Rebuilding or replacing a internally geared wheel - how big a job for a local shop?
Quoted: 981 Post(s)
Liked 584 Times
I suppose there's a little dish in those IGH rear wheels... but all the spokes are the same length and their tensions are virtually the same, which was kind of what I meant.
Agree it's not a big job. Some folks are not at all mechanically inclined, though, and others just lack the confidence to try a DIY fix. Pity he couldn't find a shop that was willing to help out a little.
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
I'm not sure what you mean by " =8-| "... (EDIT: D'oh! I figured it out! )
1. Adjective dish (appearance) caused by dual flanged hubs.
2. Verb dish (action) which is a TECHNICAL requirement for building ALL wheels.
Dual flanged hubs cause the spokes from each side to approach the rim at angle. Flipping the wheel in the horizontal will show each side having the "appearance" of what can roughly be construed as "dish" as in a shallow dish (plate) or deep dish (bowl).
Rigid center line spoked wheels and center line disc wheels do not have this. This form of dish I just described is NOT directly relevant to the technical process of building a bicycle wheel.
All wheels however, have to be properly dished in the "verb" sense - their rims placed directly over the center line between the ends of the locknuts of the hub. Doesn't matter if the hub is symmetrical or asymmetrical, the rim has to be centered on the center line that lies between the ends of the locknuts of the hub. Doing so insures that the entirety of the wheel when centered between the dropouts resides on the center line of the frame itself. It also insures that the gear set operates parallel to the frame's center line and on the drivetrain's own center line.
Placing the rim over the center line between the locknuts of the hub is the type of dish that is DIRECTLY relevant to the technical process of building a bicycle wheel.
The confusion that people have on this topic comes from using the SAME word for two different things.
=8-|
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
Likes For mrrabbit:
Quoted: 1062 Post(s)
Liked 665 Times
This is true. However, a wheel that's symmetrical left to right is somewhat easier to build. I've found that if I get the tensions decent, then the amount of adjustment needed to get it dished correctly is pretty minimal. This is also true for front wheels.
Now, I've built coaster hub wheels with asymmetric dish, to get the chainline that I wanted. But that's a different story.
Likes For sweeks:
Quoted: 550 Post(s)
Liked 325 Times
Rebuilding a wheel competently fast enough to turn a profit is.
The two viable options are
1. Learning wheel building. Use Jobst's Brandt's book and a tension meter app to reach correct absolute tension. The result will beat many shop built wheels but take much longer.
2. Delegating to a one person operation (e.g. pcad RIP, mrrabbit, Peter White, etc.) where the hands that earned the reputation build the wheel.
I started building wheels after folding an under tensioned front wheel from a formerly reputable shop with their rear never staying true although I only weighed 150 pounds.
I didn't feel like upgrading my wife's bike to an 8 speed IGH from a 3, and paid a shop. Although it barely had any dish they didn't put enough tension in many spokes to keep the wheel straight beneath a 5'4" woman. It took as long to fix than starting from scratch.
Mechanics able to build wheels competently and profitably disappeared as boutique wheels became common.
Assuming the spokes reach the screwdriver slot and don't protrude beyond the nipple top.
Right. Building wheels is no more difficult than setting up a front derailleur, but takes much longer with all the spokes.
Any respectable shop can do that for you (don't know the going rate these days) and can recommend good spokes. Sounds like the shop you went to is not capable of working on bikes or selling parts. It's unfortunate that this job needs doing now when so much is going on to complicate the process.
You could also do it yourself. Un-build this one to measure the spokes, buy new ones and watch a tutorial on the Tubes of You or get coaching from someone. If you were nearby I'd coach you. It looks daunting but it's not. My first build was a Sturmey-Archer 3-speed wheel.
I vote for learning to do it yourself. Seriously, if you can spin a wrench you can build a wheel.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
What, pray tell, is a "boutique wheel?" Remember that Sturmey wheel I mentioned as my first? It was a 40 hole hub built 3X to a tubular rim. Would that qualify as boutique and, if so, how many suppliers would have provided that on order? How many suppliers could do that today? That's what bike shops and the mechanics who work in them are for. If it's that big a challenge the shop should charge a little more to cover that or send the customer down the street to a real bike shop.
And I didn't see you offering to coach the OP on how to rebuild his wheel. I haven't been in a shop on industry business (repping) in almost 20 years and I have not worked as a paid mechanic in almost 35 but with the parts in hand I could rebuild his wheel right now, or teach him to do it, and would be willing to do so. Would you?
