Schwinn DeLuxe Twinn 5 Resto: Advice Needed!
blahblahblah chrome moly
Quoted: 1193 Post(s)
Liked 2,594 Times
You'd still have that horrible fork though. On our Twinn, we could get the brake to rub on both sides of the rim just by pedaling standing up. The fork was flexing side-to-side that much. Even doing a tight turn like a U-turn in the road, the fork blades would flop over enough for the brake to rub. Not confidence-inspiring!
Personally I can't see any downside to 559 26" MTB wheels, if the fork is sized for it. Yes it lowers your BB height a little, but we haven't scraped a pedal yet.
I think it all comes down to can you find a nice replacement fork with canti bosses on it already. Should be a somewhat heavy one for stiffness, with either an oversize steerer or a one-inch steerer with a heavy reinforcement in the lower part. Ours is a Tange-made Cr-Mo fork (not just Tange Tubing, but they also did the fabrication). The steerer has a heavier butt than a road single fork, plus then they also shoved a reinforcement tube up in the lower end of the steerer, so I'd expect it to be pretty bomb proof. Stronger than the Twinn fork anyway, by a mile I bet. Also (cherry on top) this fork came from a Schwinn MTB, keeping it in the family in a way, even though it was made in Japan. I don't know how difficult it is to find such a perfect fork, maybe we just got lucky, or maybe they're common as dirt.
Seattle has a shop (Recycled Cycles) that sells a lot of used bikes and parts -- got anything like that near you?
Mark B
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 251 Post(s)
Liked 167 Times
Hi,
Realizing that there is a personal attachment here, I wouldn’t go overboard with mods. First, get some decent alloy wheels & tires. If you can use the existing hubs that would be great. It looks like 700c/29ers will work. I’d also try the Tektro brakes or Mafac center pulls with aftermarket pads. Then, find a wide range FW and ride!
There are 3 or 4 co-ops in your area that my help you with this project. I volunteer at the NW Hub in Salem. We have a couple of people who like to preserve vintage bikes, if you are down our way.
My wife and I have been thru 3 tandems and several hundred miles over the years. It’s a great relationship builder.
Cheers,
Van
Cheers,
Van
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
Insane Bicycle Mechanic
Quoted: 810 Post(s)
Liked 722 Times
I had a yellow one. The original rims were the Schwinn 26 x 1 3/8 S-6 (597mm) and might be hard to find. You could try "normal" 26 x 1 3/8 (590mm) instead of the 559mm rims on there now. The rear drum would work with anything but one of the larger sizes would be best for use with a front caliper like you have on there.
FWIW: I think the original spokes were "105 gauge" aka 12 gauge. The Twinns were heavy, awkward beasts when I moved them around the shop.
Jeff Wills
Jeff Wills
Total Scrounge
Bikes: 71 International 72 Super Course 83 Gap
Quoted: 327 Post(s)
Liked 924 Times
Boy oh boy, so many cool ideas floating around here! Hard to keep ‘em all straight! I’ve got a couple of weird sets of 29er wheels and tires that I’ve built over the years for my Surly Karate Monkey that I can throw in there and just see if it sits right. Maybe give it a spin on flat ground with just a front brake. The rear spacing seems to be 135mm.
I was wondering about that flat blade fork. There sure are a lot of replacement forks out there, just not sure I’d want to alter the headtube in a way that I couldn’t undo. Maybe build a drum brake wheel that fits in that flat blade and see how it goes.
Yes, we’ve got some great co-op shops in Portland. I rarely buy new stuff anymore.
Thanks for the ideas and info! Much appreciated!
Liked 2,594 Times
Note, watch out for replacement forks with a loooong threaded section -- those should be illegal IMHO. They're trying to fit a wider range of frame sizes, but it's not safe having the stem expander tightening up in the threaded section, especially if it also has a slit for the headset "tongue washer", as they usually do. It's like the perforated paper on your utility bill, saying "tear here". Bad enough on a single bike, but with a tandem, not only are stresses higher, but the stakes are higher too -- two people who will go down if the steerer splits. The right amount of thread, roughly speaking, is the minimum that will work with your head tube length. It's not something with tight tolerances though; there's some wiggle room.
Let me know if you still have questions, I'd be glad to help.
Mark B
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Yeah, Baby! Yeah! *channeling Austin Powers today*
I built a set of wheels using the Sturmey Archer front-dynamo/drum brake hub, and the 5-speed internal gear/drum brake rear. I was going to use them on a post-apocalyptic build over on Rat Rod Bikes, but got too busy with something else and now I'll just use them elsewhere. Thinking about making a nice winter-bike with them.
Senior member
Quoted: 945 Post(s)
Liked 662 Times
This is a Schwinn Twinn that my wife bought for us on Bay Area Craigslist 20 or so years ago. We used to have an old single speed coaster brake tandem that was stolen from our yard, and we really missed cruising around on that thing.
The only problem with this one was that the wheels were shot. The bottom tube is engraved Calif. School f/t Blind, so who knows who had been steering, but it looked like they had run up a few curbs.
