Welcome me to your forum
Prefers Cicero
Originally Posted by jyossarian
Waterproof ski gloves work well. So does soaking your shirt in liquid laundry detergent and riding it in the rain. When you get to work, just towel off, ring out the shirt and hang to dry. It's clean and so are you. Voila!
Hi Koffee,
DC is quite simple once you know the basics:
Quadrants: DC is divided into quadrants (NW, NE, SW, SE), and the axis is the Capitol. The various Capitol Streets (North Capitol (North Cap for short), South Cap, East Capitol...there is no West Capitol because that is where the Mall is). Easy enough.
State Avenues: varying lengths, almost always diagonal and leading to a circle or confusing intersection.
Numbered Streets: Run North-South, starting at the aforementioned Capitol. So you work at Union Station, that is just northeast of the Capitol. First Street NW runs alongside the west side of Union Station, and is one-way going south. It has a bike lane, but cars are usually parked in it.
Alphabetical Streets: Streets that run East-West are organized alphabetically AND by number of syllables. Again, the Capitol is the starting point (keep in mind the quadrants). The streets closest to the Capitol are simply letters: D Street NE, C Street SE...Then you get into the names alphabetical by syllable. After the letters, you get two-syllable streets in alphabetical order...such as Macomb, Newton, and Quebec. Then you get three-syllable streets alphabetically...such as Fessenden, Kennedy, Quackenbos.
So if someone tells you to meet them at 1409 Quincy NE, it's easy to find! NE, okay. 14th NE...go up to Quincy (two syllable, alphabetical)...see you at the Franciscan Monestery (they have great gardens).
The exceptions will drive you crazy, but knowing the rules will go along way in getting you where you need to go. And never forget the quadrant!
about gloves - i'm experimenting with that too, in my first winter commuting season here where it rains some ridiculous number of days in the year, with hands that turn unusable once they get cold. so far i've had no trouble in snowboarder's gloves at feels-like temperatures between 0C and 10C. They're light and flexible enough that i can still feel the gears, and have room inside them for extra layers if it gets any colder than this. don't know how cold it gets in dc though.
Tail End Charlie
Bikes: Fuji Nevada MTB, Giant OCR1
I was gonna try those oversized "food service" gloves you see them wear behind the counter at Subway for water/wind resistance. Couldn't find any. I'm gonna try your basic plastic food storage bags. Very elegant.
Why isn't 11 pronounced onety one?
Guest
Posts: n/a
Quoted: Post(s)
Nope. Sorry. Someone already sat down and pulled out the "just remember the quadrants" speech. That is not going to get me to visualize the layout of the city. My best bet so far is just memorizing maps. Perhaps in the next year or so, I'll have ridden around the city enough to pick up where things are. But that does nothing.
Thanks for trying anyway.
Koffee
Koffee
Bikes: Fuji Supreme
Koffee -- you'll definitely need to prepare for rain since that is the most common winter precip around here. Of course once you've prepared for rain then it freezes and all bets are off. In much of downtown you can use the Washington Monument as a landmark. Also since you are coming in from Arlington the numbered streets will be counting down as you head towards the Capitol. Lettered streets work up from the Mall. If you give us starting and ending points chances are very good someone can steer you through a very efficient route since there are many DC areas commuters on here.
I'm pretty sure you don't ride sidewalks but if you think about it, remember it is prohibited in most of the downtown area. Everything from 24th St NW east to the Capitol and from the Mall north to Mass Ave. The only place I have ever been hassled was up by the Capitol, otherwise it is only enforced in occasional crackdowns or if you have an altercation with a ped.
As for maps you should definitely check out the ADC bike route maps which can be found in most LBS. And in general any of the ADC road maps will give you very detailed maps of city streets -- even DPW carries these maps to find their way around. Also the Washington Area Bike Assoc. site has some good maps. I think you'll find DC is pretty practical on a bike if not always bike friendly.
Calamari to go
Bikes: Trek 750
The ADC (Alexandria Drafting Company) maps are the best for this area. The ADC bike map is ok, but they don't keep it updated quick enough.
Most of the maps put out by other companies are not nearly as good as ADC.
As you say, not much snow here. Usually only 2 to 5 good snow storms a year. There is usually not too much rain in the winter either. That'll happen in the spring.
Since our area is not warm enough to avoid freezing, and not cold enough to stay frozen, the big problem is ice. A lot of our winter storms happen around 30 degrees.
Best way to learn DC streets is to ride them, then look at the map and see where you've been. Then ride them again, trying alternate routes. You'll figure it out.
All Weather Commuter
Bikes: Surly CrossCheck, Giant NSR1
I got these gloves last year because I often have to de-ice my house gutters. They are water proof outer shell and you can remove the thick liner. I am useing the outer shell now and usually my hands are toasty but damp by the time I get to work. About 45 to 60 min ride.
REI 3-in-1 waterproof
Not great but they work. The problem I have is brakeing. The get bound up because the outside is rubber. So often to get a good handle on the brakes I have to adjust my hand position slightly. They keep me warm though, can't say dry since I sweat inside. My set is also all black with some stripes of reflective white. Not good for visibility.
Quoted: 170 Post(s)
Liked 156 Times
Welcome to DC commuting Rain will get you wet regardless of what you wear especially if the ride lasts 1 hour. After many years of commuting I find that 'serious' downpours do not last a long time. Well timed rides can really reduce riding in the heavy rains. If the rains are significant wait a little while, then haul ass.
Pants: I wear Sporthill brand of XC ski pants in the winter. Very wind and water resistant. Also dries quickly for the return ride. They will not keep you dry in heavy rain. I only use them in the winter when rains are infrequent. For cool rains I wear the waterproof performance jacket/pants. You will not get wet with the rain but will sweat like a pig. Basically you must decide cold rain or warm sweat. I also concur with oknups(hey Steve) to ride a bike friday and METRO(in bad weather). I bike and ride MARC. For route finding touch base with bikewashington yahoo group. Lots of local road knowledge. Enjoy DC, Charlie
45 miles/week
Bikes: Jamis Aurora
Hi, welcome. I don't really have anything to add, this is my first winter commuting too. Except that this morning was DEFINITELY NOT cold enough for windproof pants!
SERENITY NOW!!!
Bikes: Haro Vector, IRO Rob Roy, Bianchi Veloce
Originally Posted by tokolosh
yeah, but your towel is filthy
HHCMF - Take pride in your ability to amaze lesser mortals! - MikeR
We demand rigidly defined areas of doubt and uncertainty!
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,189 Times
Originally Posted by koffee brown
It's ridiculous. I was trying to find first street, which disappeared into another street (I think New Jersey or something like that), only to reappear as 1st Street at Union Station. It just doesn't look that way on the map at all. Someone was smoking some good weed when they put together that map.
Koffee
Koffee
Bikes: Mercier Corvus (commuter), Fila Taos (MTB), Trek 660(Got frame for free and put my LeMans Centurian components on it)
It is not filthy! It's soaked in nutrients! You can't even find your towel!
My towel is upstairs. At least until the ravenous bugblatter beast of traal shows up again.
Welcome to the Forum Koffee! As time goes on you will get to have the wonderful time of trying new routes and slowly dialing in your most efficient/safest route. I do about an hour and 15 minutes a morning myself. Perfect training for centuries.
Sunrise saturday,
I was biking the backroads,
lost in the moment.
Sunrise saturday,
lost in the moment.
In Arlington, you will also be initiated into the mysteries of Glebe Road. It appears all over the county in various forms. There is even an intersection of Glebe and Glebe.
Paul
Paul
more ape than man
i've still never sucessfully commutted to work. however i commute back and forth between my GF's apartment and my own all the time - often the morning before work or afterward with a change of clothes. so, i still consider that commuting. am i cheating??
Best rain jacket I've encountered.
www.showerspass.com
Their century elite jacket.
Made with event mtl which breezes a lot more than gortex. Pearl izumi makes one out of it also, except they have zero ventalation, not even pit zips.
The showers pass jacket has lots of venting.
www.showerspass.com
Calamari to go
Bikes: Trek 750
Paul
Paul
Administrator
Liked 2,189 Times
Paul
Paul
Originally Posted by StanSeven
Let's not forget route 123 as it moves out to Fairfax country - Chain Bridge Road, Dolly Madision, Maple Avenue, back to Chain Bridge, Ox Road and Monroe Drive. It's so easy for out of towners to find their way araound.
Sorry to lose you from the Chicago area. A rough winter is predicted, so you probably won't miss Chicago (at least the weather).
52-week commuter
Bikes: Redline Conquest, Cannonday, Specialized, RANS
Originally Posted by cc_rider
Would that be North Glebe, South Glebe, East Glebe, West Glebe or Old Glebe?
The explanation I've heard is that the Glebe is the part of a parish dedicated to the support of the priest. When Arlington was founded, the Church of England was running the show, there was a church at every intersection, every church had a glebe, and every glebe had a glebe road. Most of the other colonies were formed by separatists who were seeking religious freedom, so they didn't have glebes.
Originally Posted by velogirl
I'm fine in DC, but get me in NOVA and I'm lost.
45 miles/week
Bikes: Jamis Aurora
The only Glebe I know of is "Glebe and Sycamore", which you'll hear every SINGLE day in the traffic report on the radio. Don't drive by there, apparently. Maybe it's "Glebe to Sycamore" dunno but those are two street names you'll hear without fail.
Bikes: Trek 4300
What about waterproof gloves? I hate those performance neoprene gloves. They are only rain resistant, and when the rain finally penetrates it, man are my hands COLD! Then they never dry out in time for me to head home.
Koffee
Koffee
Mine have become wet inside, but I can't remember if it was from just heavy rain or if I did something. Because they are so nearly waterproof, drying the insides is difficult. If I just set them out to air dry after a rain and the inside is damp, it will remain so. So what I do is, when I get home after a wet trip, set them out to dry, or put them in the dryer if I am in a hurry. Then I check the insides, and if they seem at all wet I turn them inside out (a bit of a struggle) and run them through the dryer that way.
Theoretically, I wear a rain jacket that is a bit large, and ends of the sleeves overlap the tops of the gloves so water runs off. I am not so religious about keeping up that sleeve-glove seal, so that might explain how I can get water inside the gloves. I personally like them but have not had enough good hard rains to give a solid review of them.
Rider in the Storm
Bikes: LeMond Zurich, KHS Fiero (Fixed), Centurion Ironman Expert
I like to wear all my pants baggy, so it's a matter of finding rain pants baggy enough to suit me.
Commuting Horrorshow
Bikes: Giant OCR3, Decathlon ****box.
