What do you see here?
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 338 Times
Thank you all for you observations and responses.
Yes, I was also thinking the jockey cage plates were bent. When I noticed that most here agreed, I decided to take the derailleur apart to confirm. Yup. Both bent; the rear plate was the worse of the two.
One washer was missing, but l had a spare. When I put that spare in to see what things looked like the bend was obvious. All fixed now, plus I learned how to dismantle/rebuild a CDA RD - which is good practical knowledge to pass along to my buddy when it comes time for him to put the correct set of jockey wheels in there.
DD
DD
I’ll add that those Bullseye “speed” pulleys are likely considerably narrower than the original Cd’A pulleys, which could throw things out of whack if spaced unevenly. I overhauled my NR derailleur recently and replaced my well-worn Bullseyes with NOS Campagnolo pulleys. The Bullseyes measured 6mm wide; the NR pulleys 10.5mm. Not sure how wide Cd’A pulleys are, but I’ll bet they’re wider than Bullseyes.