I was twenty-something, and it was early internet, so rather than finding some Scwinn rims, my buddy at the bike shop rebuilt them using 26” Sun anodized rims. We were in a hurry to take it on a weekend trip, so he used the spokes that he had, and they came out pretty scary. The rear is okay.
But the front is spooky.
I found a long reach caliper, and the whole thing worked for one or two rides, but it just wasn’t safe, so it has been gathering sawdust for a couple of decades.
Aside from a few odds and ends, the big question is what to do with the wheels. Is this a candidate for 650b? Do I track down some original wheels? Keep it at 26 and just find a new front? My priority would be for the brakes to work as well as possible, so steel rims seem like a bad idea. I dunno!
Any advice would be appreciated!
Thanks
Thanks
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Note, watch out for replacement forks with a loooong threaded section -- those should be illegal IMHO. They're trying to fit a wider range of frame sizes, but it's not safe having the stem expander tightening up in the threaded section, especially if it also has a slit for the headset "tongue washer".
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
I'm sorry I even mentioned altering the head tube. It's not necessary for replacing the fork -- you can keep your existing Schwinn headset and leave the head tube alone. I only mentioned it because I sent the photo of my Twinn, which does have an altered head tube, done for reasons that probably don't apply to you. Just get a good strong MTB fork with a 1" steerer, in a suitable length for your existing head tube. For a gently ridden Twinn that stays on pavement, I think most any MTB fork will be strong enough (stronger than the existing fork).
Mark B
Mark B
Quoted: 810 Post(s)
Liked 722 Times
Jacob, I have a Schwinn "mattress" saddle that I can contribute to the cause. It's missing the seatpost clamp so you'll have to go fishing at Citybikes or CCC. I live in East Vancouver but work near downtown Portland so I can drop it off when I'm running errands.
I spent 5 years as a Schwinn mechanic out of a 12-year career in the bike business. If you need help, just ask. I have a couple projects in the works- what's one more?
Jeff Wills
Jeff Wills
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
Oh, and I’ve been corrected on the bike’s origin. My wife bought it at a garage sale in Sonoma Ca. and gave it to me for our 5th anniversary. How do I forget these sorts of things? California School for the Blind was in Berkeley when this bike was current, so somebody probably took it home when the wheels became unrideable. The sticker is a little faded, but it came from San Francisco Cycles on Stanyan Street.
Quoted: 810 Post(s)
Liked 722 Times
Yeah- can you clone me? My employer seems to think I can do the work of two people.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
Ah, I just figured out that you weren’t talking about roller-cam brakes. I was trying to figure out how on earth you would do that! Now I’m on the same page. Do those stop it well?
Senior member
Quoted: 945 Post(s)
Liked 662 Times
I just put on the brakes I had on the shelf at the time which were the large im70 series on the rear and the 41 series on the front. I had full intentions of upgrading the front to the larger size but didn't find it necessary.
Here is a makeover video of the bike.
And another close up look.
Liked 2,594 Times
Mmm, think of the rides we could go on.
An actual Twinn! I thought about flipping the photo so the chain would be on the right, but then "Coke" would be mirrored, and of course that's what matters...
But... one bungie holding 12 glass bottles? Advertising shouldn't promote such irresponsible behavior. Better bring a broom and a dustpan with you to clean up the broken glass. Ooh don't get me started!
So cheesy! Couldn't they have found matching shoes? (Yeah uh huh, that's what's cheesy about it.)
I think that's a Columbia tandem but the gurls are blocking the view, darn it.
That photo makes me wanna... straighten that bent-in rear fender.
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
I suppose the Doublemint twins had to appear at some point. This isn’t going to help Jeff get his work done!
Liked 2,446 Times
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
Where were we? Ah yes, wheels.
Did a little swapping around and had good results with a pair of 26” Rhyno Lites with big ol’ 2.35 Fat Franks.
Next, I mounted a 700x44 front and 700x42 rear on a weird set of Velocity Deep-V’s on mtb single-speed hubs. Front looked great in the fork, but rear had to be deflated, and even with the derailleur removed and the wheel all the way back in the dropouts, it still rubbed on the fender arch.
I don’t own any 650b stuff, and the 2.35’s fill things out nicely, so it seems like some polished silver Rhyno Lites might be a good fit.
Liked 2,594 Times
Mark B
Quoted: 810 Post(s)
Liked 722 Times
The bike is missing the chain tensioner for the timing chain. There are a couple available on Ebay. It's a unique part so it might be tough to find.
I like the look of the bike with the 26" wheels and the Fat Frank tires.
Jeff Wills
Jeff Wills
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
15.2 shiny, red pounds!
I never noticed that the fender bracket had been broken off, or that the bb shell had been forged in hell!
Bottom tube is offset, I guess so that the idler pulley lines-up? Get-er-done!
It’s always fun to notice the little details. And damn, I haven’t held a one piece crank in my hand in a long time. Makes me tired just holding those!
