How best to lift handlebars ...
Maybe one of these options from Velo Orange? But not for carbon steerer tubes and make sure that installation is per spec.
https://velo-orange.com/collections/...cts/cigne-stem
70 or 90 mm length available
Or,
https://velo-orange.com/collections/...py-stem-31-8mm
45 degrees - 90 or 110 mm length available
Or,
I saw a guy once who had 6-8 inches of extra rise by clamping, literally, a pipe to the top of his steerer tube. This would be functionally the same but a little more elegant.
https://hostelshoppe.com/cdn/shop/pr...g?v=1577836859
Advanced Slacker
Quoted: 2763 Post(s)
Liked 2,537 Times
Some combo of stem and riser bar will get you where you want to be. 2" risers are very common. And getting another 1" fro a stem is pretty easy to do.
IMO, People who need bikes with shorter reaches and longer stacks (like me) are better off going with the correct reach and using spacers/stem/riser bar to get the stack right.
^ Agreed. The bike simply doesn't fit. An adjustable stem might make the fit "less bad", but I would not recommend it as a "solution".
I purposely, and with difficulty, refrained from saying this. After a certain age, one needs a back up plan, how is one going to get back up after kneeling, stooping, crouching, etc.
Bikes: Bicycles? Yup.
Quoted: 486 Post(s)
Liked 1,612 Times
Big changes in stem length, that I've noticed.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,045 Times
Otto
Quoted: 486 Post(s)
Liked 1,612 Times
I'm certainly not as conversant with the techniques and consequences of changing a bike's bar height as the above contributors, but if I were in your situation, I would be tempted to wait a bit on changes. You say you are getting back into riding after a longish layoff, perhaps as you start riding more, you will become more flexible.
When I got back on a bike, I HAD to raise the HB height so I could ride comfortably. It took about 5 months of regular riding before the combo of improved flexibility and core strength took hold and I could revert to roadie-height bars. I probably spent $75 on riser bars, brake levers and cables, but the higher bars had to come first.
