 Post(s)
Liked 10,646 Times
I agree about power being more useful in pretty much every way. I still wear the chest strap though. It's less useful but still has value.
Likes For Seattle Forrest:
Quoted: 741 Post(s)
Liked 412 Times
Not for me. At least with most of the riding I do. When I am doing a zone 2 ride, effort is so low that the numbers don’t really tell me anything that perceived effort doesn’t tell me. When I am doing structured work like zone 5 or above, it is mostly flat out and fairly short duration so, again perceived effort tells me what I need to know. Now I do use it when doing sprint type efforts to gauge recovery. I tend to do that type of work from a fully recovered state
Liked 10,646 Times
Quoted: 741 Post(s)
Liked 412 Times
I use TrainingPeaks which does a very good job of tracking power metrics in the road. Most of my structured work is either on a trainer or at the track. It is very easy to measure improvement in both situations. I just don’t find heart rate data particularly useful.
Likes For colnago62:
Quoted: 6199 Post(s)
Liked 4,816 Times
If good power meters were as inexpensive as good HR monitors, then many more of us might agree with you. <grin>
Quoted: 741 Post(s)
Liked 412 Times
That is true. It is a much less expensive alternative. Also, if I where running and swimming, I might might find more value in the data. I have SRM Origins on all my bikes and the numbers seem accurate between the devices. One of the things I dirst noticed when riding with power instead of HR, was my heart rate was a smoother with less peaks and valleys. I also noticed after collecting more data that when riding in within a lower power zone, my heart rate never increased so much that I needed to observe it. I began turning off heart rate when looking at data on the ride and after. Eventually I stopped using it for most training.
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,873 Times
Being physician and a physiologist, I like HR and HRV as state measures, but I agree that HR isn’t a very useful live parameter on the bike. It was much better for running, which is more steady-state, and I can remember what a revolution in training the first wristwatch monitors caused. I still look at my power/HR after rides and I also use the regression model that interval.icu builds for you, using a base of rides with power to derive an estimate of TSS from HR for rides without power.
Likes For MoAlpha:
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
I do most of my riding in what some call the "sweet spot" — high zone 3, low zone 4. It's easy enough that it doesn't wipe me out, and it still offers a good training effect.
Sweet spot training
Likes For terrymorse:
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
According to Andy Coggan, zone 2 will increase lactate threshold, but not as effectively as zone 3, and zone 3 is not as effective as zone 4.
Sweet spot training
Sweet spot training
And sweet spot workouts seem to work out. But the question over the last few years is whether that's really the optimal workout design. In this case, it's hard to determine because you're comparing something that appears to work (sweet spot) with alternatives that also appear to work. You're not comparing a good thing with a bad thing, or even a neutral thing, you're trying to compare and differentiate two good things.
But I think over the last few years, the scale has tipped in favor of more polarized training as the (slightly) better of the two good things -- or, at least, that's my understanding of the current state of the debate. A way to think about this is that where Andy's original schematic should've peaked? It should've peaked farther to the left. My current understanding is that the real sweet spot is farther to the left, and that another way to think about sweet spot isn't the intensity you can recover from by the time of the next workout, but rather a longer period of time since workout fatigue can cumulate. So another way to think of this in Andy-speak would be that ATL decays more slowly than Andy originally proposed, so sweet spot should be farther to the left.
At least, that's my understanding, and that's how I've been restructuring my training.
Likes For RChung:
climber has-been
Liked 3,567 Times
So the idea of polarized training is to add in some hard workouts to produce adaptations that you wouldn't get in "sweet spot" training?
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
One of the real contributions of Andy's work was giving us a way to trade off (some) volume for (some) intensity. That was what Frank Overton was trying to do: find a "sweet spot" that balanced the two.
When I'm time-crunched, I still trade off volume for intensity -- that's all I can do. But when I have the choice to do both, I've given slightly higher priority to volume than I used to, and keeping intensity low. But Berkeley is a lot like Palo Alto, and if I'm going to ride in the Berkeley Hills I'm going to get exposed to a lot of intensity no matter what, so there's a limitation to how low I can go on that.
Likes For RChung:
Bikes: Shmikes
Liked 5,873 Times
Old age may shift the trade-off in favor of a little more emphasis on the higher zones, since the cellular systems respond more sluggishly to training stimulus, or at least that’s what I’m assuming at age 65. Of course, recovery is also slower, so you more pay for those fast days.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
That's just a matter of definition. Be that as it may, the reality is that the power you can sustain over an hour is substantially less after four hours of riding than it is after one hour of riding at a similar intensity, which in turn is less than when fully rested. This droop in power sustainable is individual and trainable, and requires something other than power to track and train. Hence, the use of HR. When on hour five of your ride you go above your sustainable power, or get too close to it for that matter, your HR will begin to climb very quickly. This is the indicator that it's not sustainable.
Quoted: 741 Post(s)
Liked 412 Times
