Fall Bike Parts purge: C&V, Modern, and all sorts of stuff in between.
N+1
Bikes: A few
Liked 5 Times
This has been over a week long project, but for now it is mostly done. I am sure I will find some other parts and end up adding them. Everything should be listed with a correct picture (if not please let me know). I will ship at buyers expense. Some of the bigger items I will have to track down boxes so if you ask for a quote it might take a few days. If you do ask for a shipping quote please include a zip code.
Tires/Wheels:
Continental Ultra Sport Kevlar (folding bead), 700x23 road tires $30 pair
https://c2.staticflickr.com/6/5827/2...a1299a06_b.jpg
Rivendell Fatty Rumpkin 650B tires (584x41.5mm) wire bead, brand new $40 pair
https://c1.staticflickr.com/1/587/22...dca905da_b.jpg
Kenda Nevegal 29x2.2" folding bead mountain bike tires, barely used $40 pair
https://c2.staticflickr.com/6/5767/2...2a9263f3_b.jpg
Inertia w/Armour Punture Shield 700x23 black and yellow wire bead tires. These might have been a stock tire on a new bike (Felt?). $20 pair
https://c1.staticflickr.com/1/678/22...ce7b5300_b.jpg
Brand new Michelin Dynamic wire bead 700x28mm road tires $25 pair
https://c2.staticflickr.com/6/5663/2...35aba2a0_b.jpg
Stan's No Tubes ZTR Iron Cross disc only cross wheel set. Wheels are 24h/28h 100/135mm spacing. They have TRP 160mm rotors, Stan's rim strip, and are set up tubeless with a set of Stan's Raven 700x35 tires. They were my spare set for my cross bike and had one or two rides on dirt roads only. $400
https://c1.staticflickr.com/1/646/22...a5538380_b.jpg
https://c1.staticflickr.com/1/689/22...7203a2bc_b.jpg
700c road/cross wheel set. Hubs are silver and unmarked with a cassette rear spaced at 100 and 135mm. They are 32 hole and laced to Alex DA22 double wall rims. They have tubes and a set of Panaracer Pasela Tour Guard folding bead 700x32mm tires installed on them. $175
https://c1.staticflickr.com/1/685/22...ce2d5964_b.jpg
https://c1.staticflickr.com/1/693/22...8a01d013_b.jpg
Cane Creek V-33 Track Wheelset, 100/120mm spacing. They were only used twice on a Velodrome and I don't get out there enough so I am parting out my Track bike. They are completely ready to ride with tubes, Continental GP4000 700x23 tires, Cane Creek lock ring, and a Soma 16 tooth 1/8" track cog. The rear hub is a fixed/free type and has never had a freewheel installed. $400
https://c2.staticflickr.com/6/5753/2...7ba21a9d_b.jpg
https://c1.staticflickr.com/1/608/22...f7dccdaf_b.jpg
Brakes:
Nashbar Dual Pivot recessed mount brake calipers, 39-59mm reach $30
https://c1.staticflickr.com/1/593/23...41f0eae2_b.jpg
Tetktro R556 long reach dual pivot recessed mount brake calipers, 55-73mm reach $60
https://c1.staticflickr.com/1/587/22...421d15dd_b.jpg
Stems:
Profile Design Hammer Stem 1 1/8" steerer 31.8mm bar clamp size 120mm length $40
https://c2.staticflickr.com/6/5655/2...1b3def21_b.jpg
Deda Newton 1 1/8" threadless stem with Titanium bolts, 31.7mm clamp size 130mm length $40
https://c2.staticflickr.com/6/5796/2...d91f6e65_b.jpg
Cannondale black 1 1/8" threadless stem, 25.4mm clamp, 115mm length $10
https://c1.staticflickr.com/1/748/22...9f03a1de_b.jpg
Ritchey Pro 1 1/8" threadless stem, 26.0mm clamp, 110mm length $20
https://c1.staticflickr.com/1/775/22...aeaefa61_b.jpg
Origin 8 1 1/8" threadless stem, 26.0mm clamp, 120mm length 8 degrees $15
https://c2.staticflickr.com/6/5630/2...11e7dff2_b.jpg
Origin 8 1 1/8" threadless stem, 26.0mm clamp, 110mm length 8 degrees $15
https://c1.staticflickr.com/1/647/23...68ee3884_b.jpg
Ritchey Comp 1 1/8" threadless stem, 26.0mm clamp, 130mm length 6 degrees $20
https://c2.staticflickr.com/6/5827/2...6053bf2f_b.jpg
Cinelli Neo 1 1/8" threadless stem, 26.0mm clamp, 130mm length $30
https://c1.staticflickr.com/1/743/22...15bbb852_b.jpg
FSA OS170 1 1/8" threadless stem, 31.8mm clamp, 130mm length 6 degrees $25
https://c1.staticflickr.com/1/607/23...025db26e_b.jpg
Ritchey WCS 1 1/8" threadless stem, 26.0mm clamp, 140mm length 6 degrees $25
https://c1.staticflickr.com/1/582/22...345af4cd_b.jpg
Silver Cannondale 1 1/8" threadless stem, 25.4mm clamp, 130mm length 8 degrees $10
https://c2.staticflickr.com/6/5715/2...2e11ed5f_b.jpg
Unknown black 1 1/8" threadless stem, 26.0mm clamp, 100mm length 10 degrees $10
https://c2.staticflickr.com/6/5721/2...85865b31_b.jpg
Profile 1 1/8" threadless stem, 26.0mm clamp, 90mm length 0 degrees $10
https://c1.staticflickr.com/1/622/22...3d38702c_b.jpg
System 2 quill steel stem 22.2mm quill insertion size, 26.0 mm blame and 100mm length $10
https://c2.staticflickr.com/6/5822/2...11e017d4_b.jpg
Cranks and Chainrings:
TA Cyclotouriste 5 pin crankset with new 46t and 30t chainrings 175mm arms, crank bolts, and TA dust caps $200 (two pictures)
https://c2.staticflickr.com/6/5687/2...88a7d05a_b.jpg
https://c2.staticflickr.com/6/5817/2...4e9842da_b.jpg
T.A. Cyclouriste 5 Pin crank arms with chainring bolts, 185mm arms, 9/16x20 pedal threads $100
https://c2.staticflickr.com/6/5727/2...7407acc0_b.jpg
Silver SRAM Rival 53/39t road double with GXP bottom bracket. Arms are 175mm in length and it includes your choice of English or Italian threaded GXP bottom bracket. $100
https://c2.staticflickr.com/6/5737/2...51c368d9_b.jpg
Truvativ/SRAM GXP bottom bracket. I have two English threaded and one Italian threaded $20 each
https://c1.staticflickr.com/1/620/23...d291e25f_b.jpg
Sugino vintage Mighty Competition Track crank set, date code on arms is November 1983, arms are 165mm length, 9/16x20 pedal threads, 144 mm BCD, and it has a Sugino Mighty Competition 49 tooth 1/8" Chainring $150
https://c1.staticflickr.com/1/628/22...fc8734f6_b.jpg
https://c1.staticflickr.com/1/566/23...d65061d9_b.jpg
Black Sugino Mighty Competition 54 tooth 3/32" road chainring, 144mm BCD New $30
https://c2.staticflickr.com/6/5773/2...294cc0db_b.jpg
Sugino Mighty Competition 49 tooth 1/8" track chainring, 144mm BCD barely used $50
https://c1.staticflickr.com/1/596/23...2f15778c_b.jpg
Campagnolo Super Record 48 tooth 3/32" road chainring, 144mm BCD barely used $30
https://c2.staticflickr.com/6/5777/2...4657d52a_b.jpg
Campagnolo Nuovo Record 48 tooth 3/32" road chainring, 144mm BCD barely used $30
https://c1.staticflickr.com/1/710/23...180f922b_b.jpg
unknown brand Drillium 52 tooth 3/32" road chainring, 144mm BCD New $20
https://c1.staticflickr.com/1/620/22...b1184c3c_b.jpg
unknown brand silver 50 tooth 3/32" road chainring, 144mm BCD New $15
https://c2.staticflickr.com/6/5771/2...f6fdecca_b.jpg
unknown brand silver 51 tooth 3/32" road chainring, 144mm BCD New $15
https://c1.staticflickr.com/1/593/22...db106df2_b.jpg
T.A. Criterium 47 tooth inner chainring New $20
https://c1.staticflickr.com/1/772/23...53cfc6c7_b.jpg
T.A. Criterium 50/44 tooth double chainrings with bolts New $40
https://c2.staticflickr.com/6/5707/2...4d400ba7_b.jpg
T.A. Cyclouriste 5 Pin 52/40 tooth chainrings with bolts $30
https://c1.staticflickr.com/1/720/22...d7ccf873_b.jpg
T.A. Cyclouriste 5 Pin 46 tooth inner chainring $20
https://c2.staticflickr.com/6/5756/2...9c9eb05e_b.jpg
T.A. Cyclouriste 5 Pin 32 tooth inner chainring $25
https://c1.staticflickr.com/1/691/22...0a863197_b.jpg
Shimano Deore crank arms, model FC-MT60, 175mm arms, 110/74mm BCD $45
https://c2.staticflickr.com/6/5798/2...7c87dbb1_o.jpg
NOS Stronglight model 99 chainrings, 86mm BCD, 42t $30
https://c2.staticflickr.com/6/5788/2...6e64c007_o.jpg
T.A. Bottom Bracket, all new Grade 25 1/4" balls, 1.370x24 threading (English), 68mm shell width and a 118mm spindle and includes unmarked crank bolts (15mm) $40
https://c2.staticflickr.com/6/5821/2...0bcba562_b.jpg
Campagnolo Chorus/Croce d' aune Bottom bracket, 1.370x24 threading (English), 68mm shell width and a 111mm spindle and includes unmarked crank bolts (14mm) $60
https://c2.staticflickr.com/6/5675/2...ddc7e951_b.jpg
Saddles:
Brooks Swallow copy saddle $70
https://c1.staticflickr.com/1/773/23...db4fa5ab_b.jpg
Selle San Marco Regal TI rails white barely used $80
https://c2.staticflickr.com/6/5833/2...24bc35e3_b.jpg
https://c1.staticflickr.com/1/666/23...d36f4726_b.jpg
Selle San Marco Regal Ti rails white with red and blue stitching $80
https://c2.staticflickr.com/6/5748/2...de4dfcc8_b.jpg
https://c2.staticflickr.com/6/5762/2...0d323bdf_b.jpg
Thomson Black 27.0 mm seat post 330mm length $60
https://c2.staticflickr.com/6/5765/2...446ea282_b.jpg
Avenir 200 saddle $15
https://c1.staticflickr.com/1/746/22...2987de90_b.jpg
Bontrager Race saddle $30
https://c2.staticflickr.com/6/5733/2...fbd75784_b.jpg
Pyramid Cloud 9 saddle $10
https://c1.staticflickr.com/1/591/22...1c54686e_b.jpg
Seat posts:
Kalin 26.0mm 350mm long black, $10
https://c1.staticflickr.com/1/730/22...121864ff_o.jpg
Ritchey 30.9 seatpost 350mm length $20
https://c2.staticflickr.com/6/5743/2...0f751a66_o.jpg
Zoom suspension seatpost, 27.2mm $10
https://c1.staticflickr.com/1/695/22...495e2461_o.jpg
Silver Kalin 25.4mm seat post 350 mm length $10
https://c2.staticflickr.com/6/5732/2...b3c68fb0_b.jpg
Giant Carbon Aero 27.2 mm seat post 250mm missing lower saddle rail clamp piece $10
https://c2.staticflickr.com/6/5768/2...bf7d957f_b.jpg
Bars:
Mavic 130mm stem sanded down to work in a French steerer tube, Nitto Noodle bars 44cm, Tektro Aero brake levers, Cinelli black bar tape, and Velox bar plugs with brake housing already routed $80
https://c2.staticflickr.com/6/5756/2...c390c894_b.jpg
https://c1.staticflickr.com/1/739/23...045b4de5_b.jpg
Salsa Pro Road drop bars, 26.0mm clamp size 46cm width $25
https://c1.staticflickr.com/1/617/22...5025ec4f_b.jpg
Steel oversized clamp track drop bars with grips. Bar is 31.8mm clamp size and is 41cm width $20
https://c2.staticflickr.com/6/5625/2...36047979_o.jpg
Modolo X-Tenos road bar with single cable grooves, 42cm wide, 26.0mm clamp $20
https://c1.staticflickr.com/1/777/23...ea65ce30_o.jpg
Deda Pista bars with Bontrager bar tape 31.7mm clamp 40cm width $50
https://c1.staticflickr.com/1/733/23...2da60752_b.jpg
Cinelli Ergo Drop bars dual grooves, 26.0mm clamp and 44cm width $25
https://c2.staticflickr.com/6/5731/2...99cc7310_b.jpg
Profile single groove drop bars, 26.0mm clamp and 41cm width $10
https://c1.staticflickr.com/1/627/22626050618_021260239f_b.jpg
Sakae/SR World Custom drop bars, 25.4mm clamp 38cm width $15
https://c1.staticflickr.com/1/670/23...fba3b2c6_b.jpg
Unbranded Silver Randonneur type bend drop bars, 25.4mm clamp, 39cm width $10
https://c2.staticflickr.com/6/5722/2...171a763f_b.jpg
Friko Super Touring drop bars, 25.0mm clamp (French size!), 40cm width $5
https://c2.staticflickr.com/6/5651/2...54260d84_b.jpg
Sakae/SR Randnner Road Champion drop bars, these have a slight rise and the drops are flared, a very comfortable vintage bar for a Randonneur or Touring bike. 25.4mm clamp size and 40cm width $25
https://c1.staticflickr.com/1/586/23...67e0b172_b.jpg
Truvativ Team Aluminum riser bar 35mm rise 31.8mm clamp, they have been cut down to 540mm width $10
https://c2.staticflickr.com/6/5830/2...5c05f37d_b.jpg
Other brake stuff:
Cane Creek SCR-5 aero brake levers BNIP $30
https://c2.staticflickr.com/6/5683/2...8cde34bd_b.jpg
Cane Creek non-aero brake hoods black available or brown SOLD $10 set
https://c2.staticflickr.com/6/5678/2...3bb16c3a_b.jpg
SRAM Red, Force, Rival 10 speed doubletap hoods in RED $5
https://c1.staticflickr.com/1/735/22...855d7a59_b.jpg
Weinmann non-aero brake levers with q/r built into the lever, no hoods $10
https://c1.staticflickr.com/1/610/22...c57a5858_b.jpg
Dia Compe 287V aero brake levers for use with V-brakes/mechanical disc brakes. Barely used and complete $30
https://c1.staticflickr.com/1/727/22...cfcbfeb6_o.jpg
Specialized cross top brake levers, 31.8mm clamp size, $15
https://c1.staticflickr.com/1/732/22...bd3fced5_b.jpg
Primo V-Grip BNIP $10 https://c1.staticflickr.com/1/605/22...cdedd68c_b.jpg
Shimano center lock Disc Rotor, model SM-RT64, 160mm BNIB $15 https://c1.staticflickr.com/1/740/23044329095_966727370c_b.jpg
Used Shimano Center lock Rotor models SM-RT53M 180mm with lockring $10
https://c2.staticflickr.com/6/5763/2...589d6ab1_b.jpg
Used Shimano Center lock Rotor models SM-RT53M 160mm with lockring $10
https://c2.staticflickr.com/6/5647/2...158edd78_b.jpg
Pedals:
MKS Steel toe clips size XL with all mounting hardware $10
https://c1.staticflickr.com/1/623/22...586e2d23_b.jpg
Forks:
Electra Ticino chrome low trail fork with brake bosses. It is a made of 760 triple butted steel tubing. It is a 1" threaded steerer tube that is 300mm long with 100mm of thread. Crown race size is 26.4mm. The rake is 80mm and the axle to crown measurement is 395mm. $100
https://c1.staticflickr.com/1/566/23044351855_3a0f2bb463_b.jpg
Shifty bits:
Shimano SL-S434 6 speed indexed/friction down tube shifters $15
https://c1.staticflickr.com/1/598/22...015e7e59_b.jpg
Shimano SL-BS77 Dura Ace 9 speed bar end shifters, switchable between friction and indexed shifting on the right/rear lever. They were spray bombed black by a previous owner and that finish is flaking off, but they work perfectly. $60
https://c2.staticflickr.com/6/5727/2...c1109d93_b.jpg
Shimano 400EX rear derailleur, model RD-A400 $15
https://c2.staticflickr.com/6/5801/2...b3c8bc04_b.jpg
Black Shimano 105 rear derailleur, model RD-5501, short cage, finish is not the best but works perfectly $20
https://c2.staticflickr.com/6/5732/2...d6a072f9_b.jpg
Suntour XCE Front derailleur, bottom pull, 28.6mm clamp, new $15
https://c1.staticflickr.com/1/713/23...34627ef8_o.jpg
SRAM X4 Trigger shifters, 8 speed. Rear shifter is only compatible with a 1:1 SRAM NEW $20
https://c2.staticflickr.com/6/5792/2...01030675_o.jpg
Shimano Deore XT, model FD-M735 front derailleur 28.6mm clamp and bottom pull $25
https://c1.staticflickr.com/1/716/22...7f600d6b_b.jpg
Tires/Wheels:
Brakes:
Stems:
Saddles:
Seat posts:
Bars:
Other brake stuff:
Pedals:
Forks:
Shifty bits:
Bikes: yes
Quoted: 512 Post(s)
Liked 411 Times
NOS Stronglight model 99 chainrings, 86mm BCD, two 42t rings available. $30 each or both for $50
I'll take one of these chainrings
Aspiring curmudgeon
Bikes: Guerciotti, Serotta, Gaulzetti
Quoted: 111 Post(s)
Liked 26 Times
Any idea on the drop of the steel track bars and the Dedas?
"Party on comrades" -- Lenin, probably
pm sent re DA 7400 28.6 fd.
Dang. If I weren't going to Maui next month I'd have a list for you.
Extraordinary Magnitude
Quoted: 2609 Post(s)
Liked 1,704 Times
My zip is 53186
Thanks!
Commence to jigglin’ huh?!?!
Quoted: 17 Post(s)
I am interested in the pair of Continental Gatorskin 27x11/4 (32-630).
Can you please give me a shipping cost to zip 94303 ?
Quoted: 17 Post(s)
I will take the following
- continental gatorskins 27x1 1/4(32-630).
- Suntour XCE FD
- Cane Creek non-aero brake hoods set in Brown
Shipping is to 94303
As I do not have enough #posts , can not PM.
Thanks
- Suntour XCE FD
Thanks
Good on You! I had these bookmarked, but did not want to pull the trigger until I got the wheels to mount them on!
Oh well, I snooze I lose! Enjoy. The wheels I picked up had one of these, look OK for value tubulars.
