Official Trek FX Thread
#2026
Quoted: 5 Post(s)
Fx question
Hey everyone, first post, anyways...the guy at my LBS was surprised to see a 2021 fx4 disc in-stock for $1079 when i inquired about 2022 fitness bikes. On a whim I put some money down to reserve it (refundable), but I can't seem to figure out if a 2022 fx3 @ $999 or 2021 fx4 @ $1079 is the better buy. Any thoughts? Upgrading from an older entry level fitness bike circa 2013 with 3 x7. Rarely use the front detailer and stay almost exclusively in the middle cog, so 1x seems like a nice option for me.
#2027
Quoted: 36 Post(s)
Liked 89 Times
Hey Brown welcome to the forums! I'm new here too but I'm ALMOST a year old! Guessing by your post cycling is new for you (too) and though you might THINK you don't need more gears or use the front chainring (that's what them there cogs are called) I will bet you will! FWIW, my advice is to get the best bike you can afford but with that said, once you start riding a bit more remember that you got parts and accessories to buy. For example the previous pedal posts...apparently stock pedals are gauche! Huh, who knew? but seriously, you'll need padded shorts...I say NEED....you'll want a new saddle, some biking clothes - I had to buy epileptic yellow for riding on roads - a helmet, water bottles and other stuff....
With all that said, you CAN'T make a bad decision between those two. Good luck and let us know what you decide!
Likes For Chickenwings:
#2028
Quoted: 5 Post(s)
Thanks Chickenwings. I've been riding casually for quite a few years but looking for an upgrade. My current bike has seen better days and I've always wanted a Trek FX because of the durable builds and the flat bar style (I'm a mountain biker at heart). Looking at the spec sheet the biggest difference seems to be the 2021 trek fx4 has the 1x11 whereas the 2022 trek fx3 has the 1x10. I see most of the other components are the same. I noticed the Fx4 has a different rim but not sure if its an improvement or not (Bontrager Affinity vs Bontrager Tubeless Ready). I'm just looking to maximize my dollars at the end of the day. I don't mind paying the extra $80+ dollars for the FX4 but It's hard for me to tell if its really an upgrade or not since its already replaced with newer 2022 models. Does that make sense?
#2029
Quoted: 36 Post(s)
Liked 89 Times
Makes perfect sense! FWIW, I'd get the FX3. As I said I'm new but I ended up with an FX2 AND a 7.4. The 7.4 is an older bike but it has a little better groupset and I sure notice it when I'm riding. The FX3 looks like it's a bit better fit out and for the few dollars, I'd go that way.
I'll break eye contact now and slowly back away to wait for someone with more knowledge and expertise!
#2030
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 312 Times
If they were both the same colour, the FX4 for sure.
#2031
Quoted: 5 Post(s)
The 2021 Fx4 is Dnister Black to Radioactive Red Fade. The Fx3's is either Dnister Black or Light/Dark Blue Fade. They all seem pretty alright, but nothing fantastic color wise.
#2032
Bikes: Trek FX 3 Disc & Trek 5200
I'd go with the FX3. I have it and love it. I know another rider that got the FX4....only because it was the only choice he had during the Virus shortages...and he is not a fan. His FX 4 is probably a 2020 or maybe a 2021....but it is more of a gravel bike than my FX3. His has the one small front ring with the larger cluster on the back while my FX3 is more conventional with two rings up front and 9 on the back. Just my 2 cents.
#2033
Quoted: 5 Post(s)
well, the new 2022 Fx3's are also 1 chainring up front. It's a little smaller at 40T versus 42T on the Fx4 though. It seems bikes are going to 1x more and more.
#2034
Quoted: 5 Post(s)
What is the general consensus on the two tone color schemes? I havent seen any in person but they have the black/red for 2021 and dark blue/light blue for 2022. I generally like single color bikes but trying to keep an open mind.
#2035
As superficial as it seems, I bought my FX 2 because availability and the Satin Lithium Grey made subdued the branding.
And yes, the first thing I knew I had to replace are the pedals. It just looks too slippery for me. One ride on RF Chester and I knew I made the right decision. Can I also gush over how awesome the sqlab grips and innerbarends are? They give me a new hold position that still has full access to brakes and part of the gear shift.
These upgrades are thanks to the posts on bikeforum.
And those two tones do look very interesting. I almost bought a black/blue FX 3 but waited too long and there was no availability.
#2036
1x seems to be the trend and some of them even have gear ranges covering the full range of 2x or 3x. You could go to 99spokes and compare geometry and gearing. There doesn’t seem to be that much difference between a 2021 FX4 and a 2022 FX3.
#2037
Bikes: 2015 Trek FX 7.0 - modified to be better on the road than it was designed to be. Now, 2021 Domane.
Quoted: 23 Post(s)
Liked 10 Times
No 1x for me
There are a number of bike oriented sites out there where you can calculate the differences in gear spreads and ranges with different setups.
I think it's a big time mistake. Enough, for me, anyway, that IF I were to be buying another bike, if that's all Trek had, I'd go to another brand.
