Strava Segment - how much faster is a road bike than a hybrid?
#51
meh
Quoted: 1111 Post(s)
Liked 1,013 Times
https://www.bikeforums.net/general-cy...ead-sorry.html
To your point, compare the Globe Daily (city bike) or Marin Nail Trail (winter bike) with the Felt Z85 and Mondonico (pure road bikes).
The large sample size helps, but there are lots of errors in my comparison. For example, I typically ride the Globe with panniers, making it heavier and more wind resistance; and the road bikes will ride the segment on fitness/training rides. However, I feel that the top 20% of each bike offers a good 'feel' for what the speed differences are based on the same rider.
BTW - the tires are a lesser difference, the Globe is on 28mm T-Servs; the road bikes are on 25mm.
#53
Bikes: 12 Diamond Back Topanga custom build, 16 Niner Air 9 custom build, Slightly modded 16 Polygon Helios F5
Quoted: 21 Post(s)
I think you would first have to define "hybrid" and "road bike". You can have an 18lb carbon hybrid, and you can have a 30lb steel road bike.
#54
Quoted: 1186 Post(s)
Liked 289 Times
@Dan333SP, he did that in the middle of a long ride??? Wow.
You know what I did? I did a flying start. I got up to full speed before hitting Start at the boat dock. And I flew into the boat dock entrance at speed while hitting stop. Not cheating but not exactly a standing start either.
And I was fresh. I didn't bike before this.
And still in the 19s after all that.
So all I can say is Wow!
#55
Quoted: 20810 Post(s)
Liked 9,456 Times
#56
Since the strava segment is inside a metro park, make sure you don't go over the speed limit and don't put other recreation riders/pedestrians at risk.
#57
meh
Liked 1,013 Times
If you want to see the advantage of drop-bars (& riding on the drops) - I made my Pugsley a drop-bar fatbike for gravel grinding. Here's a pic from the 2016 Almanzo 100:
I made this conversation on Feb 29, 2016, also changed to (relatively) lighter/faster tires. Here's the Pugsley's performance on the same segment (see my earlier post).
Image screenshot from VeloViewer
I've ridden the Pug over this segment 155 times, and in every condition imaginable. I don't 'race' the Pug on this segment, the Pug's never gonna get my PR. So this give a good idea what the speed difference is with the same rider, over the same segment, with only changing from flat-bars to drop-bars (& lighter/faster tires). There's a time advantage, but it's not massive over a short segment. However, that small advantage pays off when you're riding a 100 miles!
#60
Bikes: Giant Escape 1
Quoted: 136 Post(s)
You could improve your speed by changing your tires. That would make the biggest difference. You could get more "aero" by riding in the drops on a road bike, but a lot of people don't like riding with their hands down there. You may be able to lower your flat handlebars some at the stem or by rolling them down. Do you use clipless pedals (or toe straps)? If not, this may improve your speed too. Do you use a bike computer so that you can see your speed? Do you pedal with cadence or power in mind? If you can develop a fast steady cadence and sustain it, that will improve your speed.
#62
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I'm going to go out on a limb here and say that it is the bike.
I had that bike (or maybe the next increment up), and it really was a mistake for me. I gave it to my daughter's flute teacher, and he likes it. I am older and less fit than you are, so my numbers would mean very little, but the difference between that bike and a good road bike are rather extreme. As others have suggested, even if it gains you nothing in speed, it will still gain you quite a bit in terms of enjoyment.
#63
Right, I've never heard of a path with a posted limit any higher than 15mph, aka toodling along on a road bike. But apparently this segment is a road with a 35mph speed limit so no issues there.
#65
Bikes: Huffy Sienna Cruiser
Quoted: 54 Post(s)
There is a path around that park but it has a 10mph speed limit. The only cyclists you usually see on the path are families going slowly with small children.
I rode the road around. I'm sure everyone else did too.
@Hypno Toad, that is a good summary in your thread. And like you said, the top 20% speed does show a marked difference when you step into the road bikes.
#67
Quoted: 507 Post(s)
Liked 237 Times
Also, were you wearing a skin-tight kit?
#68
I like to ride a six mile loop here in Michigan and the Stoney Creek metropark. It's a popular place to ride. Lately I started looking at my lap time compared to what folks are running on Strava.
I ride a stock Trek FX 7.4 hybrid on 32 tires and a flat bar. I'm in good shape. I lift and run every day. 6'1 and 168lb.
So I did the loop in the high 19 minute range.
I looked online and the fastest times were in the 13 minutes.
My question is - how much of that time difference do you guys think is because of my bike and how much because of me? For example, if I got my hands on something like a Trek Madone, would I drop two minutes or five?
#69
Quoted: 18883 Post(s)
Liked 10,646 Times
#70
Quoted: 54 Post(s)
@autonomy,
I was using the normal platform pedals that come with the bike. I was running around 60psi in the 32 tires. I didn't really do any maintenance beforehand. I lubed the chain at the start of the season. I rode in my normal position.
And I was wearing normal khaki shorts and a t-shirt, and hiking shoes. Not tight bike gear.
These are all things that are costing me speed, and that I could change before I swap the bike out. That's why I was wondering how much I left on the table, and at what point I'd hit the wall before I'd need to jump onto a better bike.
#71
Liked 9,456 Times
Tweaking stuff on your current bike or even getting a new bike might net you some relatively easy gains, but everything after that is going to be more and more hard-fought.
#72
Quoted: 507 Post(s)
Liked 237 Times
@autonomy,
Of course, biggest gains you'll see will be from wearing a team kit lol:
#73
Bikes: Yes
Quoted: 14 Post(s)
I feel like that's the sentiment a lot of people express here when they buy something (new bike, new wheels, new whatever) and think it's going to gain them X time or X speed.
There's no replacement for time in the saddle, and particularly hard efforts/intervals if your goal is to go faster for a given distance.
FWIW, you could just put some clip on aero bars on your hybrid and swap your tires for 25mm slicks. Then the difference between your hybrid and a true road bike would be virtually nill.
#74
these are my results for a local TT loop on country roads (8.3 miles 469ft 0% grade):
Road Apr 2, 2017 29:51 16.7mi/h
Hybrid Mar 20, 2017 31:39 15.8mi/h
Just the last half which is slightly downhill (3.9 miles 390ft -2% grade):
Road Apr 2, 2017 9:10 26.0mi/h <-- was in the drops the whole time.
Hybrid Mar 20, 2017 9:50 24.2mi/h
My road bike is geared 53/39 w/ 11-27 25c conti 4season tires. Hybrid is 1x 40t w/11-40 44c compass tires.
#75
meh
Liked 1,013 Times
@autonomy,
Warning: You can get lost watching their videos, they have tons of entertaining and informative content.
