Why I hate cottered cranksets...
#51
Quoted: 1303 Post(s)
Liked 1,912 Times
Kurt,
It is always a possibility. However 61+CM frames are a no no go, and the ones needing repair to the rust on the top tube are also no go's. Perhaps the doghouse and fenders from a 69 Dodge would work. Smiles, MH Gimme a call 812-336-3283
#52
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
-Kurt
#53
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 857 Times
I have an older generation of the Bike Smith press and it works great on both my Schwinn and Raleigh three speeds with cottered cranks. It's worth it if you plan to do you own bottom bracket work on a cottered crank bike. The tool has paid for itself many, many times over in terms of saved time for me.
And I love those "AS&CO" cranks.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Likes For SirMike1983:
#54
Liked 1,912 Times
Likes For Mad Honk:
#55
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 175 Times
This is what ChatGPT had to say. Not sure I agree.
#56
Liked 4,396 Times
#57
Liked 4,396 Times
I tasked it with a related question.
This is like reading WikiHow when it was really bad. (Not to say it still isn't, but it has improved).
But yay to us - we've invented a system that provides the same vapid advice replies with slightly better grammar -with the added benefit of wasting inordinate amount of processing power and energy to achieve said result.
-Kurt
-Kurt
Likes For cudak888:
#58
Quoted: 1952 Post(s)
Liked 2,013 Times
I think I read all the posts. Did anyone mention that you often need to file the taper on the cotter to properly fit the crank and spindle? I’d like to regularly service my 73 Peugeot but after using a BFH and a 2X4 on it and getting the original set performing as it should, I’m leaving it well enough alone for the foreseeable future.
#59
Edumacator
Quoted: 2441 Post(s)
Liked 3,136 Times
Victory...?
Okay, in the battle of the tools, it is a split decision. Tool d @Mad Honk versus tool de Treatland’s.
In the NDS crankside, Dave’s tool did well. In the DS, the C-channel actually bent and would not crack the cotter.
In comes the plate steel. After working it, the cotter popped.
The crank is now available to @RustyJames or whomever wishes to partake.
#60
Liked 4,396 Times
#61
Edumacator
Liked 3,136 Times
#62
Quoted: 3811 Post(s)
Liked 6,716 Times
You sure that crankset has enough chain guards?
#63
Edumacator
Liked 3,136 Times
#64
Edumacator
Liked 3,136 Times
Now to remove the bottom bracket...
#65
Bikes: many
Quoted: 1446 Post(s)
Liked 1,395 Times
Whatcha looking at? Upon recommendation of someone here, on CR, or iBoB, I modified the one-tooth end of my Park HCW-5 so its inside radius better matched the radius of the Stronglight lockring on my Automoto. If you have a similar issue, let me know and I'll take some pix. Or, you can buy this from Bike Recyclery:
Also, the Stronglight fixed cup was a nearly perfect fit for the 36mm end of my Park HW-2 headset wrench:
Of course, not knowing what you actually have, I'm just speculating that any of this will help you.
Likes For smontanaro:
#66
Edumacator
Liked 3,136 Times
and now I have two cool tools (one homemade junkyard special by Mad Honk!) for the zero cottered cranks I will be buying in the future.
#67
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
No surprise, that metal is just way too thin. I thought it was intended as a joke or prank when I first saw it. (Are we sure it wasn't?) Can't remove a properly-installed cotter, and definitely can't install one firmly enough to be reliable for riding.
That crank isn't really worth putting on a bike. It was near bottom-quality in its day, and this one has slipped at the swaged interface between the crank and the 3-arm spider. Note how the bolt that should be hidden behind the crank isn't quite hidden? Maybe it was just made that way (horrible manufacturing standards) and didn't slip, but either way this crank is not a keeper.
Ooh, I'm such a snob.
Mark B
Mark B
#68
Edumacator
Liked 3,136 Times
The c channel did well when it was seated squarely on the NDS arm.
When it was a bit squeezed on the DS, it must have been awkwardly angled a bit.
the manufactured too also hand a tough time, and the cotter bound the exit side of the tool against the spider...had to back off and pop it off...
#70
Quoted: 4513 Post(s)
Liked 6,388 Times
Success is of course always the goal, but often a bonus.
#71
Edumacator
Liked 3,136 Times
Okay, so adjustable cup off...
It actually seems to be British but not sure. No markings but held a Nervar crank which, of the French brands often did English threading.
Fixed cup flats are between 34.5 and 35.5, while the adjustable cup stuff was 25.
Don't want to crank that thing (pun intended) clockwise and it being French or something.
Lock nut should not be able to thread on a British cup if it is French, correct?
