Why I prefer rim brakes over disk brakes
Having cable rim brakes and hydraulic disc brakes, and having used the Magura hydraulic rims (but not cable discs) I found a significant difference between hydraulic actuation and cable actuation. Rim vs disk? Not so much. Theoretically the rim should be better, unless you need to keep the braking surface away from the ground. IMO rim vs disc is mostly full of sound and fury signifying not a whole hell of a lot.
Quoted: 2333 Post(s)
Liked 2,097 Times
latex tubes,
No boom
You read too much
You have no idea what you are talking about
I regularly descend 15% hills
The key is the epoxy and the pads
You are spewing 2009 ignorant fear
Liked 2,097 Times
Quoted: 3980 Post(s)
Liked 7,431 Times
Likes For tomato coupe:
Expired Member
Quoted: 3713 Post(s)
Liked 5,576 Times
climber has-been
Quoted: 3512 Post(s)
Liked 3,654 Times
Of course I am, because the laws of thermodynamics have changed dramatically since 2009, and resin no longer softens when it gets hot.
<insert eye roll here>
I lost a lot of money renting carbon wheels to clueless riders who didn’t know how to descend. Years after 2009. Including some rather dramatic failures of my wheels at the Levi's Gran Fondo.
As do I, on carbon rims with rim brakes. It's not a problem if you are a skilled descender using good braking technique.
No, that is not the "key" to preventing rim failure or tire blowoff from braking heat. Resin with a higher softening temperature can help a little, but pads do almost nothing to help dissipate heat from the rim (even if manufacturers tell you otherwise).
The key is using good braking technique.
You presume too much about me, relatively new account guy.
Suggest you ask around about me, and what I may or may not know. It could be enlightening.
You read too much
climber has-been
Liked 3,654 Times
Even a featherweight rider can blow a tire on a descent, if they don't know how to brake properly.
But a Clydesdale with the same crummy braking technique will blow a tire sooner.
It's a fairly simple energy equation, converting kinetic energy into heat. Clydesdales have more kinetic energy, so they generate more heat with the same braking.
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
When this old fuddy duddy sees them on TT bikes in Grand Tours, I'll consider them.
I bought into both clipless and index shifting immediately.
Buying an entire new bike, when I already have like 15, just to get the required thru axle seems stupid.
Disc brakes have some positives and some negatives. I cannot see a problem that they solve.
They are on the TT bikes of many pros riding in Grand Tours, not all, but enough that it’s fair to say they aren’t a novelty.
If buying a new bike isn’t for you, fine.
The negatives of disc brakes, in my experience, stem from people riding bikes and having not a clue about how to actually ride it, maintain it, or otherwise keep it functional. The problem they solve is predictable (much more easily modulated) and vastly improved stopping power, especially when they weather is crappy. But, a lot of folks don’t ride very aggressively, even when they think they do, or avoid riding a bike when it’s raining, so it’s understandable that they think discs are either no improvement or unnecessary. Probably the only place, in my experience, that rim brakes are equally sufficient to discs is riding on flat, dry pavement in sunny weather.
Regardless, rim brakes have functioned adequately for many years, and with the advent of a superior braking system in the form of hydraulic disc brakes on TA equipped bikes, that hasn’t changed.
read report disc can cause the front wheel axle to come loose.
i will never buy disc brake for safety reason.
besides, discs look ugly.
sad part is that the selection of rim brake is getting smaller and smaller every day.
Quoted: 4227 Post(s)
Liked 2,489 Times
The manufacturer try to put the blame on the victims. but i believe its more than just user error.
Some mfr is redesigning the fork to prevent this problem. But there is alot of dangerous disk brake forks still out there.
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 766 Post(s)
Liked 4,067 Times
no, problem is real. Just google it, there is so many stories.
I like disk brakes because they work extremely well, and need almost no maintenance. Some rim brakes work well and some of them don’t. I’ve never met a rim brake I liked. If others prefer rim brakes, that’s perfectly fine with me. But this paranoia about safety is laughable.
