3x9 or 2x11 for commuter/touring bike?
Quoted: 137 Post(s)
Liked 81 Times
I'll try to make this short and easy. If you were building a road bike designed for commuting to work/running errands and *possibly* light touring (like 2 panniers' worth), would you run a 3x9 or 2x11 setup?
Caveats:
1) Mostly used parts
2) Shimano (or Microshift equivalent)
3) You are not allowed to answer 1x12. Sorry.
I'm inclined to go for the 3x9 as I think I can cram more teeth on the largest cog if need be (looks like the 2x11 maxes out at 34) but it's a bit harder to find used parts for triples where I live - especially cranksets and brifters. Apparently riding a triple is the equivalent of drinking decaf coffee with soy milk.
Caveats:
little ring
Bikes: 2002 Bianchi Veloce, 1980-something Bianchi Axis Pro, 2003 Cannondale R2000
Quoted: 14 Post(s)
Wow, great answers! Appreciate all the input. @icemilkcoffee I'll be likely using rim brakes (cantilever or V), so good to know about 11 speed hubs. Wheels are not my wheelhouse (/bad pun).
Used GRX parts are even tougher to find than 3x9 here - otherwise that was my first thought.
Shimano isn't much help on their website (FFS, why have a compatiblity chart and not link to the specs PDF on each item? ), which is why I rely on the collective minds of BF to help me out. From what I remember, 10+ speed MTB RDs don't work with road shifters.
I think it's going to come down to brifter availability. 3x9 used brifters would be a miracle or I'll have pony up the cash for new microshifts. Bar ends are fine for touring, but as a commuter they can be somewhat cumbersome.
SE Wis
Quoted: 2747 Post(s)
Liked 3,403 Times
Likes For dedhed:
My similar-intentioned bike is 2x11 (with a subcompact crank) because I love Shimano road hydraulic brakes, but if we don't need hydraulic brakes either has its merits. It's also a bit of a matter of how low you need--getting 30t in the front and 34t is easy and in spec, 36t in the rear is out of spec and probably just works, and you can probably hack a 40t without a ton of drama, but if you're wanting a similar gear as a 22t and a 36t with a triple, the choices start getting really weird for 2x11 (Di2 with MTB FB and RD and road shifters, for instance).
I also have a straight touring bike with 3x9 with a 22t and 36t--it's probably what I would still choose if I were long distance touring in mixed terrain with moderately heavy loads.
I'm both somewhat old and slow and fine with that.
top
RD-RX400 is officially compatible with 36T, so when it is paired with 11s shifter it can be used with these 11s cassettes:
11-12-13-15-17-19-21-24-28-32-36 sunrace (compatible with 10s freehub)
11-12-13-15-17-19-22-25-28-32-36 sram (not compatible with 10s freehub?)
Likes For djb:
