1970s? Stella road bike
Friendship is Magic
Bikes: old ones
Quoted: 26431 Post(s)
Liked 10,391 Times
...one other thing that occurred to me.
If you want to ride this but are uncertain of the BB maintenance and lubrication history,
it's not unheard of to simply drip some relatively viscous oil in the BB bearings by sliding
it in past the crank spindle, with the cranks in place. You can usually get by for a couple
of months at a time using this method. Use 40 weight or Phil's tenacious oil or similar.
Clean everything off the exterior when finished with solvent or citrus cleaner.
Bikes: 2004 Cannondale Jekyll FS 5"Travel, 1971 Stella, Campy components
Wrapped some new red tape over the residue glue and it worked just fine! I stopped at a lbs free cycles and they were really excited about the bike and are going to help me get it back to great riding shape . They gave me two 700 X 23 120psi slicks. Is it okay to run these at just a 100? Should it be any problems with my older rims at higher pressure? They are clincher, and my rims are aluminum super champion, possibly original (1972-3). They cracked my freewheel loose, so re packed both campy hubs today.
Quoted: 836 Post(s)
Liked 2,164 Times
Just make sure that you aren't using folding tires with unhooked rims, or you risk the chance the tires will blow off the rim (usually at an inopportune time). 23mm @ 100psi sounds about right or near the tire's limit. Check the sidewalls for a psi rating as it varies from tire to tire.
I know that's your bike and all, but PLEASE don't turn it into a god forsaken fixed gear!!
It's getting rare to see a decent Stella in good original shape.
Quoted: 556 Post(s)
Liked 132 Times
Some of those old Super Champions were hooked, and some not. I have one of each. Just check the inside of the rim sidewall and see. In any case, 120 psi is probably the max rating. Lower is OK, but be careful with any non-hooked rim, as Gaucho said. Are they wire bead tires, or other?
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
A folding tire has a Kevlar (or similar) chord instead of a wire in the bead where it seats against the rim. They are significantly stiffer, hence can't be folded. A folding tire often comes from the shop in a small box, all folded up into a small package.
Real cyclists use toe clips.
jimmuller
jimmuller
On a non-hooked-bead rim the inside edge of the rim will simply be flat. On a hooked-bead rim the inside edge will have a lip sticking inward all along the outermost circumference.
For now I have to ride my mountain bike anyways a its been snowing every day and then roads are a bit icy.
Liked 645 Times
In the old days good vs. better tires meant 60 vs. 70psi. Then they started making 90psi tires, 28mm. I ran those for years on old rims. Now they are listed as max pressure 115 to 120 for 25mm tires. These are what can blow off, in my experience. Of course we didn't have folding tires at all back then. If you run your tires lower, maybe 85 or less, you maybe okay. Be aware that heat makes the pressure go up. Also lower pressure raises the risk of snake-bite punctures.
In the log run you should just pick up another tire, and in the longer run consider different rims which let you run whatever you want.
jimmuller
jimmuller
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Certainly in most cases the bottom bracket bearings can be lubed from the outside, allowing some thick oil to drip in, down along the spindle with the bike laying down on the side.
That should be good for at least a thousand miles or a year of use in decent weather conditions.
***EDIT: I see that 3alarmer beat me to this suggestion! I also use Phil oil, but in cold weather it flows most slowly!***
So I would leave the cotter crank alone for now, it was installed correctly at the factory in almost every case I can think of.
So likely a 1971 or '72 Stella, a nice find.
Likely the Suntour derailer replaced a Campagnolo Valentino derailer, which would be for the (much) better.
Campagnolo's Valentino rear derailers were good in name only, were somewhat of a disgrace to the brand.
Tire pressure should be based proportionally on rider weight.
For my 150lbs I run a 700x23 tire at mid-90's pressure.
Tubing / Frame
Probably Durifort tubing. The steerer tube might be stamped if it is. Mid-range bike for sure. Nothing wrong with that if you like to ride it. Tires, tubes, cables, bar tape & brake pads are all consumables and should be replaced as needed. New ones will do only good for your bike and you.
The frame was a Reynolds double butted tube and had some nice detail with impeccable welding. As the story goes the Stella Factory ( France) burned down and the two men wanted to get out of distribution and start manufacturing. They did just that in 1975 and started a bicycle manufacturing operation in Waterloo, WI... You may have heard of it TREK.
My Old Stella
It's been about 6 years since you posted this, so not sure you even still have the bike. But I bought the exact same Stella brand new in '72 or '73 in Sacramento California. It came with sew up tires that were glued to the rims, which I didn't want to hassle with, so I changed them out to 700c tires. Other than that, the bike was equipped the same as yours, except mine had a smooth saddle that I think was a plastic. I had the bike for about 7 years and rode it through college at UCSB. When I was 24 the bike was stolen from my garage in Sacto. Years later I saw a girl outside a convenience store sitting next to it. I told her it was my bike and she denied it saying that she had owned it for 3 years. Which was when mine was stolen. I described to her a scratch on the side of the seat facing the ground that I couldn't see. So she knew then that it was my bike. But said, I'm not giving you this bike. If I had tried to go into the store to call the police (pre-cell phones) she would have been gone. I decided to just let it go since she seemed to love the bike and was taking good care of it. But not trying to get it back has been a regret in my life and I've seen only a handful of Stella's since then, and never one as nice as the model I had. Thanks for posting your pics. It was wonderful to see again what mine looked like. BTW, I still ride old lugged bikes and still love riding.
I bought a Stella in Madison, WI. early 70’s. The bike store was owned by Bevil Hogg and Richard Burke both young men at the time.
Quoted: 1106 Post(s)
Liked 1,328 Times
This is a good trick to know if you are touring and taking spare tyres with you - they'll fit in a decent size pannier; if not, you can tie it on the outside.
mapleleafs-13
Classic & Vintage
101
10-12-11 06:48 PM
crobinson180908
Classic & Vintage
12
06-21-11 07:24 PM
