ISO and for trade thread part 5
#4626
Bikes: many
Quoted: 1448 Post(s)
Liked 1,396 Times
* There might be situations where you can get away with it. If your Italian BB shell has been aggressively faced it might be closer to 69mm wide, in which case you might get away with a simple cup swap.
#4627
Quoted: 1873 Post(s)
Liked 692 Times
Generally, no*. An English BB will be designed for a 68mm wide bottom bracket shell, while Italian BB shells are 70mm wide. Your English spindle would be a couple mm shy of proper length. You'd probably be better off just angling to swap your complete English BB for a similar Italian BB.
2019 Salsa Warbird
2019 Salsa Warbird
#4629
“Senior” Member
Likes For obuckler:
#4630
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Lookin' for a French-threaded Atom 77 compact 6-speed with a 30t large cog (or 32t, if such a thing exists...), or comparable French-threaded 6-speed/30t that would work with a 120mm or 126mm rear hub. Thx
#4631
Quoted: 1106 Post(s)
Liked 1,328 Times
There was such an english 14-32 at the local coop recently if that might help, I could go have a look to see if it's still there.
Likes For oneclick:
#4632
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#4634
Quoted: 761 Post(s)
Liked 1,563 Times
I am green with envy every time I read references to a "local co-op"..... There ain't really even a half-decent LBS near me! Sounds like assembling what I want from and English & a French FW is the way to go. That'd be fantastic if the 14-32 is still at your co-op!
Likes For oneclick:
#4636
Quoted: 761 Post(s)
Liked 1,563 Times
#4637
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 429 Times
Front derailleur- bottom pull widget
i sold my simplex front mech.
got this Suntour front mech
I’ve got a cable guide on the downtube
but I need a guide below the Suntour front mech.
my simplex had a cable housing stop.
Dang it.
Anybody got something to help?
#4638
tantum vehi
Liked 992 Times
Likes For mountaindave:
#4639
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Quoted: 331 Post(s)
Liked 415 Times
In a pinch, you can route a short section of housing under the BB from the cable stop (or bypass the stop completely), just terminate it as it heads up toward the FD. Friction and cable tension will keep it in place. I did that on my Gitane TdF and it worked perfectly.
#4640
tantum vehi
Liked 992 Times
I give my LBS credit for clueing me in when I had exactly the same crisis.
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#4641
I need one of these
It goes to a Modolo Sporting brake lever, but I suspect there may be clamps from other similar levers that would work.
#4642
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Likes For thook:
#4643
Thanks! Though I'm impatient to get this bike built up, I actually need several key parts before it's rolling, so the left brake lever is not an urgent item. No rush.
#4644
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
#4645
The main thing I'm looking for is a set of derailleurs for an '83 Holdsworth Professional. So Campy Super Record is probably most appropriate, but also the most $$$ so I might go with 80s vintage Dura Ace or Superbe depending upon what I find that looks right and is a reasonably good deal.
Here is a link to the build sheet so you can see both what I've got and what I still need.
#4646
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Likes For thook:
#4647
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
#4648
buy my bikes
Quoted: 519 Post(s)
Liked 429 Times
Shimano Down-tube Shifter
Looking for a banded Shimano DT shifter that’s friction-able.
Light action would match the rear derailleur, but not picky.
Thanks.
Thanks.
#4649
Eccentric Old Man
Quoted: 248 Post(s)
Liked 173 Times
Email if interested.
Likes For eom:
#4650
Edumacator
Quoted: 2444 Post(s)
Liked 3,137 Times
https://www.ebay.com/itm/20383032981...8AAOSwDmdh7FzR
Very nice
https://www.ebay.com/itm/32496397798...UAAOSwwbVhyjKZ
Cool rarer ones
https://www.ebay.com/itm/22451828461...kAAOSwNdpgcH6Q
Likes For jdawginsc:
