Light Bicycle Wheels
#1176
Ordered my second pair. AR56CO3 rims. 3k matte, no holes, and graphene grooved brake track.
Not on their website, but you can ask for them 56mm deep 28mm wide.
Likes For deepakvrao:
#1180
Bikes: '70s Eisentraut, Gary Fisher mtn, Scott carbon road
I have a set of WR50s with about 800 road miles on them, doing well after some early truing and dishing. Crazy stiff if you like that. I should write a review, glad I bought them and lucky it was January not now. I’ve been riding Schwalbe new Pro One 28s and they’re just not tough enough for New Mexico goatheads. Also they weep and lose pressure, but I was tempted because they fit narrower than most 28s. Oh well.
Has anyone measured the width of Continental GP5000 TL 28c on the WR50s? I can just clear a 32mm actual width tire. Ideally they would be 31mm or less.
Any other suggestions welcome for a good tubeless road tire .< 32mm on WR50s.
Cheers, Dan
Cheers, Dan
#1182
Quoted: 20810 Post(s)
Liked 9,456 Times
I don't have WR50s, but the new Schwalbe Pro One Addix TLE have been awesome. They measure out to their nominal width on a 19mm int width rim, so that should give you a good idea of how they'll measure on wider/narrower. They also have them in 28mm and 30mm, which is nice for those looking to maximize their frame/fork clearance.
#1183
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
So, not sure if I can source the famous 'black prince' pads. How many of you use the LB blue pads and are happy with them? I never ride in rain. This is for dry.
Looking at you guadzilla for the inability to source the swisstop.
(Of course, the correct answer is get a disc brake frame, but you know that)
Likes For guadzilla:
#1184
Just picked up yesterday 8/17, ordered 7/17 from the global warehouse to Seattle, WA. Shipped using EMS - air to San Francisco and USPS to the PNW.
AR56 disc (glossy, UD, no logo, no holes), DT 240s EXP hubs, CX-RAY spokes, brass nipples. Spec'd at 1493g +/- 25g, weighed in 1518g (or exactly 1493 + 25, 😂 ).
This is my first set of deep carbon wheels. Looking forward to getting them kitted out and going for a ride!
Likes For dur4ce:
#1185
Fat n slow
Quoted: 3259 Post(s)
Liked 2,086 Times
#1187
Thanks! Islay is a favorite vacation spot. The Botanist is a great gin that I prefer to London dry variants. It definitely gets overshadowed by the local Scotch. Although I am also partial to the whisky...
Yea, was a toss up on whether 24 dime size pieces of carbon or rim tape would weigh more. And obviously serviceability is a bit more difficult. My compromise was to go for the easier tubeless setup, and take the minimal weight delta of brass nipples to hopefully minimize future maintenance needs.
#1188
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
Arrived this week.. Light Bicycle WR50 wheels at 1,354g for the pair as the photos show. They're a custom build with "Flyweight" carbon as I only weigh ~165 lbs and I wanted these wheels to be as crazy-light as possible. I had to have them built in China because I wanted the new DT Swiss 240 Ratchet EXP hubs and those hubs won't be available in the USA for who-knows how long.
For comparison, Bontrager Aeolus XXX 4 are claimed to weigh 1,455g and that's before adding the tubeless rim liner, not to mention that the WR50's have a 25mm internal width and the XXX 4's are only 21mm. After riding the Bontrager Aeolus Pro 3V wheels on my new bike this year, I love the wider rims when setup tubeless. I thought the wide-rim thing was a marketing ploy, but I am now a believer.
As for the finish on the rims, the rims look perfect. Obviously, I ordered the custom 3K Twill carbon which has a glossy clear coat.
I'm waiting on a set of 60mm valve stems to arrive before I put the wheels on the bike with Conti GP5000 TL tires. The wheels came with 70mm valve stems which stick out about a mile above the rim which bothers me
#1189
Looking to buy some new wheels. Don't necessarily need them, but just want to change something on my bike. I'm looking at the 25mm wide 45 mm deep rim brake wheelset from Light Bicycle. I currently run Soul s3.0 wheels I bought from overseas years ago. They are aluminium and weight less than 1500 grams. I actually really love the wheels and they've been awesome. They spin forever and are super smooth. I believe the rear hub is a bitex as I had to remove the freehub recently to clean and relube. The pawls and internals looked almost identical to what I found on the bitex website.
That being said....if I had a new light bicycle wheelset built with bitex hubs, can anyone share their experience? If I go for the dt swiss 350 hubs I start getting into more money than I want to spend.
FYI....I'm 6 foot, 170, don't race, never ride in rain or snow, only ride on good roads, I like to ride fast ( which for me is averaging 18 o 20) and meticulously care for my bike.
#1190
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4401 Post(s)
Liked 3,024 Times
I suspect that the weight difference either way is tiny. But my new LB wheels don't have the spoke holes and I sure do appreciate that I'll never have to worry about a perforation in the rim tape causing flats which has happened to me several times, including on my older LB wheels.
Likes For MinnMan:
#1191
#1192
These wheels sure are popular now. Jus ordered a set of WR45s for my Trek SL 5 from the North America option and looking at a 4 week lead time.
#1193
Coffin Dodger
Quoted: 794 Post(s)
Liked 292 Times
I got to test the LB blue brake pads in the wet the other day, got caught in pop up thunderstorm on a 9% descent. The first squeeze of the brakes was unnerving, as in nonexistent braking, the second squeeze was more a drag squeeze and that was much better. The drag squeeze technique seemed to work best and I could have locked a wheel but didn't want to die testing that.
#1194
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
Have you guys noticed that other than the AR56, most other rims on the LB page are now rated to a max of 60psi for hooked/50psi for tubeless?
That seems absurdly low to me. For a tire with a 28mm WAM, my optimal pressure is in the 80f/85r range for good tarmac - and that kinda dovetails with what Silca's tire pressure calculator says (which, in turn, is based on their extensive reach on total rolling efficiency, ie combining RR and vibration losses). Similarly, for a 32mm WAM tire, my optimal pressure is in the 65-70psi range. All tubeless, FWIW.
They said this was due to a tire blowing off the rim. What wasnt very clear was the circumstances which led to this -was it too narrow a tire (eg, 23 or 25mm mounted on a 25mm ID rim) or something else.
Leaving aside the argument of whether I SHOULD be riding at 65-70psi with 32mms, what do you guys think? LB is being absurdly conservative or would you not take the chance?
#1195
Quoted: 4717 Post(s)
Liked 1,882 Times
Nevermind. I see where you found it.
#1196
Advocatus Diaboli
Quoted: 4750 Post(s)
Liked 1,536 Times
What's a bit odd, is max tire pressure is usually determined in part by the width of the tire you mount.
OTOH, is this really any different than what Enve also has (see below)? Mind you, I never fully understood Enve either for the reasons you mention. However, note that I don't think it's recommended to put a 25mm tire on the WR wheels in the first place, which is the only way you'd have a 28mm WAM. So mounting a 28mm nominal tire on these WR rims would likely be over 30mm WAM, and that's what you should put into the Silca calculator I think.
#1197
Liked 9,456 Times
I think you're referring to the WR rims, right?
#1198
Advocatus Diaboli
Liked 1,536 Times
I thought his 60/50 was Hooked/hookless? Either way, optimal rolling resistance and performance of a tire/road/rider combo isn't driven by whether the rim has hooks or not, right?
#1199
Liked 9,456 Times
Here's not talking about optimal - he's talking about max. For hookless, the limit that he mentions is low. For hooked, it's exceptionally low.
#1200
Advocatus Diaboli
Liked 1,536 Times
Sorry, but I think he said his optimal was 80-85, but the max for the LB rim is down at 60/50 or somewhere in that territory. Neither LB or Enve are anywhere close to 80 psi recommended/optimal/max AFAIK for a 28mm tire.
