Rain/Wet Rig Hot or Not
Quoted: 1096 Post(s)
Don't expect this thread to get so many entries, but figured what the heck: it's winter and I'm bored. Post your road bike with fenders here. ![Smilie](https://www.bikeforums.net/images/smilies/smile.gif)
Just cleaned this thing and figured I might as well post it. Probably wouldn't get much love in the no-holds-barred Hot-or-Not, even if I'd put the fancy wheels on it, but figured I'd get points for trying, what with managing to get fenders squeezed onto this gimmicky frame....
No garage doors, just balancing in a window frame again....
![](https://i1065.photobucket.com/albums/u397/archkevinbrown/winterhotrnot_zpsuleqoakv.jpg)
May just go for a little ride up to the bike shop later. It's above 40 already, roads look mostly dry now, but it's a bit windy (all the more reason to keep the lower-profile wheels on).
Gold Member
Bikes: Pinarello Dogma F8, Pinarello Bolide, Argon 18 E-118, Bianchi Oltre, Cervelo S1, Wilier Pista
Quoted: 34 Post(s)
I have a fairly nice rain bike, but I don't use fenders.
Bikes: 1981 Miyata 210, 1987 Miyata 615GT, 1990 Miyata CT3000, 1993 Cannondale M300, 1994 Cannondale Killer V, 1995 Cannondale R500, 2010 Cannondale F4, 2015 Framed Minnesota 3.0
Wow! My rain/salt bike is not nearly that cool. It's just an old Cannondale MTB commuter.
Thanks. It was my only bike until recently.
By the way, for those of you who would judge, the bars have been fixed.
It turned out to be a gorgeous day, so I took the bike in this afternoon to see about tweaking the fit and maybe do a loop of the park. I've been trying to ride in the drops more, and things didn't seem quite right. Well, it seems the bars had rotated - maybe you can tell from the photo above - and not only did they fix that, but they gave me a longer stem (110 in place of 100). Who knew it would make such a HUGE difference? It's like a new bike!
If you ride alone, and do your own laundry, I guess no one can complain.
Gold Member
Quoted: 34 Post(s)
Nobody does, and I don't always ride alone. Fenders just aren't as popular in Europe. Most of the guys I ride with don't have them and don't care. People just accept that if you ride in the rain, you get wet.
True, however what is coming down from the sky isn't of much concern for me. What is coming up from the pavement is.
Over a century ago "Mudguards" were the term for full fenders in British English when draft animals left their digestive end-product on the roadways.
It wasn't "Mud" that cyclists prevented from being slung onto themselves and their machines by fitting mudguards.
A nasty toxic blend of water, oil, ATF, pesticides, herbicides and "dog-mud" are intercepted by the full mudguards on my winter bike.
![](https://bikeforums.net/attachment.php?attachmentid=430487)
Riders on my wheel in a paceline are not soaked by a rooster tail of road spooge.
-Bandera
-Bandera
-Bandera
-Bandera
So, is that a camping bike, too?
Not at my advanced age.
It's set-up for winter/wet roads as a traditional Audax/Randonneuring rig suitable for overnight trips to a lovely old hotel w/ the best chef and wine cellar in the area.
Although we are in a drought winter brings enough rain to wash months worth of toxic road grime and nasty agricultural runoff into our "low water crossings", not something that I wish to wear.
In ten minutes it converts to summer duty, and back again in the winter.
![](https://bikeforums.net/attachment.php?attachmentid=430512)
-Bandera
![Wink](https://www.bikeforums.net/images/smilies/wink.gif)
![EEK!](https://www.bikeforums.net/images/smilies/eek.gif)
-Bandera
Bikes: 2012 Scott CR1 Comp
What sort of bag support are you using there? It looks like something extends from right above the rear brake caliper and supports the bag....
Liked 15 Times
Really flexible fenders with a wide opening at the bottom, narrowing to what looks like about a zillionth of an inch of clearance between the front tire, the fender, and the down tube?
I have no opinion on the appearance of the bike, but I'll bet skin grafts on your face are definitely a "not".
Actually Crud Roadracers are fairly decent fenders for road bikes. If I had the clearance to mount them I would be using them on rainy days/wet roads.
That's what I'm showing - didn't think I'd get anything to fit, but they do. It helps that they are narrow under the brakes and zip-tie on there. Are you sure you don't have clearance?
Bikes: 2013 Cannondale SuperSix - 1998 CAAD3 R500 - 2012 Demo 8 Carbon
Quoted: 13 Post(s)
Traditional, solid, reliable and very high quality.
I prefer the traditional British seatbag over the French decalleur/HB bag for long un-supported rides in sketchy weather.
On/Off as needed.
-Bandera
Expired Member
Quoted: 3822 Post(s)
Liked 5,858 Times
First I've seen of that bag support. It looks like a good alternative to the rack I bang my knee on!
Quoted: 18597 Post(s)
Liked 16,104 Times
Liked 15 Times
The clearance between the down tube and the tire is about 1/2". The fender itself is super flexible, thin and floats just below the downtube. Sometimes it grazes, but generally it's about 1/8" off at the closest point; the slight angle of the wheel and the photo make it look tighter than it is.
How do you figure? The opening at the trailing edge of the wheel is there at the down tube with or without the fender, and the fender is extremely pliable, if not fragile. It's not like a vacuum is created that's going to suck rocks and sticks and metal rods up off the road into the forks.
Liked 15 Times
No vacuum or anything, but pebbles and sticks and various other garbage does adhere to the tire for a fraction of a second and sometimes makes it into the fender. If the "entrance" at the tire/fender is smaller than the clearance under the fork crown, problems are unlikely. But if the entrance is wide open and narrows into a pinch point under the crown, you might have a problem.
Flexible fenders actually exacerbate the issue, as they are more likely to accordion into the crown when a foreign objects gets momentarily caught.
Liked 15 Times
That's why bikes made for fenders traditionally have quite a bit of clearance at the bridges and crown. The idea is to have a minimum of 1 cm. between the tire and the fender, which means the bridges are normally at least 1.5 cm from the tire, and the crown usually a bit more, like 1.7 cm. minimum. I try to set up my fenders so that the "entrance" gap is about 1 cm. and the rest is about 1.1 cm. That way the fender still appears to follow the tire line, but the "choke point" is right at the beginning.
There's a lot I don't know though, and I could be wrong about your set-up. I personally wouldn't ride it, but I tend to be pretty conservative about such things. Good luck!
The stays are designed to snap when something gets caught up by the wheel. I have caught a full on branch on my wheels, and the stays snapped immediately, followed by the rest of the fender. Nothing else was harmed. I cannot see how the structure would accordion into the fork, it simply isn't strong enough to stay in place that long before it tears away as it is designed to. As far as stuff being momentarily being stuck on the tire, they are peeled off by inside surface of the fender, so you hear a "ziiiiip!' sound as the rock or debris is forced off the tire and dragged along the inside of the fender. Anything bigger than that just isn't going to stick long enough unless you are riding through fresh tar.
Your limits would make it impossible to ride a tire of any size on my Scott CR1 at all, much less with any fenders.
