Threads repair
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
...these guys offer it as an online repair service for $25 which is pretty cheap), but the mailing costs might kill it for you.
Jeff Wills
Jeff Wills
Quoted: 18382 Post(s)
Liked 4,515 Times
Keep an eye open for single crank arms on E-Bay, although it can be harder to find current generation stuff than previous generation stuff.
Cranksets without the spider?
The threads stripped pretty bad. Chances are not have enough metal for a bigger insert. Even if someone will do the repair that will lessen the strength of the crank. I think the best bet is to shop for new crank..ouch
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,384 Times
Anyway, all this is by way of saying that if you run into it on a regular basis, it's probably not out of the question to buy yourself a kit.
You do need to remove the crank arm and do it in a vise, with a way to check that you're getting it started off at 90*. I usually just use a carpenter's square. *
For a while, there was even some company making and marketing a helicoil kit, with both LH and RH helicoils. Which is probably a stronger repair, but I've never had one of those sheet metal threadserts fail in use, so it probably does not matter. Don't know if they are still for sale somewhere.
To the OP, this repair doesn't remove a whole lot of material, and if your crank is that expensive, it's worth doing it. Those online guys mention they do SRAM cranks, so I'm guessing they wouldn't if there was much chance of failure.
*it's easier to do the drive side arm from the back, so you can clamp it in the vise with the spider and chainwheels up, not down.
Quoted: 809 Post(s)
Liked 712 Times
I'll be visiting Sellwood Cycle Repair tomorrow. Matt says they have the taps and helicoils but he wants to see the crankarm first. This gives me a little confidence that they'll say "no" if they think it won't work.
Jeff Wills
Jeff Wills
