Reds for water bottles/bidons that don’t make hands sticky
Quoted: 4838 Post(s)
Liked 3,967 Times
Or, be like the pros, They just accept that those bottles are sticky even before they've taken the first drink. You don't hear them complain.
Likes For 79pmooney:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2611 Post(s)
Liked 5,735 Times
If we could only have support cars passing us food and bottles and sticky ones at that.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 229 Post(s)
Liked 319 Times
The reason I moved from only electrolytes to a carb electrolyte mix in my bottles: Road Cycling Academy
Just ordered two Podiums and will give them a go. Thanks for the responses.
FYI, the lids on these have a little diaphragm that is meant to be removed for cleaning.
Likes For Mtracer:
Grupetto Bob
Liked 5,735 Times
I use Podiums and they work well. They have a shutoff. I make sure to keep this closed until I'm about ready to roll. The reason is I typically stick bottles in while the bike is still inside. I lift the bike up on it's back wheel to get out the garage door. While you have to squeeze the Podiums to get "water" out, it will also squirt out a little if it is jarred. If I keep the bottle shutoff closed, then nothing comes out as I bump over thresholds and such while the bike is tipped up.
Quoted: 1117 Post(s)
Liked 1,213 Times
Get a new water bottle that doesn't leak. A water bottle is a water bottle. Choose on the basis of price (free is even better), color and availability the day you decide to buy one.
Is there really a significant difference between any water bottles? Nah.
Quoted: 3251 Post(s)
Liked 2,537 Times
Switch to a Camelback and eliminate the bottles. Or use plain water and products like these. Saltstick even makes a dispenser that goes on your handlebars
https://www.amazon.com/SaltStick-Ele.../dp/B002IY96B0
https://www.amazon.com/Elite-Sportz-...c%2C162&sr=1-2
https://www.amazon.com/SaltStick-143...ct_top?ie=UTF8
Quoted: 4482 Post(s)
Liked 4,955 Times
I have 6 Elite Fly bottles (small and large). They do flow well, but they don't seem to flow only into my mouth. It also sills out of the gap between the bottom of the nozzle and the bottle lid, invariably leaving sticky bottles and fingers, and dried carb drink on my frame. I'm also having a hell of a time keeping the inside of the Fly nozzles clean.
CBak Podiums on the other hand are a PITA to clean. I gave up with those in the end for that reason. That and I prefer the high flow rate on the Elites.
Liked 4,955 Times
There is for me. IME they vary a lot in flowrate, ease of cleaning and how much plastic you can taste! Even how well they fit in bottle cages varies. Some nozzle designs are much better than others and there is a fair degree of personal preference. Over the years I’ve used all the common types and definitely have fairly strong preferences.
Likes For PeteHski:
Quoted: 229 Post(s)
Liked 319 Times
In a normal riding position, the air is going to be at the top. So even if a bump caused the valve to open, you’d get air not water.
I’ve never noticed an issue, other than what I described before. I will find a small amount of dried drink on my down tube after rides. I don’t know whether this bounced out of the bottle or more likely just from drops of drink coming off the bottle after I take a drink.
What I never have is any noticeable sticky drink on the bottle or my hands. I use a mix with maltodextrin, and that’s sticky stuff.
Bottles not in active use, like one on the seat tube or in a Jersey pocket, I keep the shutoff valve closed. That seals it tight.
Likes For Mtracer:
Bikes: Shmikes
Quoted: 10188 Post(s)
Liked 5,892 Times
I like a couple of reds crushed up and dissolved in my bidon. Makes the ride go really fast.
Likes For MoAlpha:
Habitual User
Quoted: 5030 Post(s)
Liked 8,228 Times
Habitual User
Liked 8,228 Times
I pulled apart the nozzle on a couple of the Fly bottles that I typically use with carb mix, and was horrified at how they looked inside. I need to find some sort of brush to get in there.
Pennylane Splitter
Bikes: Yes
Quoted: 1826 Post(s)
Liked 1,467 Times
Does anyone know of a bicycle water bottle that has a 'flip-up'- style spout like a coffee mug for an automobile? A spout like that would be awesome for me versus the traditional pull-up/push down spout. And the tops of the mugs usually don't leak (from my experience). If I'm stopped I'll just unscrew the top of a traditional water bottle and drink it like its a glass of water. FWIW: I tried a few of the coffee mugs I have but none fit a water bottle holder, they're all too skinny or too fat.
Over the hill
Quoted: 1002 Post(s)
Liked 1,219 Times
This is exactly why I stopped drinking any type of mix, but when I did I would always ride with one bottle of sports drink and one of plain water, then use the water bottle to squirt away any stickiness I accumulated.
It's like riding a bicycle
Quoted: 511 Post(s)
Liked 646 Times
Plus you can use the water to wash your hands after changing a flat or to rinse a wound from road rash. I used to use bottled drinks but now it's solid food and water. I add salt to the solid food to make sure I get enough electrolytes and no more sticky bike, sticky fingers, and green stuff growing in my bottles. Your water intake varies widely with weather conditions, but your calorie intake doesn't. It makes no sense to combine hydration and calories in the same source.
Klaatu..Verata..Necktie?
Quoted: 10477 Post(s)
Liked 11,995 Times
Likes For genejockey:
Quoted: 9656 Post(s)
Liked 6,366 Times
Grupetto Bob
Liked 5,735 Times
Likes For rsbob:
Liked 3,967 Times
Bottom line, when in the open position, you squeeze it to get fluid out. The squeezing puts pressure on the top to allow fluid out. Strong enough jarring can do the same thing. But for me it was more having full bottles, and the bike tipped up on its back wheel. This causes the water to already be up against the lid. Rather like the position you need it in to drink, tilted up so the water is by the opening.
Habitual User
Liked 8,228 Times
Likes For Eric F:
Clark W. Griswold
Quoted: 4424 Post(s)
Liked 4,069 Times
In terms of bottles for the OP, Camelbak Podium Chill or Ice bottles and nothing else. I have gotten a good number of free bottles over the years and will still pay for Camelbaks and yes there is a difference. I don't get flavors from Camelbaks the water tastes like water every time even if I leave the water in there for a week or two it still tastes good and not like plastic or chemicals and if I do have mix in the water I can rinse it with water and it won't hold onto that flavor and the water tastes like water still. Though usually I will rinse twice (no soap just water) just to make sure. I haven't had any real leaks though on some rare occasions I accidentally partially close it and go to drink water and it sprays out poorly and gets me a little wet but that is rare and I haven't had an open valve bottle leak on me yet in the 11 years I have been using them (one of those bottles until I lost it a year ago was that old and still in constant use with no real changes to the inside with minimal cleaning though I did clean the valves and the threads every so often).
Likes For veganbikes:
Quoted: 511 Post(s)
Liked 646 Times
What you are telling us is that you are not eating properly. You can combine food with salt to get the electrolytes you need and get your hydration from the water. Based on distance and effort, you can estimate your calorie needs and eat enough solid food (salted) to fuel the ride. Based on the temperature, humidity, and your own past experience you can estimate your water and salt requirements. If you have hit the wall you are either not eating enough or are out of shape.
Clark W. Griswold
Liked 4,069 Times
Foolish to consume refined sugars while riding that results in spikes in your blood sugar level. Better to eat dried fruit and nuts where the fiber slows down the absorption in your intestines. The energy drink business rakes in millions in profits but that does mean that anyone other than a pro racer on a tour needs to consume them.
