Hey...no kickstand
#76
Apparently, you're doing something different from what I do. The included bungees allow me to set the brakes, front and rear, and the Click Stand staff holds the bike at near vertical. Nothing else is needed. Works every time, even when the bike is loaded with a single wheel trailer attached, no problem at all.
Edit: I think we're talking about two different products. The Click Stand I use does not affect the front wheel except to keep it from rolling.
#77
Quoted: 1034 Post(s)
Liked 1,292 Times
I capped the ends of my top tube, installed a presta valve, and filled the tube with helium. The bike now stands up on its own, no kickstand needed.
Alternately, you cold mount a gyroscope between the top tube and bottom tubes, but that will require a power source. The helium is a better option for me, and it makes the bike lighter so I can go faster.
Likes For phughes:
#78
Bikes: Basso Loto, Andre Bertain, Schwinn Madison, Litespeed Unicoi, Easton full sustension, Macau non-suspended MTN, Merlin Agilis, A-D Superlicht, Daccordi Piuma, Scott CR1 (former owner Thomas Frischnecht), Van Diesel CX, Alan Top Cross, Scattante CX, Ri
Quoted: 10 Post(s)
Liked 15 Times
No, don't put a kick stand on it! Use the curb by rotating the pedal facing the curb to rest on the curb behind bottom dead center. The bike will tend to move forward but cannot so the pedal will hold the bike up. Takes a little practice but quite stable except in very strong winds or when someone pushes the bike.
Likes For sabele:
#79
think putting a towing package on a Mercedes 450 SL or a Porsche 914 ....... really
#80
Quoted: 10 Post(s)
Liked 15 Times
My 20 bikes also hang from hooks in the ceiling; one hook per bike on the rear wheel. Hanging is better than standing as the tires will not be impacted when they deflate.
Likes For sabele:
#81
Just checked this. No this isn't a joke. I realize I could buy one, but there is a reason they don't come with them so I was curious as to what everyone is using. And I understand if you are on a long ride with no kickstand, then you can lay it down or against a tree or whatever is soft. I mean more like for storage in the garage. This is my fault for phrasing the question poorly. I was never owned a bike without a kickstand...then see other people riding and they have none. So that begged the question what are you holding you prized possession up with. You are damn sure not laying it down in the garage.
#82
kickstand
[QUOTE=ClydeClydeson;21862329]Bike snobs don't like kickstands, except for maybe on dedicated touring or city bikes.
I heard real mountain bikes don't come with kickstands, it could deploy riding over rough terrain and cause an accident....lol
#86
Bikes: Devinci Millenium, Gary Fisher Joshua
Quoted: 73 Post(s)
Liked 29 Times
Just get an elastic like the ones that hold veges at the supermarket, loosely wrap it around the handlebar near the end of the brake lever or wherever it is out of the way. To lock the wheels best you can use a second one on the other brake. You simply wrap the elastic around the brake lever and the handlebar and the brakes are locked and the bike will not roll no matter what you lean it against if, it is solid of course. Even one wheel touching will do the trick. For instance one wheel against a wall is plenty.
#88
Quoted: 741 Post(s)
Liked 818 Times
I stopped by the LBS the other day, and they were really busy, at least 8 or 10 empty bike boxes on the sidewalk. A guy was walking out with a new mtn/hybrid bike, and he turned around and asked the guy if he could buy a kick stand for it. I was surprised. Never saw that before. I think the last time I had a kickstand on my bike, I was in fifth grade.
#89
Bikes: 2014 Fuji Traverse 1.3, 2020 Electra Cruiser 1, 1995 Giant CFM-4
Quoted: 124 Post(s)
Liked 51 Times
I'm a dork with a kickstand. In fact a double one making me I guess, a double dork.
#90
pauoos
Bikes: 2001 LeMond Tourmalet, 2000 Gary Fisher Aquila
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Likes For GlennR:
#92
On Your Left
Liked 2,434 Times
Likes For GlennR:
#95
The kids in the house across the street from me just lie the bikes down flat on the ground. Not necessarily gently either; it's more of a halfway set-it-down, let-it fall the rest of the way kind of maneuver. And by "ground", it could be anyplace: in the yard, on the driveway, on the sidewalk, etc.
One morning last summer, I was sitting in my living room and I heard some commotion across the street. Apparently one of the bikes had been left overnight on the sidewalk and a lady came walking by not long after sunrise and tripped over it.
#97
Bikes: 1982 Bianchi Limited, Specialized Stumpjumper, Trek 520, Specialized carbon Diverge
Quoted: 7 Post(s)
No kickstand
I put a couple of pieces of electrical tape on the side of my touring bike saddle in case I have to lean the bike against a rough surface. The tape gets scuffed occasionally, especially on tour, but the saddle doesn't.
At no time did I exceed the posted speed limit.
#98
Quoted: 604 Post(s)
Liked 1,064 Times
