Best Tires for Touring with 26" Wheels.
Slow Rider
While not narrow, I use Schwalbe Big Ben (2.15") on my Surly LHT. They roll very well on and off road, are durable, and add comfort from the balloon-tire design. Highly recommended, excellent tire.
Big Ben HS 439 | Schwalbe North America
I'm getting ready to order tires and I appreciated this thread. What are the advantages of the Big Ben over the Schwalbe big apple?
I'm 330lbs down from 365 and I was thinking of sticking with a fatter tire until I lose more weight. I have the 2" big apple I my utility bike and they have worked well for me. They are not as fast I sippose, but they have carried me and a lot of groceries quite a few times.
I'd like to try a smaller tire but I'm kind of nervousness outbut until I getunder 300#
Quoted: 55 Post(s)
Liked 32 Times
If your wheels are 26"/559mm, then Compass is coming out with a 54mm high performance tire later this month or next month. The Rat Trap Pass buries the Big Apple as far as weight (weighs less than half the BA) and it should also blow the BA away for speed and maybe comfort. You would be giving up flat protection though and that's a major issue for some people.
I do ride off pavement quite often. I've done it several times on the big apples, but I did wipe out once riding on wet grass. I always wondered if I was pushing my luck off-road on the big apples.
Quoted: 55 Post(s)
Liked 32 Times
I will also say that as a big guy, based on my fairly limited amount of off-road riding, wider is better. If I spent any time at all off the pavement and my bike fit 50mm tires, I would never ride less than 50mm tires. If you hit a softer spot, narrower tires will dig in and slow or stop you where fatter tires might just roll right over it.
Thank you. I think I will get the big bens. Im probably 60% off road right now. And I'm not married to one tire forever anyway.
I have a second 26" rear wheel I think will fit my troll. I was wondering if I could make a second set of wheels and mount narrower tires on them for all pavement rides.
Quoted: 137 Post(s)
Liked 81 Times
In the big picture another set of tires isn't a great expense and it's fun to see how the bike handles with different tires. I find there are other tires that roll easier and don't feel as squiggly on drawbridge grates as Continental Touring tires. The Panaracer T-serves are light and durable enough for light touring, Continental Sport Contact in a 1.4" rolls fast but not the most puncture resistant, Schwalbe Supreme is good but pricey, the Schwalbe Racer is very comfy.
only dis advantage to Continental Travel Contact, was the tread design .
Which had people volunteering their observation that it was a Knobby tire was worn slick ,
not knowing the smooth center band, for paved roads , and a row of knobs on the edge for un paved roads ,
is there by design..
Quoted: 5 Post(s)
Liked 5 Times
Marathon Supreme in 26x2.0 is light, tough and rolls well. I have found them to be a 'fast' tire and I like being able to drop the pressure down if I am going through rough terrain (like many of the roads in my general area).
I used Schwalbe Marathon 26 X 2.00 tires recently between Perth and Peterborough, South Australia. 2700 km in a month. I have always used Schwalbe. The key for me is to keep them at about 62~65 psi. Too low and I had sidewall failures. Now with the Schwalbe digital pressure gauge I can keep the pressure measured accurately.
Quoted: 671 Post(s)
Liked 49 Times
Kinda surprising that Schwalbe sidewalls would break from using lower pressure; I assumed they were designed for use even down to 45 psi depending on load etc.
I have a question. I have been using my second pair of Greenguards starting with 1000 mile tour last summer and just competed a shorter 200 miler yesterday. I swapped them front for rear for this year's ride. I had discovered the front had not seated well on last summer's ride and I couldn't eliminate a slight wobble to the tread alignment no matter how hard I tried so I hoped it would be less noticeable on the rear for this most recent ride. Instead I discovered a slight hump to the rear (now front) tire when I swapped them. Again, I couldn't eliminate it with repeated deflations and reinflations with much much fiddling in between.
I now suspect they were seconds and are just not up to spec. I got them at discount through Tree Fort Bikes. Is this reasonable to assume? I'm reluctant to buy another possible pair of seconds (if that is indeed the problem) but was happy enough with the first pair to risk a non-discounted price if I can be sure that everything will work as expected. Any comments?
Quoted: 3462 Post(s)
Liked 1,468 Times
I always want my most worn tire on the rear, the last thing I want to risk is a blow out on a front tire. If I had a tire with an odd bump to it, if I continued to use it, I would not have it on the front. When I replace a tire (virtually always a rear), I often take the front and put it on the rear, then the new tire goes on the front.
Bikes: Thorn Nomad Mk2, 1996 Trek 520, Workcycles Transport, Brompton
Here is my nifty table for tire pressures, based on Frank Berto's graphs plus some of my own theorizing: Interdependent Science: Bicycle Tire Pressure
65 psi seems very high for a 2 inch tire. But it depends on the load. If you have like 400 pounds total on the two wheels, then yeah 65 psi would be about right.
Depends also on road conditions. Suspension will help smooth the ride on rough roads, so lower psi is more efficient then. On smooth roads, higher pressure will be more efficient.
Max pressure also depends on rim width. Fat tires on narrow rims tend to pull the rims apart, so best not to push the pressure too high. Fatter rims can handle more pressure, just because of the geometry.
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
Keep in mind that narrower tires will require higher pressure and will result in a firmer ride. They will also transfer more force to the spokes. I am 350#, using 40 spoke wheels with Velocity Aeroheat rims and Wheelmaster "tandem" hubs. My best 559 wheel has Wheelsmith DB15 spokes on the left and DB14 spokes on the right, and has about 2K miles on it with no issues. I started off with SS14 spokes on both sides; the DB spokes provide the extra compliance needed so that no one spoke is taking excessive load before other spokes start sharing the load. A "weaker" (in the center area) spoke results in a STRONGER wheel.
To the OP I went with 2.0 Continental Travel Contacts on my Panasonic and thus far have been very happy with them. The smooth center tread is great for on road travel and they feel much more stable than narrower 1.5 inch tires I've run in the past. No regrets on the purchase.
hilltowner - I was very interested in your experience because I recently purchased a pair of 27 x 1 1/4 in. Schwalbe green guards and they are next to impossible to get seated without some kind of rise. I even contacted Schwalbe about one which had a wide section in the tread. It was almost 3/16 " wider and appeared to be bad cords. To their credit they were straight forward in replacing it.
I don't know if the reflective band is not parallel with the bead or what but I cannot get them to look like they don't bulge away from the rim in spots. I will note that I am mounting them on old Weinmann straight sided rims and maybe if they had a hook I could get a more even seat. Overall my experience hasn't been too good and I think I would opt for other options in the future. I do however like the tread pattern and puncture resistance but I'm running them at 70 psi max for fear of them blowing off my straight rims and I can't say they are any more comfortable than some Continental Gatorskins of the same size.
Nothing compares to the simple pleasure of a bike ride - JFK
Liked 1,468 Times
I will just add that I have two sets of wheels for my LHT, Mavic A719 rims with robust 37mm wide touring tires and the other wheels are narrower (cheaper) rims that I mounted 28mm wide supple Continental smooth tires that actually measure 25mm wide. In my case I have a cassette on each set of wheels, that increased the cost a bit.
My faster wheels are not that much faster when I look at total time of travel, but they feel a lot faster and I think I am often in a slightly higher gear when riding them.
Keep in mind that you have to reset the bike computer with different tire circumference data each time you switch wheels.
Liked 1,468 Times
My Hutchinson Globetrotters have a reflective stripe that is not in the right spot and makes things look rather weird, but it is only the reflective strip that is problematic. The rest of the tire is quite symmetrical and of consistent width.
Harhir
6
09-17-15 10:40 AM