Quoted: 550 Post(s)
Liked 325 Times
This is how internet discussion boards work. People reply with comments that may be useful to the Original Poster (e.g. use Jobst's book). People comment on answers (e.g. wheel building is dead at local bike shops).
That means they don't get enough practice to do a good job fast. Too many compromise with fast bad jobs that don't even match machine built wheel quality. This even applies to "good" local bike shops.
A few people do for customers who want something odd like dynamo front hubs and PowerTap rear. I noted mrrabbit and Peter White who have no employees, good reputations, and will do a quality job on any new build. I would not trust anyone who is not a one person operation.
I'm genuinely curious about how many custom wheels are built to order versus assembled by their end user. You need to be intimate enough with mechanical details to want something different than the companies are selling in spite of it usually being heavier, but not enough to build it yourself.
I also suggested using a tension meter app to achieve sufficient absolute tension because with contemporary 25mm+ deep rims spoke bed fatigue caps it not the rim's elastic limit which can be determined by Jobst's iterative tension, stress relieve method until the wheel goes out of true at which point you back off a half turn and touch up.
The Zac 19 is shallow enough it would probably be fine, but a $5 phone app converting plucked spoke sounds into the frequency domain via FFT, picking out the loudest, and converting to tension is accessible and more universally applicable.
We both agree that's the right choice given a little mechanical aptitude. Wheel building is not difficult. It just takes a while when you only do it periodically.
Quoted: 252 Post(s)
Liked 67 Times
Unless the OP has no mechanical aptitude, he should fix it himself.
Start by removing one spoke only, marking or noting by some tape which spoke it went over or under and shop for spare spokes of that length, probably a common type.... You could use color tape or fix pens to mark the holes where the given spoke ends belong (you can easily get lost in it if you are new to it).
BTW question for experts - if a spoke is broken or you don't care if you bend it out of shape, it will be easy to remove but maybe hard or even impossible to insert the new spoke back if you don't want to destroy it in the process of inserting it? Do spokes need to be inserted in some sequence, meaning you may not be able to replace some spokes without having to bend them too much, in some cases not possible? Like roof clay tiles in Europe, to replace some of them, first you need to remove others before you can remove/replace the broken one, unless you are lucky and you can replace one without messing with any other. Is that the case with wheel spokes too?
I have only ever been 'fixing' a wheel when one or couple or several spokes were loose and that involved pre-tightening and then truing the wheel in place, using partially closed brake pads as a guide, plus common sense. Also picking with fingernails on the spokes to tell by the tone pitch how tight they are.
To have a bike shop tackle your job, I think you may need to find the right place for it. Those fancier ones may tackle only the more expensive wheels, otherwise it is not financially interesting to them and by the same token, to you (to have such job done by them). In bigger towns you should be able to find some little one man bike shops where the owner can cost wise tackle even ordinary wheel job since he doesn't have high overhead or profit expectation. Those bike shops are found in less fancy parts of towns and serve the population below middle class one but often they do better job than some shops on main avenue with bright showroom.
Likes For cpach:
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
The hardest part is probably removing the sprocket set if the broken spoke in question has to go into the hub from the sprocket side. I only have single speed and IGH hub bikes, so popping off the single rear sprocket is easy. Same may apply to disc braked wheels, but I don't have disc braked wheels to know.
To install a new spoke, you may have to put a slight curve into it, unless you remove the surrounding spokes. Getting the over/under pattern is not hard because you just look at the other spokes still in the wheel and replicate it. Also, you may have to remove the tire or maybe not. I've replaced spokes fairly easily by just partially deflating the tire enough so the nipple can go into the rim part way, and the partially inflated tube will prevent the nipple from falling in if you're careful.
You can uncurve the new spoke after you get it laced past the other spokes and get it started in the nipple.
Quoted: 252 Post(s)
Liked 67 Times
Wonder how classic wheel compares to those more modern ones that have much fewer spokes in terms of how easy they are to rebuild spokes. My new bike has 20/24 spokes front and rear respectively and the weave looks much simpler than the classic old one of mine (who knows how many spokes that one has). It may well be that a beginner wheel maker might have easier job with one of those old wheels with many more spokes, even if the intuition might tell otherwise? Truing the wheel with fewer spokes may be much less forgiving.
Ha, you just hit on an argument against disc brakes, even if a minor one only, I suppose. Thing is, broken spokes mean the bike was abused pretty badly, in terrain, or long neglect. Road bike can at most have loose spoke(s) unless maybe we are talking some fine wheels with gossamer spokes and serious biking, road or otherwise.
Likes For cpach:
