Suntour Cyclone limit screws
Did you know that these limit screws have a groove running the length of the thread which is filled with some glue-like substance, which I NOW realise is there and acts as a locking mechanism. Who knew! In the misguided process of cleaning the threads, I've gone and removed it, so now there's nothing to prevent the screws from being vibrated out. A search for replacement limit screws has brought me to this site, so..... Hello! If possible I'll post a pic of the offending article..
Bikes: Raleigh tourer, Eddie Merckx road bike, Raleigh Maxx ATB
Thanks for the ideas! I have blue Locktite and candles... also a hot glue gun.. ... but not beeswax, so I'll do some experimenting. Also some silicon adhesive which may also be a possibility.
Y'know what this needs? More Locktite.
FWIW: I added to this aged-thread for pretty much the same reason you mentioned- I cleaned out the plastic strip in the keyed portion of the limit screw and it wouldn't hold. Worried that locktite blue would be too much, I used just a drop on the thread--> didn't hold, screw vibrated loose; I tried quite a bit of beeswax--> didn't hold, screw vibrated loose; I added a bead of Locktite Blue to the length of the screw and it held. It holds tight enough that you can still adjust it and the effort to turn the screw is not heroic. I suspect if I removed the screw completely, I'd find some excess locktite accumulated in the keyed groove of the limit screw.
I'm feeling a bit more relaxed now that I'm not the only one! Tell you what, it won't happen again! I've just applied the hot glue liberally to the slot and surrounding threads... it's not pretty! but it seems to have given the screw some extra grip. I think I'll just give it a dab of blue loctite too. Belt and braces!.... Cheers!
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 988 Post(s)
Liked 656 Times
If had a Suntour or other RD (or FD?) that used those combination screws that accept straight-slot or Phillips drivers, I'd probably be interested in retapping just because those are the ugliest fasteners known to man (yeah, but you can use either type of screwdriver); even cut nails would be more elegant. Little Allen wrench bolts would look SO cool.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
