Bike Pressure Gauges Are a Waste of Time and Money
The gauge below has a bleed off function that allows you to over inflate slightly and bleed off to the EXACT pressure you desire. The display adjusts in real time. I can tell you it works as advertised. I found my floor pump was reading over 10psi higher than the gauge.
https://www.topeak.com/global/en/pro...-smartgauge-d2
Likes For noimagination:
Quoted: 6972 Post(s)
Liked 10,968 Times
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Tragically Ignorant
Liked 9,098 Times
Likes For livedarklions:
Quoted: 33 Post(s)
So I figure you must weigh about 220... Well, whatever works for you, I know you weren't asking my advice, but, hey... it's free! One of the odd things tire scientists have found is that rolling resistance does not necessarily go down as tire pressure goes up. What seems to happen is that a lot of energy is wasted rolling up and down the microscopic roughness in the pavement where with a slightly lower pressure the CG doesn't move and the roughness is absorbed by the tire. I don't remember where I originally came across the studies, but if you won't take my word for it... https://blog.silca.cc/part-4b-rollin...-and-impedance
(Around here surfaces are cr...ummy and I could probably go lower than I do, but I'm too lazy to do the optimization studies, and I don't want to bother changing pressure depending on the particular road I ride, so I guess.)
Passista
Quoted: 868 Post(s)
Liked 721 Times
There could be a gauge that measured the deflection of the tire, like a thumb test but with a calibrated spring and a dial gauge?
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
BTW.. who says the gauge is accurate?
I'm not concerned about my pump/gauge since I mine is set by "feel". Meaning once I found what feels right I jsut pump them to the same setting which is 90/100. Doesn't matter if it's actually 87/102 as long as the gauge is consistent.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Have you considered that perhaps the gauges on your pump and hand gauge may not calibrated the same?
Tragically Ignorant
Liked 9,098 Times
[QUOTE=Phil_gretz;21501951]I weigh about the same as OP and ride a bit faster, and that's what I run at. Anything higher and I hate the ride, I feel every tiny bump.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
I don't trust the gauges on either of my floor pumps (one of them is more than 5psi off), so I pump my tires above where I want it, and the check/bleed it down to where I want it with this:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Works great, and minimal pressure loss when removing the gauge, with a swift movement just a slight hiss of air. I've double checked the pressure and saw no loss. I run latex tubes on the road bike and tubeless on the gravel bike, so I'm pumping and setting pressure on every ride no matter which bike I'm on.
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,533 Times
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Really? I go 8 bar which is 116 on my 25mm and need it. Yesterday I only pumped up the front tire, not the rear, and coming down the hill I just felt odd, at the bottom I quickly stopped to check if everything was ok, yes looked fine, except, the tire when pressing it was noticeably less full of air than I would normally ride, but probably it was still 7 bar which is 101 psi. But the ride just felt unsmooth
Likes For MadKaw:
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 337 Post(s)
Liked 228 Times
Amazing how this went from a complaint about problems with a specific tire gauge, to a thread on tire pressure.
The gauge the op is using is a major pain to get off a presta stem without losing pressure, if you all have any suggestions on how to remove it without dropping 5 lbs or so, I'd also like to know
On Your Left
Liked 2,433 Times
Personally i use a floor pump with a built in gauge. Is use the same one everything and whatever the number is, it's consistent. If it drops a few psi when I take it off, it's always the same. And the number doesn't matter as long as it rides the way I like.
Likes For GlennR:
Advanced Slacker
Liked 2,537 Times
Likes For Kapusta:
Dont fix whats not broken
Bikes: Steelman Stage Race, Dura-Ace 9s
Quoted: 95 Post(s)
Liked 166 Times
I used to use a gauge long ago, I think it was an Accu-Rite or something like that, it was digital and measured to the 1/2 psi. It didn't lose any pressure either. In any case, I stopped using it when I realized that level of resolution really wasn't necessary, and the gauge broke when using it on car tires . I also realized that the gauge on my Silca floor pump is "good enough" and a quick squeeze of the tire is adequate to get a good feel for how much pressure was adequate.
To keep the spirit of this thread morphing into something else, in my younger days I ran 700x23 and 25 tires (usually Vredesteins) pumped to ~120psi, I weighed between 200 and 220 lbs back then. Now I'm an old man in the mid-250's, run Continental Grand Prix 25 mm tires (measure 26mm wide on my rims) at between 90-100 psi on my Silca pump's gauge. Great ride and no pinch flats (I ride on pretty decent roads). I've gone higher than this and don't like the handling of the bike.
Quoted: 33 Post(s)
Loss in pressure when removing pump from bike
I have a BB Air Tower 3. I attach to the bike and lock lifting the thumb screw into a vertical (upright position). to unlock I move the thumb screw back down to a 90 degree angle and pop-off.
What I noticed was if I leave the thumbscrew in the unlock position that the tire pressure slowly fizzles out.. you don't hear a hiss but you can watch the dial on the pump and see pressure dropping.
This leads me to believe that even if the pump reads 110 while in the LOCKED position that as soon as I switch to the UNLOCKED that I will lose pressure between the time it is in the UNLOCKED and removal from the open valve
That being said, I just get up to my target pressure, give it one more stroke, then disconnect and don't worry about it. I also don't particularly care if the pressure reading is lab-grade accurate. I know that if my pump shows 90 psi with my 32mm tires then I'm safe from pinch flats on some bad roads around me, and if I let it go 10-15 lbs down from that I'm at non-trivial risk of a pinch flat, verified through experience. It doesn't bother me that what my pump shows as 90 may actually be 87 or 95 and I'd just never know.
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
I've owned two gauges in my life, one was an Accu Gage, which I lost when we moved, and the one I have now is a Zefal gauge and neither of them lost air either connecting or disconnecting.
I use a tire pressure calculator on the internet to get the supposedly correct pressure based on the rule of 15% tire deflection, see: Bicycle tire pressure calculator Use the middle one and enter your clothed body weight and your total bike weight ready to ride, enter your tire size, if you have a typical road bike set up leave the F/R weight dist alone unless you have a more upright riding bike then change it. Now there is room to adjust those pressure depending on the the kind of ride you like, firm or comfort, or the roughness or smoothness of the surfaces you ride on, or if it's raining.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
Terrible title. I use a Topeak digital gauge and maybe lose a couple PSI if I am less careful.
Tragically Ignorant
Liked 9,098 Times
Might want to check the gauge for over-thinking stuff.
Quoted: 22 Post(s)
Liked 78 Times
Old time pressure gauge
Back about 90-100 years ago car tires had cotton belts instead of steel belts. There was a gauge that could be pushed into the sidewall to read the pressure. I tried mine on my 29er and it read about half what I normally run. Can't post links yet, but Google 'JIF air tire gauge' if you're interested.
