Retired and want to get back into cycling in my 60s.
#51
Quoted: 4494 Post(s)
Liked 4,966 Times
I chose the Endurace over the Ultimate. It adds a little long haul comfort and compliance for no perceptible loss of performance. I suspect it’s actually a little faster on mixed road centuries, carrying my 55 year old bones! The slightly wider 22 mm internal rims, 30 mm GP5000S TR tyres and slightly more comfortable cockpit all make a positive difference for me.
Likes For PeteHski:
#52
Method to My Madness
Quoted: 2010 Post(s)
Liked 1,516 Times
As a mechanical engineer I certainly know my trigonometry, but everyone wanting a new frame shouldn't have to use it. Once you know your preferred stack and reach range, plus your desired STA, it only takes seconds to figure out whether a frame meets your needs. It's a huge improvement to have this info. I also know that the proper stack can be affected by the stem angle. Two of my frames have -7 degree integrated bar/stems with internal routing of brake lines. Other bars and stems would make for an ugly setup. I chose a 505mm stack and use the minimum 20mm headset top cover setup. If a -17 stem is an option, I would prefer a 20mm taller total stack, with the headset top cover.
OK, three dimensions should be considered. Still no trigonometry needed. Many of today's frame have proprietary seat posts with inadequate setback for me. If the fame has a 75 degree STA and anything less than 25mm of setback on the post, it's an immediate NO.
#53
I understand that this is how you (and maybe others) evaluate a frame. That is fine. But it does not explain the contradiction between your two original statements (that I had highlighted above), which is all the more surprising given your apparent grasp of the trigonometry. To me, we seem to be essentially doing the same thing by looking at a third measurement in addition to stack and reach.
#54
Perceptual Dullard
Quoted: 939 Post(s)
Liked 1,201 Times
#55
Liked 1,516 Times
Understanding Bike Geometry (geometrygeeks.bike)
Now you have gone full circle. If the idea is to avoid calculation, then effective top tube is a number that more readily conveys the horizontal distance. Just because you are used to looking for a certain range of seat tube angles does not make the effective top tube number useless.
#56
You're really confused. The BB center is the starting point for reach and stack. Stack is the vertical distance from that point to the top-center of the headset bearing. The reach is the horizontal distance from a vertical line through the BB to the same point on the tip headset bearing. There is no fork involved.
#57
Perceptual Dullard
Quoted: 939 Post(s)
Liked 1,201 Times
#58
Huh? Effective top tube and reach are different distances along the same line, and the difference (which you are calling seat tube setback) is determined by the seat tube angle.
Italian builders often never used seat tube angle, back in the days of horizontal TTs. They used setback of the seat tube, which was different for each frame size. A geometry chart from the 90's listed the seat tube length, along the centerline of the tube, the TT length and the "seat back" that is the distance from a vertical line through the BB center to the seat tube center line. My 55cm frame had a 55cm TT and 15.2mm "seat back". The STA cosine would be 15.2÷55 =.2764. The STA would be 73.96 degrees.
#59
Liked 1,516 Times
The fork potentially affects both reach and stack because a longer or shorter fork effectively rotates the frame around the BB, moving the top of the head tube relative to the ground. This is how those "flip chips" work.
There's no use discussing this any further. I've bought my last 6 frames using only stack and reach, since they all had the same 74.5 degree STA. With the stack and reach numbers, I know exactly what stem length I need and the stem angle and spacer setup, before I buy the frame. I got no surprises. I never look at effective TT.
#60
Perceptual Dullard
Quoted: 939 Post(s)
Liked 1,201 Times
That stack and reach work as well as they do considering these points is actually kinda nice.
#61
Liked 4,966 Times
Maybe it is odd that I consider the fork as part of the frame set when making use of stack and reach values.
#62
Most road bike frames come with a matching fork. Since stack and reach are measured from the center of the bottom bracket, a fork change does nothing to alter those values. If a different fork length were used it would change the steering geometry and slightly change the BB height, but that does not change stack and reach values. Stack and reach are not relative to the ground.
#63
Quoted: 3980 Post(s)
Liked 7,430 Times
#64
Perceptual Dullard
Quoted: 939 Post(s)
Liked 1,201 Times
Have you seen photos of Moser's 1994 Hour Record bike? If he had used the same diameter front and rear wheels, even with the same fork, stack and reach would have changed.
#65
Perceptual Dullard
Quoted: 939 Post(s)
Liked 1,201 Times
Dan Empfield, the originator of stack and reach, agrees with me, not you.
#66
Liked 4,966 Times
When I see a manufacturer quote Stack and Reach I take it for granted they will be quoted with the original fork that comes with the bike. Same goes for all other fitting parameters which are dependent on the orientation of the frame relative to the ground plane.
Fork length only becomes relevant if you decide to change it.
#67
Liked 7,430 Times
#68
Liked 4,966 Times
So if my bike is quoted with a Stack and Reach of Y and X I would expect those numbers to relate to the designed fork length and wheel sizes. I don’t see what is odd about that?
#69
Perceptual Dullard
Quoted: 939 Post(s)
Liked 1,201 Times
I’m not disagreeing. I realise that Stack and Reach will change with fork length, wheel sizes, tyre profile etc. But so what? They are fitting parameters relating to the whole bike in whatever configuration they are quoted.
I tell the students that we teach undergrads how to do simple things, we teach the graduates how to do the complete detailed obsessive things, and we spend the rest of our careers figuring out when we have to do the complete detailed thing and when we can get away with the simple thing -- but that being able to get away with the simple thing doesn't mean that there's no difference between the simple and the detailed. I tell the grad students that they have to learn the details both because of edge cases where the simple thing fails, and also because we learn more if we understand why the simple thing failed.
Dan used cartesian coordinates based on the BB to formalize stack and reach. He could've used polar coordinates to describe those same two points in space -- but that would have made it clearer that he needed one more reference line, and Dan is more a cartesian guy than a polar guy.
Likes For RChung:
#70
Quoted: 512 Post(s)
Liked 663 Times
#71
I thought that we were talking about real bikes that are sold with a matching fork and how to compare the fit of different models. There's no reason to make some huge change to fork length.
#73
Quoted: 512 Post(s)
Liked 663 Times
You are really on a roll (of errors) in this thread.
The fact that this is how you shop for bikes does not make the effective top tube number useless. Otherwise, no one would report it.
#74
Liked 7,430 Times
Likes For tomato coupe:
