A frightening look inside of a BMC Road Machine RM01
#126
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
Qull stems rely on just one bolt to hold the bars in place (attached to the fork - i.e. steering column). If it snaps, you instantly loose control of the bike. Threadless forks have at least two bolts holding the stem to the fork - probability of 2 bolts snapping at the same time is very, very low. I'd stay away from quill stems if at all possible (for 1" standard you can still find threadless forks and headsets, though they are not as common).
#127
Quoted: 4459 Post(s)
Liked 1,592 Times
Steel forks may not be sitting in every shop but in the US there must be several hundred framebuilders who can crank out exactly what you want for not much more than a high end carbon fork. (And you get to choose the type, crown, geometry, braze-ons and paint or chrome. And it will be compatible with your favorite headset. Threadless or quill. Any carbon forks offer so many choices?
#128
Quoted: 70 Post(s)
What I actually see is a gentleman performing destructive visual inspections and then noodling about without any numbers or data.
I did find the different layup techniques in the differently aged frames to be interesting. I think it is clear that a process without voids and etc. can deliver a lighter frame. We don't know if the lighter frame with fewer voids and etc. is better than the BMC frame because no measurements were made and no comparisons were performed in the videos that I watched. We do know that at least some carbon fiber parts that work well are not aesthetically pleasing when cut apart.
The BMC frame, with all of its imperfections seems to have done a perfectly fine and safe job of carrying its riders about. I learned that that fairly mediocre carbon frames work really well, and that the aesthetics of disassembled carbon parts has little bearing on their real world performance.
#129
Liked 1,592 Times
I would expect said expert to measure the deflection, yield, and other characteristics of the frame and then compare those vs. a known good frame and then discuss how visually detectable defects in the frame lead to the deltas.
It may very well be that the ugliest parts of those frames are in effectively unimportant areas. But why put loose chunks of non-load bearing fiber in an area it isn't needed? Maybe it just makes things easier to lay up, or maybe they shouldn't be hanging in space like that, it is hard to tell.
What isn't so hard to tell is when you cut up a bike that doesn't have any extra junk anywhere. There isn't any question about whether the stuff you see is merely extra or misplaced, because nothing is extra or misplaced.
The BMC internals make the case for a haphazard build process OR unnecessary extra material, neither of which are hallmarks of the highest level of bicycle technology. Which would be okey-dokey in an entry level Giant, but maybe not in an $8000 bike. These are the McClaren's of bikes, not Deng Fu ebay fodder.
#130
Thread Killer
Quoted: 3166 Post(s)
Liked 1,724 Times
As for the aesthetics having little bearing on real world performance, he does concede that while matte white looks great new, it’s hard to keep clean and so *might* not be a great paint finish for a bike. I guess you have to know both how matte paint works and have the contextual understanding that clean is better than dirty in order to make sense of his point.
So, if your point is that his vids aren’t for everyone, yeah, I can see where you’re coming from there.
#131
Quoted: 1096 Post(s)
I dunno. He's just a guy who knows a thing or two about carbon fiber and manufacturing; he's not a representative of a standards institute, is he? Besides, if it weren't for the freak show nature of the video - if it were entirely scientific - it probably wouldn't get as many views.
#132
So you can control your level of QC in terms of increasing it, but you can't control how lower quality manifests in the product.
Another way of looking at this: If you can't control every process, you can't have expectations of quality for those uncontrolled processes. Not having any expectations, you can just buy insurance and hope the number of failures is low enough to not affect your bottom line.
To my eyes, the seat cluster looks like the tooling design does not effectively match the frame design, and the layup ends up a random mess of unconnected layers.
#133
Thread Killer
Liked 1,724 Times
@Kontact, it’s hopeless...probably a case of Don’t Feed the Trolls.
#136
Quoted: 18883 Post(s)
Liked 10,646 Times
I've wrecked exactly the same number of carbon and steel bikes in my lifetime.
#137
Liked 1,592 Times
You can't counteract decreased QC on the manufacturing level, because you don't have any expectations of where the problems will be. They are random in a way that a too wide or too narrow part are not.
#138
Quoted: 4819 Post(s)
Liked 3,946 Times
One of the aspects of quill stems I love is that I can very safely adjust handlebar height out on the road with just a 6mm allen wrench (and I might need a rock). No torque wrench, no headset adjustment, nothing to go wrong at all besides perhaps crooked handlebars and threadess setups have that same issue. A very wide range of acceptable torques.
