Ruined Cinelli Stem ??
I think I know why it was done - but sad. Seems like a rare stem too.
Quoted: 4533 Post(s)
Liked 6,439 Times
Yep, bummer but those are POS when the wedge breaks. I would find a lower profile button head bolt and grind it down so it doesn't stick out so much. Maybe even use a small smear of super glue or JB for good measure and probably not ride it too far from home.
Quoted: 3827 Post(s)
Liked 3,377 Times
good candidate for inclusion in bulgie 's gallery of failed and broken components -
https://bulgier.net/pics/bike/Broken
Likes For juvela:
Quoted: 3464 Post(s)
Liked 2,834 Times
I have seen similar “augmented” 1R stems.
desperate moves.
desperate moves.
Quoted: 989 Post(s)
Liked 1,657 Times
I have never used these brazing rods yet, but if your considering filing the hole it might be worth a try...
Randomhead
Liked 3,723 Times
Looks like it's cracking. I had a 1/R break on me, it's really exciting. Actually rode it home though.
Bikes: old ones
Quoted: 26464 Post(s)
Liked 10,420 Times
...when a bicycle component is "rare", a part of me always asks, "Why ?"
Ok, I'm gonna say it: I would never use that stem. I'd also be on the fence about using those bars.
Liked 6,439 Times
These won't tolerate a much bigger bar and I don't think that would break the wedge, seems to me like it might help with keeping the wedge intact.
Too small would more likely be the culprit I think.
Quoted: 964 Post(s)
Liked 1,451 Times
https://youtu.be/CCycms8wVC4
Likes For scarlson:
Phyllo-buster
Quoted: 2299 Post(s)
Liked 2,059 Times
Say goodbye to it. It's fugly and dangerous in it's present condition.
Quoted: 1616 Post(s)
Liked 2,221 Times
I am not convinced that the broken parts of the stem contribute that much to the clamping force. What is critical in this design are the raised parts on both the bar and the stem. I have a few with one having a broken wedge. They all work well for me with the proper lube of the wedge ramp and associated parts. My favorite is the XA in terms of appearance. The 1A is just plain practical.
I am willing to be flamed here but I am trying out a 26 bar in a 26.4 1R. So far, so good in the testing. I tried to shim with beer can stock but it was too slippery. I have read all the warnings from all of you over multiple threads so you don't need to repeat how stupid I am to do this nor the consequences. I get it. The bar is about to be replaced anyway with a 65-40.
I have noticed that there is always a gap on the wedge side, even with the correct bar diameter. The diameter of the 1R is around 26.7 on the one stem I measured.
Quoted: 964 Post(s)
Liked 1,451 Times
Yeah, I have a 1R in my bin of curiosities so I know how they go together. I think a crummy weld would be ok because the wedge is under compression. If you could get that rod to work, of course. Its performance is pretty dependent on the base metal you're welding, and we have no idea what exactly that wedge is made of. So, try it if you've got nothing to lose. I don't think it would cause a catastrophic failure of the wedge or loss of control of the bike. More likely, the wedge would crumble on tightening or gradually come loose, requiring more tightenings until it fails.
Liked 2,221 Times
@scarlson - I don't have one of those rods but if it were a possibility.....
The wedge is a casting so it is not as strong as other mfg methods. I think they break because of a bending force or poor installation. The break is often on the perimeter. The size helps address surface contact with the bar and helps with preventing bar rotation.
Quoted: 4251 Post(s)
Liked 2,965 Times
Those stems are well known for the internal wedge cracking and breaking all on their own for poor design, overtightening, lack of proper lube, etc.
verktyg
Quoted: 1037 Post(s)
Liked 1,240 Times
Dental Insurance
This is a Cinelli 1a stem not a 1r but it's an example of what can happen when clamping down on an undersized bar:
BITD, in the early 70's when we were young and dumb, we sold a lot of French bikes at our shop. French 22.0mm stems like Cinelli 1a and 3TTT Record where hard to come by, matching bars too...
Back then there were very few sources for bikies to get good info so everything was learning by trial and error.
We used the 25.0mm or 25.4mm bars alloy that came with the bikes and clamped down on them. Those quality stems broke while clamping down on the undersized bars at least 20% of the time. We quickly learned our lesson after breaking several expensive, hard to get 22.0mm stems.
PSA:
Dental insurance is expensive, uninsured dental costs far more so than the cost of an old bicycle stem!!! Then there's plastic surgery, ortho MDs and worse...
Unlike steel, aluminum has a very low bendability rate. It has in general 1/3rd the strength of steel. That's why all of the recommendations to not try to spread to fit or clamp down on incorrect sized bars. You can only bend aluminum a small amount before excess stress and cracks form.
REMEMBER the call of the Darwin Award Candidates: HEY! WATCH THIS!!!
It never ceases to amaze me that C&V folks will spend hundreds of dollars on components for their bikes and then cheap out on the weakest, most critical elements - the bars and stems???
The Cinelli 1r and XA stems have known design flaws. They're 25 to 40 year old components and should be retired at the slightest sign of a problem. Same with any other stem or bars.
If you acquired them used, you have no idea what a former owner did with them.
verktyg
Chas. ;-)
Chas. ;-)
Liked 2,965 Times
What is the issue with the 1r stems? I've used several without problems.
My main problem with them is that mine aren't labeled with their clamp diameter and I never thought to mark them myself before putting them in the parts bin.
Liked 6,439 Times
Absolutely, most often now days you have to buy a stem to get a wedge, then you have two useless stems if/when that wedge crumbles.
I recently and reluctantly bought one of these as it was Merckx panto, its wedge was cracked. I found a stem with a good wedge on here for a good price and then found another good wedge on efbay for an ok price as well.
So now, I have two complete stems with good wedges that I never plan to rely on despite being heavily invested.
These are POS design and material of the wedge in my mind and I'm going to research smoothing all the sharp edges on the wedge for stress relief. Also seems to me that one could add an abrasive layer to the grooved side of the wedge to lessen the torque needed, possibly reinforce by epoxying it and keep it from cracking.
Likes For merziac:
verktyg
Liked 1,240 Times
Broken Cinelli 1R and XA Stems
Cinelli stem - safe?
What I suggested in my post above was stems and or bars with any kind of problem should be taken out of service or better yet discarded so that some unsuspecting soul in the future couldn't put them back to use...
That very small cross section of metal is all that keeps the bars and stem connected!
The human skull is like a cantaloupe - think about it...
verktyg
Chas. ;-)
Chas. ;-)
Liked 2,221 Times
@verktyg - I do appreciate the your note. I have not seen the 1R break. The 1A break with an under sized bar is not surprising at all. I would also expect the XA to break in a similar way with an undersized bar.
Are the recorded breaks of the XA due to undersized bars?
verktyg
Liked 1,240 Times
The 1r stems were introduced in 1973 so there are some that are almost 50 years old out there!
In 1978 the logo on the plastic plate switched to the "winged C".
Here's a breakdown of the 1r wedge and parts... a picture is worth....
Cinelli Time Line up into the early 80's. No mention of the XA stems. Scroll to the bottom of the page for info on stems.
Velo-Retro: Cinelli Timeline
The XA stems probably broke in the same manner in the 1a stems - primarily from clamping down on an undersized bar.
Opening a bar clamp to fit a larger bar whether it was used with an undersize bar or to fit a 26mm stem to a 26.4mm bar is asking for trouble. If the stem doesn't crack or break during assembly, there's no telling when it could fail catastrophically!
Here's a 26mm 3TTT stem that was probably clamped down on an undersize bar. This is another place where this style of stem can fail.
So... my advice is to thoroughly inspect any older stem and bars before installing them and to periodically check them too. Any bars or stem with any sign of damage should not be used.
Old saying: "Don't be so cheap, you wont be so rich!"
verktyg
Chas. ;-)
Chas. ;-)
Quoted: 964 Post(s)
Liked 1,451 Times
Forgive my ignorance, but:
Does anyone sell replacement wedges for these? Is there a lot of demand?
How many do you think I could sell, just on bikeforums, if I made some?
It wouldn't be too terrible to CNC mill, but my queue is pretty long these days.
Liked 6,439 Times
I'd be all for it and would gladly pay what I paid for a crappy one but can't imagine it would be worth the time.
These stock disposable ones seem to be maybe only a step above pot metal.
Liked 2,221 Times
The wedges are a low cost casting, based on the cross section of the break. Given that they only experience force in compression, it is not a bad choice, just not a great one.
Cinelli1RClamp on Flickr
Although there is a radius from the ramped feature to the curved surface, there is not a more gradual thinning of the curved surface from the ramp feature. This is due to the feature of the opening of the stem where the ramp fits. So the unsupported surface is a long lever that does not have reinforcement. It won't bend like a diving board and breaks.