#2038
Bikes: 2021 Trek FX Sport 4, ~1996 Mongoose Crossway 4.50
Quoted: 94 Post(s)
Liked 1,311 Times
I did the gear inch calc when I was debating how to replace my 3x7 Mongoose. The FX 3 had just gone to 1x10. On my Mongoose, I mostly used the top 7 gears. I calculated the 1x10 only gave me 5 gears in the same range. But the 1x11 FX Sport 4 gave me 6 gears in that range.
I decided I wouldn’t like the 1x10 gaps. I’m finding the 1x11 just fine. Glad I don’t have to deal with a 2X and the duplicate gearing.
Mark
Mark
#2039
I get that Trek is doing what it's doing, but frankly, for me a 1x anything is a nogo. And the simple reason is that it means the jump from one gear to another can be too much, one way or the other. In fact, there are any number of situations where a two tooth change is one tooth too many for me.
Likes For Jonavin:
#2040
Quoted: 5 Post(s)
I've had 2x on a Trek mountain bike and didn't really like it. I found that the gap between the lower and upper chainring was prime for chain drops or skipping. I ended up just keeping it in my preferred chainring for the trail i was on and just adjusted the rear gears up/down. It seems like whether its 1x, 2x, or even 3x they all have their pros and cons and their isn't one that is the clear winner in all categories.
Likes For Brown3dr:
#2041
Quoted: 23 Post(s)
Liked 10 Times
My first FX was a 3x7. I never used the smallest chainring; and I soon replaced the freewheel with that useless 34tooth (?!) cog with a 13x26 (28?) freewheel. Worked well for me, although I was still wanting in some cases, a 1 tooth jump instead of two. That was a key reason why I wanted a new bike. Since I never ever went off road.... had a slammed stem.... cutdown bars, and other changes, it made no sense to keep up with an FX. My 2x10 Domane is about perfect, although, that notion that a road bike is naturally 'faster' than a hybrid is, for me, a falsehood. It's not. If I had to do it again - buying a different bike for the gearing - it'd be a hybrid. As long as the trannie wasn't that stupid 1x.
#2042
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I tried a couple of 1x drivetrains on some of my bikes, but eventually converted nearly all of them back to 3x gearing. The only bike that remains a 1x is the '70 Peugeot mixte that's sort of a townie/cruiser bike for us. For the type of riding that I do, 2x and 3x just work better. Russ at Path Less Pedaled recently did a video on why he's going back to 2x drivetrains, and I'd say that I went back to multiple chain rings for the same reasons he did.
About half of my 3x bikes have indexed front shifting, and I've found it pretty easy to tune them to get good shifting and minimal chain rub. The other half of my 3x bikes use thumb shifters...friction on the front and indexed on the rear. I think this is generally my favorite configuration -- friction/indexed with thumbies.
#2043
I rode 3x for many years, probably not on a great gearing, but found there to be too many gears for my style. 1x is interesting and simplifies things but doesn’t have the range I want. This 2x9 I have on the FX seems just right. I stay on one cog most of the time but when it gets hilly I can easily switch over. Not complicated but also flexible.
I guess it depends on what you need. If you don’t need that wide of a range, a 1x will do.
#2044
Quoted: 5 Post(s)
I still haven't decided if im buying the 2021 fx4 or not. I plan on taking it for a test ride either today or tomorrow and really getting a feel for it before any decision is made. I'm planning on being very picky since this is a big purchase for me. Part of me thinks i'd be totally fine with a 3x7 (or 8) but the higher spec'd bikes just don't use those anymore.
#2045
Quoted: 23 Post(s)
Liked 10 Times
Chasing riders away from FX?
#2046
Quoted: 5 Post(s)
Test ride went alright. I tested the '21 FX4 and a '22 FX2. I wasn't a huge fan of the 1x drivetrain on the fx4. It had a lot of gears I wasn't going to be using on the climbing end. It also had this weird sensation when i would get up to speed, stop pedaling, and the rear derailleur would buckle and you could feel it move. Probably not a big deal but found it sort of odd. The '22 FX2 was smooth and rode similarly to the FX4, but maybe a little less comfortable (seat was nicer on the 4). I couldn't really tell much difference between the carbon fork and aluminum when going over rough roads either. Long story short, I didn't end up getting the Fx4 or Fx2 at this point, and plan on testing more bikes.
#2047
Likes For Jonavin:
#2048
Quoted: 5 Post(s)
Yeah maybe i wasn't paying close enough attention, needing to pay attention to my surroundings and all that fun stuff, but both seemed fairly good over bumps. Certainly better than my current bike. I'm not ruling out an FX but didn't feel so convinced that I was willing to drop $1000+ on the spot either. Its crazy because I inquired about the FX3 and the shop guy said he didn't show any coming in until like August. I'm guessing I could shop around and find one but bike availability still seems like an issue in some cases.
#2049
Yeah, like I said earlier, I was looking at an Fx3 but didn’t buy it because of availability. Also wasn’t sure about the 1x. I don’t regret buying the FX2 and I quite like the 2x9 drivetrain. The only thing I may wish I had was a carbon fork for less vibrations, but the new grips are helping.
#2050
Quoted: 23 Post(s)
Liked 10 Times
Change individual cogs if you need to
On the other hand, there are a number of different whole cassettes out there with different cogs for different riders. You ought to be able to source one with better ratios for the kind of riding you do.
My point: The cogs in the cassette; shouldn't be the defining criteria for the bike. [same with the seat, too ;-)) ]
