FD for an old MTB
It appears, based on the second photo by the OP, that this FD has an adjuster for the spring tension. It's the allen bolt next to the inner cage, right above the chain in the 2nd photo. Depending on its current orientation, it may be possible to increase the return tension. There should be arrows on both the bolt and the body. Aligning the arrows is for standard (lower) tension, arrows at 180 degree is for higher tension.
If it's currently on lower setting, this adjustment may give you what you need to overcome the cable friction.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
Stuart Black
Stuart Black
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
IIRC, early 90s Treks had a weird FD cable routing strategy. At least some of them had a pinch bolt on the frame, as OP's does, and a stop for the housing on the actuating arm of the derailleur, and no pinch bolt on the derailleur.
It is very hard to tell form the OP's pictures, but I think that setup has been modified on their bike. It almost makes me think someone has added the pinch bolt on the derailleur where there would not have originally been one.
If you got a compatible bottom-pull derailleur, if you could swap the cable pinch bolt for the cable housing stop on the existing derailleur, that might work.
I think you are mistaken. I haven't run across any front derailer...or rear, for that matter...that has any kind of adjustment to the spring tension, especially not lower to middle of the line Shimano and not old stock. There's no Allen bolt on that derailer other than the cable anchor and the clamp.
A few RDs also had adjuster (eg: RD-6401, RD-M735). These were also 1990 vintage. These were the older design that used a coiling action spring, as opposed to the more modern pulling spring, (the spring that can be seen running the length of the parallelogram). The adjuster was a screw located on the parallelogram right under the cable anchor point.
FD-M550 LX Tension adjuster
Edit: Post #29 & photo was to show the return spring tension adjuster and is not related to the cable routing/attachment that others have explained.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
Try routing your cable housing from the top tube cable stop to the cable stop on the derailleur (I think this is how the housing is routed in the first set of pictures), and anchor the inner cable to the bolt on the frame. Do not anchor the cable to the bolt on the derailleur. This was how these bikes came from the factory.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
Here is how the connection was described in a different discussion:
https://groups.google.com/forum/#!to...ch/CJwcCaeZV9M
I have a 1992 TREK 970 frame with top tube cable routing. There is a cable
housing stop for the front derailleur on both ends of the top tube. There is
no other stop before the cable housing reaches the front derailleur but there
is an anchor bolt beyond it on the bottom bracket shell just below the
chainstays.I have a picture of the built up bike and it appears the cable & housing goes
from the rear stop on the top tube to all the way to the front derailleur,
beyond that only the cable extends through the derailleur and appears to anchor
on the bolt down on the bottom bracket. The front derailleur does appear to
have some kind of housing stop on it.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12778 Post(s)
Liked 7,695 Times
Aha so housing pushes derailleur arm down. Interesting setup!
