Giant Roam 2?
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
hokiefyd considering the way I am sure most people will be riding this sort of bike, 40 x 11-36 is a perfectly sufficient amount of gearing and should actually work rather well - for its intended purpose.
fwiw, my current setup is a 38/48 up front, and a 9 speed 11-34t in the rear. Main advantage with this setup would probably be a better chainline, and the benefit of getting to quickly switch between a climbing/cruising gear, to a sprinting gear, and back, using the front derailleur.
I typically only use the large cog up front for sprinting. Most of the time, im in the granny gear up front, which allows me to use the wide range of cogs in the resr cassette quite commendably.
If you climb steep hills on a regular basis or ride with a relatively heavy load, it probably wouldn't work so well.,but again , the roam isn't really for that. The biggest thing slowing you down would be that heavy 60mm suntour fork.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 763 Times
I have to think Giant spec'd the 40t crankset with a much wider 10-speed cassette in mind (like an 11-46) to go with the Deore derailleur, as another poster apparently has on his or her 2021 Roam 2, and they've had to step back temporarily to an 11-36 9-speed setup due to supply chain issues.
Drip, Drip.
Liked 193 Times
Liked 763 Times
I will state an observation that many bikes intended for commuting have what is close to a 1:1 low gear. So if the cassette tops out at 36 teeth, then the chain ring will have about 36 teeth. Many commuters and tourers have double or triple chain rings, so the low gear might be much lower than 1:1 (such as a 28 tooth chain ring with an 11-32 cassette).
Whether or not that suits you is totally up to you.
