best hitch mount bike rack
Quoted: 41 Post(s)
looking for decent bike rack that slides into hitch for 2 bikes,,,I don't want them touching each other
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
If you don't want the bikes to touch each other, a tray-style rack (aka platform rack) is the way to go.
eTrailer has a bunch of options HERE, and I've been happy with their pricing and customer service in the past. Thule and Yakima are probably the best-known brands. Hollywood and Saris racks tend to be good, too.
The size (1 1/4" versus 2") and class rating of your vehicle's hitch will affect your options.
Senior member
Quoted: 946 Post(s)
Liked 663 Times
It is very versatile, in that I can space out the wheel holders to accommodate my long wheelbase bikes, something I could not do with the Thule T2 I had previously.
Not really knocking the T2, it's actually a more sturdy, high quality rack than the Hollywood, but when I got rid of my pickup truck with it's 2" receiver, and went to a car with a 1 1/4", the T2 didn't work for me.
Senior member
Quoted: 946 Post(s)
Liked 663 Times
Yeah, it has a little bit of flexibility, but not enough for my longtail cargo bike, tandem, and LWB recumbent.
The Hollywood accommodates all of them. Not at the same time, obviously.
Quoted: 41 Post(s)
I have that one too, and I am also pleased with it.
????but this one you say you have now is for a 2" receiver
Senior member
Quoted: 946 Post(s)
Liked 663 Times
It is made with a 1 1/4" bar, but comes with an adapter to fit a 2".
I bought 2" TO 1 1/4" adapter so I could use the T2 on this car, but it stuck out too far to be practical.
plus, I could not mount my long bikes on it, so I sold the T2 and bought the Hollywood.
No regrets.
No regrets.
The BEST is going to be a Kuat or 1up usa. I went with the 1up myself.
using an adapter to put a 2" rack in a 1 1/4" receiver cuts your max tongue weight in half.
Quoted: 41 Post(s)
Bikes: 1980 Koga-Miyata Gentsluxe-S, 1998 Eddy Merckx Corsa 01, 1983 Tommasini Racing, 2012 Gulf Western CAAD10, 1980 Univega Gran Premio
Quoted: 600 Post(s)
Liked 11 Times
Pay attention to the class ratings, not hitch size!
So I ended up buying a rack (and adapter) that I couldn't use on my Prius, which can only handle a class 1 receiver (because the hitch receiver doesn't not bolt to the frame, as is required for classes 2, 3, and 4). I finally found a great rack that is class 1 and handles 3 bikes (as long as they're lightweight bikes like road bikes). No way you'll find a tray rack for class 1, unfortunately.
If you're hauling your bikes on the open road, you really need to make sure you respect the specs of your vehicle, your hitch, and the weight of your rack and bikes. It would be very easy to used an adapter and a class 3 bike rack, with some heavy bikes, on a class 2 hitch receiver and have the whole rear of your car cave in at 70 mph on the freeway.
Quoted: 600 Post(s)
Liked 11 Times
Same principle is why you put your heavy bike closest to the car on the rack. I can put 90# of bikes on my 3 bike rack, but I'm taking a big chance if I put a 90# bike on the 3rd spot, because that's generating much more torque on the hitch than a 90# bike in the first position.
Quoted: 600 Post(s)
Liked 11 Times
Put more simply, tongue weight is ALL you care about with a hitch mounted bike rack. Towing capacity of the hitch is irrelevant. Better to stop shaking your head and understand this stuff, or you'll come to grief.
Bikes: Specialized Roubaix Expert Road and Specialized Stump Jumper FS Mountain; De Vinci Caribou touring, Intense Tracer T275c, Cramerotti, Specialized Allez, Condor, Marinoni
Quoted: 168 Post(s)
Liked 106 Times
I've used Swagman. Less expensive than Thule or Yakima. Has a sleeve adapter for 1.25 or 2 inch receivers. Gets your bikes from a to b; doesn't damage them. What more do you want?
Quoted: 41 Post(s)
Yes, this is another very important factor. The 'tongue weight' is the weight the hitch can handle where the rack tongue goes into the hitch receiver. The adapter sticks out from the hitch receiver, generating torque (Force through a distance). It's the same principle that we use when we use a really pipe on the end of a wrench to generate extra force on a stuck bolt. Your class 2 hitch, which can handle 300# at the receiver, can handle less tongue weight at the end of the adapter.
Even if you do put a 90# bike on the rear you are safe putting it out on the end with a class 2...lol ive hauled bassboats with class 2's with a heck of a lot more tongue weight,,,it wont break trust me,,,
Quoted: 41 Post(s)
Lol...yea I guess the several hundred thousand miles ive hauled on a class 2 I better not overload it with a couple bikes...lmao....
Quoted: 600 Post(s)
Liked 11 Times
Have it your way, cvman. My guess is that you're not actually hauling a bass boat, but hauling a trailer that has a couple of wheels, and the bass boat is sitting above those wheels. Those wheels are supporting most of the weight of the trailer, and virtually all of the weight of the bass boat (unless you don't know how to load a trailer). That's why you can easily grab the trailer tongue and hold it level with the hitch while you make adjustments before the trailer is attached to the hitch.
The actual tongue weight of your trailer with bass boat loaded is likely a lot less than the tongue weight of a bike rack and a couple of bikes. It's simple physics. But whatever, you're the expert who can't figure out why tongue weight matters on a hitch-mount bike rack.
Quoted: 941 Post(s)
Liked 319 Times
Well, my two bike rack on my Honda Pilot (pretty substantial box steel by the way and a class 2 hitch) carries a 75 lb weight limit.
Quoted: 41 Post(s)
Lol,,,you CANT grab the tongue and lift it easily,,,unless you can easily lift over 100 pounds ! And IF you could that would mean the tongue was WAY to light,,,and the trailer would whip all over the road,,,trust me,,,ive trailered hundreds of thousands of miles...this may help educate you a little Boat Trailering: Tongue Weight | Boat Trader - WaterBlogged
My 20ft Ranger and motor weighed over 2k pounds,,,so 10 to 15% of that SHOULD be tongue weight,,,think you can lift that easy ???
If you think the tongue weight of a 20ft Ranger bassboat is lighter than a rack with bikes,,,well YOU really have NO clue what you are talking about and have NEVER hauled a bassboat...I may not be an expert but again have set up hundreds of trailers,,,,and have towed boats all up and down the east coast thousands of miles,,,,so I really do know what om talking about,,,its clear YOU do NOT ! Good day !