And, yes, a quill stem can just break in two. I am sure there are those here who have seen this happen. (In my 50 years, I have never heard of a casting failure on any well designed and executed stem that hadn't seen use way beyond the expected.)
Lastly: "Qull stems rely on just one bolt to hold the bars in place (attached to the fork - i.e. steering column). If it snaps, you instantly loose control of the bike." Funny, in the Mechanics Forum you hear of people who cannot budge their stems after removing the bolt completely. Now, I ride with well greased quills and wedges and I still have to sometimes tap the bolt down to free the wedge. So in reality, even if this lightly loaded bolt does break, there is a very good chance that nothing will happen at all.
Ben
#139
Quoted: 1067 Post(s)
Liked 259 Times
I have never been on a ride and decided I needed to change the handlebar height.
I have however wanted to adjust the headset which is much easier on the modern threadless system.
#141
Liked 1,592 Times
Yeah, sort of. Quill stems have the long bolt to the wedge or cone at the bottom and yes, it is key in preventing the stem from turning or lifting out. But it does not need to be especially tight. It never sees outside loads. And they very rarely fail. The bolt at the handlebars can fail but with traditional stems. the handlebars are still captive and just rotates. By contrast, threadless stems have bolts that require torque wrenches. When a one bolt breaks, frequently the others do too. The stem itself and the handlebar clamp have also been known to break. When these things happens, the only things holding the handlebars to the steerer are the brake and derailleur cables.
Ben
Ben
It is okay to like old school stuff, but you are manufacturing "issues" to bolster your preferences.
#142
They may look significantly better, but I'd never buy a Cannondale based on my experience with their reliability. I've been racing a long time and I've seen a lot of defects. Granted, Cannondale puts out far more bikes than BMC, so as a percentage it probably doesn't sound any alarms, but that doesn't make it any less scary.
#143
Liked 1,592 Times
Many common brands have a wide variety of QC issues, and unless you personally experience them you are unlikely to hear a lot about the issues. It is somewhat open secret among Cervelo dealers that they're easy going warranty policy gets used - a lot. Not because the frames are breaking in half, but because of BBs that are too large or internal cables that don't work right.
In 2014 Cervelo recalled the P5 integrated bar system. I worked on the first failure - the screws were threaded into tubular anchors that pulled right out of the carbon when you leaned on the bars. Even a competent bike mechanic or cabinet maker would know better. The bike industry does not operate like aviation or automobiles - plenty of people designing and building bikes are frankly winging it.
Specialized just issued a recall on basic, lower end carbon fork.
#144
That's simply not the case. When you use larger tolerances in a machined part, you know exactly the kind of problems you are going to run into, and can come up with assembly methods to counteract them.
#145
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1269 Post(s)
Liked 1,300 Times
Wait, wasn't the whole point of their oversized BB area to increase stiffness & durability?!?!
#146
There is a saying in manufacturing: "You can't inspect quality in"(meaning 'into the product').
Very obvious, once stated, but not really intuitive.
Looked at from 1000' up, quality control and manufacturing processes are both necessary steps to achieve the targeted goal(s).
There is a mind-set that insists on their separation.
The parts of the thread that haven't been a pissing contest have been quite enjoyable.
Sorry for the O/T musings.
#147
Liked 1,592 Times
#148
Liked 1,592 Times
Im not really going into the debate, but I will just comment that lots of normal bike components does not, Imo, need a lot of QC because they are dimensioned to take a lot of abuse, are built with proven, cheap manufacturing techniques and does not push the weight envelope. Im sure we can find examples of broken quill stem bolts, but from my experience, with normal commuter stuff, they just dont break. Race bike carbon frames on the other hand are tricky to manufacture and does indeed push weight envelope. That, Imo, requires much more vigilant QC and very conservative rejection criteria. BMC however seem to disagree with me on that point and that is why I would never consider a BMC, based on the video in #1.
Vacuum bagged monocoque construction has far too many places for things to go wrong. Mandrel wound tube with die formed carbon lugs has very few.
#149
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
If one person defines "quality" as
and another uses less-flowery language like "low failure rate", why would you be surprised that a thread will go on for pages with no consensus?
#150
Thread Killer
Liked 1,724 Times
The thread has gone on for pages without consensus because people do not have good comprehension skills.
