Advice on getting started
Bikes: 1997 Schwinn Searcher GS, 2007 Dahon Curve D3
Maybe the best piece of advice is to bring your cell phone. You will almost certainly forget something you need.
Remember, when we were kids, we didn't carry any of this jazz, and we did OK, so don't get too stressed out about it. The worst that can happen is you have a nice long walk to think about it.
Quoted: 336 Post(s)
Liked 309 Times
To solve your tube problems, get some rim grommets. Since your rim is drilled for schrader valves, you can use any tube you can beg, borrow, or steal if the need arises.
+1 on the dry run. 10 miles isn't very far, but hills and wind can make it seem that way.
+1 on being visible. Get a rear blinky LED light and either a front blinky white LED light or powerful headlight.
I don't see why riding the wrong way is dangerous. I know it is not recommended, but It increases the closing speed, but it gives you the chance to spot a drunk or someone who is "driving while intexticated" before they're on you. It is a mixed thing.
Riding the wrong way is dangerous because, being against the law, NO ONE in a car expects to see you there. The increased closure rate you refer to is deadly under the wrong conditions. And, no -- you're not likely to spot a drunk or a text fiend in time to do anything but say, "OH SH**!"
Hits from the rear are less than 3% of all bike/car crashes, IIRC.
Bikes: Workcycles FR8, 2016 Jamis Coda Comp, 2008 Surly Long Haul Trucker
Liked 6 Times
I agree with the dry run first. Also be aware of how you feel after you do it. Make small adjustments as necessary (raising/lowering saddle, adjusting tilt, fore/aft position, etc.), but not all at once. Think about what you need to bring to work, and what you can store their as well. If you sweat a lot or don't want to feel scumy have baby wipes available.
A Backpack might be fine at first as well. If you have the money, there is nothing wrong with having a rack. Also learn how to fix a flat, before you need to fix a flat. Learn basic bike maintenance as well. I would hold off on all the accessories until you know you will keep doing it. A rear blinkie like the Superflash, and a front blink or steady light should be enough if you are not commuting at night.
Anyways good luck, and let us know how your dry run goes.
chinotex
Commuting
12
06-01-11 01:55 AM
