Narhay's 1975 Raleigh International
The original brake bolt mount Blackburn rack, and it's plethora of knock-offs from Vetta and others, would be both period correct and useful.
I've had one and off of my Internat'l for decades.
Look in your local co-op, old shops and on the usual auction site for one.
-Bandera
-Bandera
This one doesn't look like it would be out of place...
https://www.mec.ca/en/product/5036-5...stay-Rear-Rack
Looks like it comes w/ coated P-clamps: Good to Go.
-Bandera
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 166 Post(s)
Liked 102 Times
I would hold out for an old Blackburn that attaches to the rear brake bolt. They're still fairly common and usually not not expensive.
I have finally begun working on the bike. Sun rims M13II onto high flange record hub. I've used this combination a couple times before and I've liked it. Classic, plain silver rim, sapim db spokes and what I believe
to be the finest vintage hubs in existence. You can see evidence of the sources of my lack of time in the background, x2.
Sun race 6 and 7 speed freewheels. The 6 speed needs 31mm spacing, the 7 needs almost 36mm. I may have to harvest some thinner locknuts and spacers from another campy hub to make the 7 speed freewheel fit as mine has a wide, single piece locknut, thin keyed washer and cone on the non drive side. Not much for adjusting axle spacing.
Bikes: 1974 Copper Raleigh International, 1975 Olive Green Raleigh Grand Prix, 1974 Raleigh Europa Custom
Quoted: 104 Post(s)
I am intending on adding 45mm fenders to this bike. I was about to pull the trigger on a set of Velo Orange 45mm silver fenders until two unknown options presented themselves. I have a Raleigh Competition as my go-fast bike with no fenders, 28mm tires, etc. so this one will be more along the lines of a comfortable, dry ride.
Option 1 - Origin 8 classic silver hammered fenders. These are basically copies of Velo Orange hammered fenders but at $52 instead of $68. I have the 35mm Velo Orange version on my Peugeot PX-10 and liked them once I got the rattles down to an acceptable level.
Option 2 - Handsome Cycles copper fenders at $70. These would certainly match the bike but I have to wonder if it would be too much matchy matchy. What are your thoughts?
Unless they're exactly the same colour, the copper guards would look slightly out in my opinion.
I have started the teardown. What manner of blasphemy is this (unmarked 170mm non driveside crank arm) and do any of you have a 172.5 Nuovo Record non drive side crank arm? I was just about ready to unclench my nether regions and forgive not having the Campagnolo shield on the lowly crank arm but this mismatched length won't do at all.
Apparently only one side of the bottom bracket got repacked.
first time looking at this thread- and WOW what a color on that frame! also you are good at photography.
I'm just taking quick photos on my phone. My real camera is at work because I tend to use it more frequently there as I am usually out and about.
Quoted: 355 Post(s)
Liked 345 Times
Still worth doing unless you stumble on an inexpensive upgrade like a Phil Woods BB at a great price.
There's a bike swap meet near me on Saturday and I can look for a fixed (I'm assuming British 1.370 x 24) thick wall (rifled) cup, and a 68-SS Spindle. I know a fellow with a number of NOS cups, I'll check with him to see what he has.
If you can, measure the spindle length to verify, should be 113.5mm (54 bet. bearing race shoulders, 28 on left, 31.5 on right). That would be the "new style" Record with gray finish. There is also the Nuovo Record gray finish that is 49mm Bet. race shoulders, 30mm left, 33.5mm right, total 112.5, and then the Super Record spindle with silver reflective finish (which looks like yours) at 52mm bet. race shoulders, 30mm left, 33.5mm right, total 115.5mm.
Would suggest also a new set of bearings. Measure the size of the bearings to check if you have 1/4" or 3/16" but it looks like you have the 1/4" size. You want the adjustable cup too?
As for the cranks, some quick research on ebay suggests the non-drive crank arm is an Ambrosio (from lack of imprinted make logo, pedal engraving, and "strada 170" engravement.
Here's a couple of current Ebay listing with them:
VGC Colnago Ambrosio Special/Strada crankset - 170 mm - Laser printed | eBay
Pics 1-4 show the left side crank.
Ambrosio Colnago Pantograph Left Crank Arm Vintage Racing Bicycle 175mm Strada | eBay
a 175mm single Ambrosio crank, similar in appearance:
Pics 5-6.
Might be hard to find a 172.5mm left side crank alone. Would you consider changing to a Campagnolo NR 170mm crankset since they are much more common?
Pics 5-6.
Quoted: 355 Post(s)
Liked 345 Times
This might also be of interest, no affiliation.
Campagnolo Nuovo Record Bottom Bracket Fixed Cup English Thread Classic Road | eBay
Vintage Campagnolo Record Bottom Bracket Fixed Cup (English) | eBay
Thank you for the sleuthing and the ID on the Ambrosio arm. I took my calipers out and measured the spindle...114.5mm 🤔.
I am seeing some new production campagnolo veloce 115mm sealed bottom bracket units that are purported to work with pre-1995 record units. Does this include the pre-1978 record like mine?
I may have to find a pair of more common 170mm crank arms and call it a day. I suppose my build will be delayed just a bit but it's already been 5 months to get to this point so what's another little while longer?
Quoted: 1834 Post(s)
Liked 3,417 Times
..speaking of which.... any little cracks in the webs where the R/H crank arm joins the spider?
A shame that the axle and fixed cup were trashed. I can only assume that someone thought it was too much trouble to clean the old grease out and clean things up??
Steve in Peoria
Might want to try sanding out that gouge in the R/H crank arm left by the front derailleur too. Those stress risers are just trouble waiting to happen.
Steve in Peoria
Steve in Peoria
No cracks at the arm spider interface. I'll keep looking for a suitable replacement arm or pair.
Semper Fi
Quoted: 1173 Post(s)
Liked 358 Times
I have a clean 81 spider and nds arm, 172.5 for both of them. They have their dust caps and the chain ring bolts included. Any suggestions? I'm big, cheap and easy. And I can be had.....
I have gone to 170 mm crank arms, this one is now unused.
Pictures in just a bit.
Bill
Bill
Semper Fi, USMC, 1975-1977
Quoted: 3464 Post(s)
Liked 2,834 Times
Ever had your legs measured? hardly anyone's are exactly the same, so you might be lucky and the mismatch is perfect…
Nasty Bottom bracket, why I tear down every bike I buy right upon receipt, no matter how beautiful it is upon purchase.
Note- there are a LOT of bad / shady mechanics out there in vintage bike land.
Quoted: 95 Post(s)
Maybe it's just me, but I've had good luck swapping over to cartridge BBs. I know they aren't period correct and I know they are disposable units, unless you ride a ton in the rain, I don't see replacing them that often.
Also, I saw the bike with the wheels that came on it, and thought to myself "well, take off the stickers and they are probably fine"...till I saw the silver.
Bill
Bill
This would leave me with an 'extra' perfectly serviceable NDS/left 172.5 crank. Perhaps we could all work out something out? PM me if you like.
The record cranks on my Masi are 172.5mm, and I've been thinking of replacing them since the drive side spider has the classic crack in the web. It's not really been a priority for me as the old Masi is basically a wall hanger that I keep for nostalgia.
I'm not above overt flattery to make this happen.
Semper Fi
Liked 358 Times
PMs received, settled and mailing the parts this weekend. Pop the corks on the champagne/beer cans popped open, etc. I'm out and just watching now, happily.
Bill
Bill
I do have to say members like you are the reason I came here and never left, plus the bikes are ok too, I guess. If you have a molteni orange colnago in 60cm you can put that in the bubble mailer too. 😀
Bikes: Too many, but sometimes not enough.
Quoted: 225 Post(s)
Liked 18 Times
The single lip seals are the one weak point of the cartridge bearing bottom brackets like Phil. Probably not an issue in dry climates, but I wouldn't use that kind of seal in wet conditions. I think Shimano / Tange have a real edge in their bottom brackets, as the bearings are integral to the spindle, rather than discrete bearing units. This allows more and larger balls, while keeping the spindle beefy. Unfortunately, they aren't available in ISO tapers, and I'm not real comfortable mounting ISO cranks where they're only halfway on a JIS taper. (Probably safe, but I can't imagine it does much good for the socket in the crank.)
