Going to a 7-Speed Cassette from a 6-Speed Freewheel
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Brings to mind a kerfuffle I caused on Slack because I had the temerity to admit and even tell other people that 12v impact wrenches are just as effective at tightening axel nuts way past spec as 18/20v impact drivers.
Probably more so.
Quoted: 67 Post(s)
Liked 49 Times
I got the new wheels on yesterday. The gears seem to shift fine.
I'm still a little confused by the rear axle dimension. The 130mm rear wheel went on okay, but there was a little resistance. Could the original 126mm wheel have been right and the frame sloppily set up (too wide)?
Quoted: 541 Post(s)
Liked 416 Times
It doesn't matter when it comes to old vintage crap.
Everything is eyeballed to make it work, when the rider is happy, the job is done.
That's how they built everything in the last century.
If I wanted something that was NASA precision, I'd buy a S-works.
Really Old Senior Member
Your stays are pretty "spindly", so I wouldn't think 4mm would offer much resistance.
How did you measure?
That is a rather cool looking bike.
One issue that you "might possibly" run into is the chain not wanting to come back off the smallest cog because of clearance issues.
That can usually be easily remedied by putting a thin washer under the lock nut of the DS cone.
I think it tends to manifest itself, it's when going to a smaller end cog than "stock". Like 14T to 12T.
Quoted: 67 Post(s)
Liked 49 Times
I was back at this, riding the bike a few days ago, trying to fine tune. It looks like seven speeds isn't going to work well. The geometry of the chain is angled too far out on the outer cogs. I can't get it adjusted so that it doesn't rub. Back to six speeds, it seems.
Quoted: 4420 Post(s)
Liked 1,568 Times
Are you not trimming the FD when you shift the rear to the far ends? I've never had a downtube friction bike rub.
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Liked 1,568 Times
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
i didn't try putting a narrower chain on... it seemed that it wouldn't give enough clearance anyway, and i'm not about to tear up the Imron paint.
Liked 739 Times
and 6 sp. freewheels are just about free in my Co-op, so there is that factor...
Nice bike, BTW .. the bike i had just before getting the Trek was a Puch touring bike.. that frame was Copper plated, and the paint was trashed, so... Paint remover then Steel wool had it shining like a new penny.. I clear coated it after painting the Lugs black and adding a gold pinstripe around them...
Liked 1,568 Times
That's normal. We don't use that gear combination under normal circumstances, and if you have to use it, the rubbing noise isn't going to break anything.
Mechanic/Tourist
1. There is a large angle in the chain, which is more stressful, as well as creating the problem you are having.
2. It is a relatively high gear with the minimum number of total teeth engaged, which increases chain and small cog wear.
3. There are one or two large chain combinations that duplicate or bracket that gear ratio and offer both lower wear and better chainline.
