What is your cruise speed in top gear on flat ground?
#51
Bikes: 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 213 Post(s)
Liked 589 Times
I'm too old and slow to worry about all the technical details. My average speed over 20-30 miles of rolling hills is 10-13 mph.
#52
Quoted: 1062 Post(s)
Liked 665 Times
I think about this for a couple reasons: Estimating the duration of longer rides, and choosing a gear ratio for my single speed bike. With effort (i.e., not lazy cruising), I can maintain 13 - 15 mph. Above that speed, I hit an aerodynamic "wall." Likewise there's a similar "wall" for climbing grades. I'm not all that strong, and belong to the "lucky to be riding at all" camp. Since my body can't generate the power to go faster, I don't need to be geared to ride any faster. So my top gear and bottom gear are the same, and I've chosen a gearing so I can maintain a brisk but reasonable cadence.
I could choose a higher gear to take advantage of tailwinds and downgrades, but at the expense of struggling on headwinds and upgrades. So my gearing is naturally a compromise. As I get older, climbing hills becomes more important than arriving at a destination sooner.
#53
Bikes: '23 Devinci Hatchet Carbon Apex1 '19 Norco Bigfoot 6.1 ,'12 Motobecane Turino (killed by dog crash), '12 Trek 3700 Disc
Quoted: 149 Post(s)
Liked 128 Times
My top gear is 28-11.
On the flattest*** stretches with no wind *** I "cruise" at 25-30 km/h
Down hill I coast as there is no tangible benefit to pedaling above 30 km/h
*** PEI is essentially devoid of flat and windlessness. Yesterday was "light" winds of 20 gusting to 40 km/h
#54
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2680 Post(s)
Liked 5,915 Times
In Arizona its about 90-95 MPH in top gear. Around here about 80.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
#55
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 419 Post(s)
Liked 853 Times
- If your legs are burning, you are in too high (hard) a gear
- If you are out of breath, you are in too low (easy) gear.
- On flat terrain, you like will be most comfortable at gear 2 of the 1/2/3. You can then switch between 1...7 based on items 1 and 2 above
- On uphills, you will likely be most comfortable at gear 1 of the 1/2/3. You can then switch between 1 and 5 based on items 1 and 2 above. Using 6 and 7 with gear 1 is discouraged; it will wear out parts faster. If you are using 5 and you are running out of breath, try 2 and 4 or 2 and 3.
- On downhills, try gear 3 of 1/2/3. Limit the other gear to 3-7 to avoid premature wear.
Likes For john m flores:
#56
Quoted: 1790 Post(s)
Liked 1,318 Times
I don't know any absolutely flat roads around here. All I can say is there is a Strava segment near me that is 1 mi. with 1% decline for the first half and 1% incline for the end. When I was young (75) I did it at 25 mph. In general I would theorize that, on a flat road, I could "cruise" around 20-23 mph.
#57
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,099 Times
The 1/2/3 likely controls the front derailleur and the 1...7 controls the rear derailleur. As livedarklions mentioned, there's no standardization on how big or small any of the gears are, but as a general guide:
Just to be clear for the OP, you're indicating that gear 1 in the front is the smallest one, and in the back. Gear 1 is the biggest one.
This gearing numbering is also not standardized, so I think it's best to spell this out.
#58
Quoted: 419 Post(s)
Liked 853 Times
Yes, that's the way trigger shifters and Gripshifts are typically numbered, lower number = easier/lower, higher number = harder/higher.
#59
Tragically Ignorant
Liked 9,099 Times
Assuming they're actually numbered. Last triple trigger I had didn't have any numbers on it. Not sure if OP was referring to markings on the shifters or not.
BTW, I think your post was good, I've just seen newbies IRL get confused by this "high gear/low gear" thing. The logic being reversed front to back is not intuitive for us less mechanically inclined folks.
Likes For livedarklions:
#60
climber has-been
Quoted: 3557 Post(s)
Liked 3,718 Times
- If you're pedaling slowly and having to push hard to keep the pedals moving, shift to a lower gear.
- If you're pedaling quickly, and you sense very little "push back" on the pedals, shift to a higher gear.
Likes For terrymorse:
#61
Habitual User
Quoted: 5061 Post(s)
Liked 8,343 Times
Likes For Eric F:
#62
Tragically Ignorant
Liked 9,099 Times
#63
Habitual User
Liked 8,343 Times
I would pick running over swimming. I'm not very good at running, but I'm a lousy swimmer. There is zero chance of me ever being interested in a triathlon.
#64
Tragically Ignorant
Liked 9,099 Times
#65
Habitual User
Liked 8,343 Times
From running? Most of the serious runners I know are constantly complaining about pain and injuries. I'm fairly convinced that serious runners are enablers in an abusive relationship.
#66
Tragically Ignorant
Liked 9,099 Times
I'm not even a "broken runner", my feet are congenitally bad. It's what got me into biking.
#67
climber has-been
Liked 3,718 Times
#68
Habitual User
Liked 8,343 Times
Likes For Eric F:
#69
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
Yet there's a persistent notion among kids (and grown-ups who still ride bikes like they were kids) that once you can ride everywhere in top gear, you've "arrived" as a cyclist. And what's left after that, besides seeing how fast you can ride in top gear?
#70
Went for a ride today and tried to keep the intensity up the entire 3.5 miles.
3.5 miles, 14:41 moving time, 183 ft. elevation
I def. max out the speed on downhills. More gears would result in higher max speed
Recall, this is knobby tires, upright handlebars, garage sale bike, etc
I want to borrow a premium road bike from someone and compare times doing the same loop
#71
Expired Member
Quoted: 3781 Post(s)
Liked 5,756 Times
Ok
#72
Last summer riding around Lac St Jean on the Veloroute des Bluets, my average was 8-10 mph for 30-50 miles. Since that was in Canada , it was more like 13-16 kph for 48-80 km. which sounds more impressive.
Likes For Pratt:
#73
The only time I would use my top gear of 89 gear inches on flat land with my 3 x 7 speed comfort bike is with a moderate tail wind. In which case I might cruise at 27 - 30 kph. Max with a stronger wind or descending a low grade is 32 kph @ 75 rpm. Any faster then that descending a hill I coast. There are no hills near me to test my downhill speed. Only a gravel trail that I must brake on to safely navigate.
My normal cruising gears with a cadence of 60 - 70 rpm on flat land are 49, 55, 62, 70, or 78 gear inches for about 20 kph +/- 5 kph depending on the wind. Average speed including obstacles (like pedestrians and dogs) is closer to 17 - 18 kph.
