tips for learning to mount from in front of the saddle
don't try this at home.
Quoted: 983 Post(s)
Liked 517 Times
If I stand while riding and lean forward enough that I'm in front of the saddle, yes, I'm pushing back hard. At that point my elbows are locked, which gives me much more strength putting my weight on the bars. ... Normally while standing the saddle is between my thighs -- if I'm doing a standing climb it thwacks into my legs with every stroke. It's not all the way forward on the rails at all, and I have a setback post -- I think it's a fairly normal road-bike amount of setback. My bars are about level with my saddle.
What model bike is this, and what size?
Can you post a photo of the bike?
Bikes: Custom 650B tandem by Bob Brown, 650B tandem converted from Santana Arriva, Santana Noventa, Boulder Bicycle 700C, Gunnar Sport
Quoted: 23 Post(s)
Sometimes there is no substitute for personal instruction.
Lots of possible issues that are difficult to guess over the internet.
There are a couple comments mentioned above that cause me to think of possible strength and flexibility issues that we cannot see. For example, the need to lock elbows when standing mentioned in the original post. From a safety perspective I don't believe that locking elbows when riding a bike is ever a good idea.
Bikes are great machines but it does take a minimum amount of strength and flexibility to ride any bike safely and especially to captain a tandem.
just another gosling
Quoted: 3901 Post(s)
Liked 1,953 Times
This is me, about to start my bicycle. Yes, it is a single, but I think mastering this technique on a single first is a good idea.
Note that my crank arm is in about a 10:00 position ... and my foot is in front of my body.
To start, I simply push down on the pedal and the bicycle starts rolling. I lift my right foot off the ground as the bicycle starts rolling. My left leg straightens quite naturally as the pedal drops to the 6:00 position, and when it gets there, I ease myself back onto the saddle. Meanwhile, my right leg has been hanging, but when the left pedal drops to the 6:00 position, the right pedal is in the 12:00 position which is the perfect position for me to get the side of the pedal I like. And I'm off!
Actually, in thinking about it, it's similar to climbing stairs. You step up with your left foot so that it is in a start position similar to what you'd be in straddling the top tube of a bicycle. Then you push down to raise your body up, and straighten your leg ... and repeat.
Nice photos, beautiful pavers.
OP: We'd appreciate further input, progress reports, etc. Don't leave us hanging!
Results matter
Results matter
Actually, on the tandem, we both adopt the butt-in-saddle-with-toe-on-ground technique. It works for us, although isn't the "recommended way" of doing it. To assist things, I am considering getting longer cranks for both ends so the seat is slightly lower. In general, I ride just about all my bikes from the in-seat start position... always have and probably always will. (There is a video of me using this technique, too).
I also think, that apart from the unanswered question about phase, that the bike might be in too low a gear to start off. But as Wayne points out, we can't advance this until sarah comes back with some more info.
Sorry, I didn't check here over the weekend. First, answers to a variety of questions:
1. My bike is a custom, so I can't post a link to a published geometry chart. However, I can assure you the fit is correct, because it's a custom. Picture:
2. Saying I can't stand without locking my elbows is a little bit of an overstatement. I can stand normally with unlocked arms while riding, in a variety of positions -- stretching and coasting, a normal standing climb, a tucked-over-the-bars power climb, etc.; what I can't do is hold myself up with most of my weight on my partially bent arms. I am fairly certain I have enough upper body strength to captain a tandem, and my flexibility is A-OK.
3. I don't currently own a tandem. I'm looking at trying one out and I'd been led to believe this particular skill was necessary before attempting to do so, so I was trying to learn it on my single bike first. My husband and I are close in height and if we enjoy trying a tandem we would want to get one where we can swap positions.
4. Rowan might have it -- I'm likely in too low a gear. I was taught to always shift way, way down before stops, probably because as a pre-teen with my first geared bike I was a horrible masher and would end up unable to get started again, and the habit stuck. So I'm always in a very low gear trying this. I shift up as I'm clipping the second foot in, normally. I'll try it in a higher gear next time.
My husband, who can do this particular movement, and I played around with it a bit. No pictures, as we were measuring this inside the house and I just took my pants off rather than getting out some bike shorts. I definitely can't put my center of gravity over the foot on the pedal standing in front of the saddle. My foot isn't really as far "behind" me as it feels like, but it's definitely behind my center of mass. When he does it, he can get his foot under his COG. He, however, usually puts his entire butt on one side of the saddle rather than standing in front of it, basically standing a bit off to the side with the foot on the ground, which I tried the next day and was able to get started a couple times, although it felt a bit awkward.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
OK, I'll try to post a video ...
Rowan took this of me on the weekend ...
https://flic.kr/p/Ewz3Kd It doesn't seem enthusiastic about coming up here, but I think it should work if you click the link.
The thing is, you don't have to put weight on your arms when you stand or do a standing start like this ... most of the weight should be on your foot/feet.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Bikes: Trek 7.2 FX, Co-Motion Supremo
Quoted: 44 Post(s)
My wife and I rented a tandem for the first time a couple of weeks ago. Perhaps a few observations from a novice will help.
My goal was to be in the saddle before my power leg was at the bottom of the first stroke. My stoker had both feet on the pedals and we did not pause our pedaling.
I found myself pre-loading for the start. We had to go through 8 or 10 stop signs between the rental shop and the bike trail. At each stop my wife would put my power pedal at 45 degrees from vertical. I would inevitably scooch forward for a better view at the stop sign and my power pedal would dip down to 90 degrees or lower. I could have ask my wife to raise the pedal but what I did instead was put my power foot on the pedal and then roll back to raise the pedal and compress my power leg. This put my leg in a very powerful position but shifted my hips behind my grounded foot. I then leaned forward to initiate rolling forward and as my hips passed over my grounded foot I pressed hard on my power leg. If I felt like I wasn't going to make it into the saddle before I bottomed out I applied a little brake resistance. You could also use a higher gear as suggested earlier.
At the suggestion of the rental shop we started with the captain's seat a little low. I moved it up after about a mile when my knees started complaining but it was still about an inch low.
It sounds like each team finds their own way. I went with my strength which is my ability to take stairs two at a time in a slow controlled climb. Your team may have different strengths but starting with my power leg in a powerful position and a little momentum going forward worked for us.
Quoted: 23 Post(s)
If you have a workable method for that situation then you can try that method on the tandem as well.
In Real Life
Bikes: Lots
Liked 596 Times
I'm not a hill climber, so I try to avoid hills whenever possible. Even more so on the tandem. We simply do not ride the tandem in really hilly terrain. I'm just not comfortable with that ... going up or down.
If I am climbing (with a single bicycle), I prefer not to stop unless I'm planning to get off and walk. For the most part, I'd rather just get into a comfortable gear and keep going to the top. Or if I am going to stop, I pick my moments and stop on a flatter bit of the climb or a roadside turnout or something. And I haven't encountered a lot of stop signs halfway up the hills I climb.
If I do find myself in the rare situation where I stop and then attempt to get going again, I do the thing where you point the bicycle across the road to get a bit of a coast going and then swing it around to continue climbing.
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
FatBottomedGirl
Advocacy & Safety
22
11-19-12 12:14 AM