Likes For MattTheHat:
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 474 Post(s)
Liked 554 Times
I just took the fat bike out to see. I am running 180 front and 160 rear Formula rotors with Hope V4 brakes. The pads and rotors are fairly new and in very good condition. The tires on there now are Jumbo Jim 26x4.8, set to 10 psi with an accurate digital tire filling gauge so they do have good traction.
ON both pavement and gravel I can easily lock up the rear if I just grab a big handful of brakes. I can lock the front if I try, but I can also hold them just shy of lockup.
Our tandem is a breakaway but I take the calipers off if we are flying with it.
Hope does publish the max rotor thickness for the V4, but I can't tell you what it is off the top of my head.
Rim-Brakers are paranoid when it rains. Disk-Brakers are paranoid about cutting their leg off with the rotor.
Just kidding of course. Ya'll remember that broohaha years ago? Silly.
It boils down to personal preference as has been stated.
I own both and still prefer rim brakes although my Shimano XTR's on my Kona MTN bike are pretty F'n good. I have Shimano Dura Ace on one of my Wabi fixed gear bikes and man, they are sweet too.
I've only started using Disc brakes for the first time late last year. I hated them at first, the squealing, the rubbing and the ease of which they can be contaminated. Rim brakes were set and forgot for the most part, not much checking or adjusting. I persisted though, and despite not being able to solve the issues I mentioned, I started actually liking them! Although they still had two big downsides for me personally. I live in a very hilly area, as soon as I ride out of my road, I descend a tight, twisting road for a few kilometres where the gradient is easily over 20% at times. I thought Disc brakes would have an advantage here but I found them to be too good. If the road is wet or damp, my rear wheel locks up and slides if I press the rear brakes too hard. And I find it a lot harder to 'feather' the disc brakes compared to rim. Maybe more practice is needed on my part. So I'm not in either camp right now, I love the feedback and control of rim and the stopping power of disc (except of really steep hills). I'm sure eventually the annoying maintenance and noise issues of disc will be solved, once that happens I don't think too many people will opt for rim brakes any more.
Likes For sneakerfreaka:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,324 Times
The only time my discs have made noise is when they were wet. I've had my rim brakes not make a sound when wet. The difference I experienced is my discs still stopped the bike well. I don't understand the constant debate over which is better, but I also don't think I would ever buy a new bike again without discs.
My experience with disc vs. rim is that discs tend to he way easier on my hands and easier to modulate. Basically, I get more stopping power for less force on the brake and my hands appreciate that. That said, brake choice wasn't a factor when I shopped.
Clark W. Griswold
Quoted: 4431 Post(s)
Liked 4,075 Times
I guess with cheaper quick releases especially the modern open cam design and people not tightening them properly and checking their bikes once and a while you can loosen it but I imagine it has to be a lot to make that happen as I haven't seen it personally and haven't had any issues with customers and I have sold a lot of disc brake bikes with QRs over the years and now more thru-axle stuff and also work on other bikes not sold through us. I am sure people love to post horror stories but the JRA stuff is usually quite a load of hooey. People not knowing how to use a QR is usually the big culprit not Big Fork or Big Disc. I have seen more than my fair share of poorly done up quick releases over the years.
Cheap crap looks ugly, disc brakes and rim brakes of quality can look quite decent.
Quoted: 681 Post(s)
Liked 949 Times
each brand will feel different. Like magura mt4's were nice but they took 3 fingers for full power. I wanted to use one finger in the winter with gloves on so got some Shimano it's 4 piston and man 1 finger full power. but they take a delicate touch a lot more sensitive. but thats just a learning curve. our tandem has a v b rake on the back alone with a disc. man after trying that and how much work it is no wonder someone can over use a disc till they get the hang of it.
Liked 7,431 Times
Quoted: 631 Post(s)
Liked 406 Times
Rick:
