ISO and for trade thread part 5
#4051
Quoted: 765 Post(s)
Liked 660 Times
I pretty much need a 47 to work properly with a 42-tooth big ring--a larger one would interfere with the swing of the front derailleur. A 48 would probably work, though.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
#4053
Quoted: 887 Post(s)
Liked 335 Times
ISO Weinmann 22.2 brake levers
Looking for a decent pair of Weinmann upright bar brake levers. I don't mind having to polish them as long as the clamping bands are good. I have stuff to trade or cash.
#4054
Stop reading my posts!
Quoted: 1453 Post(s)
Liked 1,074 Times
The wider clamp bands (used on road lever bodies) seem to come in the next larger sizes stamped 23.5 or 23.8 and these won't swap in as replacements for the narrower clamp bands of the upright bar levers (too bad).
#4055
Quoted: 1113 Post(s)
Liked 1,335 Times
I have seen those clamp bands (either Weinmann or Dia Compe) stamped "22".but not "22.2", do they come in that size?
#4057
www.theheadbadge.com
Quoted: 2429 Post(s)
Liked 4,424 Times
-Kurt
#4058
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
not sure if this an appropriate section or there's an ISO thread anywhere else? anyhow, looking for at least one shimano cartridge/square taper bottom bracket lock ring....plastic or metal.....for ND side. mine...plastic...is busted, but the bottom bracket is still in excellent shape. could trade or cash. just need one, but maybe if you/anyone has a couple from bad BB's just hanging around the shop?? if there's any details needed to make a match up, let me know. thank you!!
#4060
Liked 1,335 Times
#4062
Quoted: 765 Post(s)
Liked 660 Times
ISO a worn-out 47-tooth 144 BCD chainring--Campy or Campy clone. I'm going to cut the teeth off it and make it into a chainring guard for a project similar to the one described here:
https://www.redclovercomponents.com/...chives/07-2014
I could use a still-serviceable chainring, of course, but it seems a shame to reduce the world's supply of functional 47 tooth rings by one when there's probably a thoroughly worn-out one out there somewhere.
I have trade goods of various kinds.
--Ogden Nash
--Ogden Nash
Likes For dweenk:
#4064
Quoted: 887 Post(s)
Liked 335 Times
Dale
#4065
Quoted: 3372 Post(s)
Liked 3,680 Times
I'll preface this with saying I'm not sure if I'm really in the market for something right now, but this is what I've been thinking a lot about. It's quite specific but maybe this will be fruitful to put out there:
High quality steel lugged or fillet brazed frameset (531db, Columbus SL, heat treated tubesets, etc). TIG welded Ti is an option but likely out of my budget. I'd like to build something fairly light.
62cm max, 60cm min CTC seat tube
57-58cm CTC top tube
73° STA (72-72.5° okay, maybe 73.5° okay, top tube length needs to compensate)
27.2mm seatpost
22.2mm steer tube
BSA bottom bracket
Clearance for 700c x 28mm tires minimum
No full brake cable housing run on top of top tube. I sweat a lot and don't want to deal with keeping that clean. This eliminates a lot of options based on my eBay trawling, so let's make this an option rather than a requirement.
Internal routing okay but I don't want to have the housing bouncing around loose inside. I'd prefer braze on stops on the top tube.
2 bottle cage mounts
100mm / 130mm spacing (or be okay with cold setting)
Recessed brake mounts for mid-reach calipers like Tektro R539 (or possible to drill out for recessed brakes)
If paint in excellent condition, I'd like it to look good with modern black components and wheels. I don't like red at all, really prefer silvers and greys, also light blue. I would be okay powder coating if paint in rough shape.
Thanks
27.2mm seatpost
22.2mm steer tube
BSA bottom bracket
Thanks
Anyone have a Paramount frameset hanging around? Or a 6xx/7xx Trek?
Found some modern steel that fits what I was looking for. Thanks!
#4066
Liked 1,074 Times
Sure, that solves the diameter no-go but my point is that the clamp widths will not swap between the 'road lever bodies' (clamps are approx 15mm) and the 'upright lever bodies' clamps are approx. 13mm. Additionally the bodies themselves differ (upright levers are narrower) so the shape of the clamps where inserted into the bodies are different to the "road bodies" as are the toggle bits that pull them tight. I once thought that just filing the "slots" of the upright bodies about 1.5mm wider would do the trick but found out: "NOT". A bit of a shame cause those road clamps are far easier to come by, especially given the stock of Dia Compe parts in circulation!
#4067
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 166 Post(s)
Liked 102 Times
ISO Weinmann or Dia-Compe 750 brake calipers
#4068
Ultegra triple front derailleur FD-6603, 28.6mm clamp
I need an Ultegra FD-6603 to replace one whose cage fractured. I found a Dura Ace front derailleur, but the cage shape is a little different, and it won’t work with my chain watcher, which this bike really needs.
The front derailleur that I’m looking for must be a 28.6mm clamp-on. Larger diameter clamps with shims won’t work, because the clamp has to fit under a bottle cage.
Willing to trade the Dura Ace front (was NOS before I mounted it) for the Ultegra
#4069
Prince of the Royal City
Need two Campy Record friction shifter parts
Hello,
Need a couple of parts for my vintage shifters on my Holdsworth.
I only need one of each and can pay via PayPal.
Missing Campy pieces
#4070
Quoted: 7360 Post(s)
Liked 2,504 Times
That would be lacing all spokes to holes on one side of the rim. I don't know if that's good or bad.
#4071
ISO Dura Ace 7700 front hub
Looking for a Dura Ace 7700 front hub, 32h, good or better condition. Cosmetics not so important, but must spin smooth. Original skewer preferred but not required.
Thanks,
Thanks,
#4073
Bianchi Frameset
I was hit by a car a couple of months ago, and have exhausted my efforts to find a replacement frameset. It's a 1983 Bianchi Tipo Corsa 28t, 61 cm frame. The frame is quite bent, and no shops here think they can re-weld it. So I thought maybe someone here might be able to help track down one. I've been looking on ebay and some other places, but finding a frame that size has been difficult. I'm 6'2" so I'd probably be as happy with a 59 cm frame. If anyone can direct me or help me find one, I'd be very grateful.
Tom
Tom
#4074
4.6692016090
Bikes: yes
Quoted: 59 Post(s)
Liked 81 Times
Tom
Tom
https://sfbay.craigslist.org/d/bicyc...%7C62cm%7C63cm
#4075
Bikes: 1972 Fuji The Finest | 1990 Bianchi Giro | 1999 LeMond Buenos Aires
Quoted: 151 Post(s)
Liked 303 Times
ISO SR Laprade 26.4 / Japanese High Flange Hubs
FOUND,THANKS! I'm looking for a couple items for a build. Would like decent condition or better, don't mind a little cleaning up or de-rusting of bolts etc as needed though.Got several things to potentially trade, let me know what you're looking for (some Shimano 9s, some 90s Campy, greenbacks).
SR Laprade fluted 26.4 Seatpost (I think I need 110mm+ from rails to min insert - so probably 180/190 overall) - either the 1 bolt or 2 bolt is OK70s era Japanese High Flange hubs - Silver (126 or 120 rear, both should work), 36h preferred - PENDINGDura Ace 1st genSanshin/Sunshine Pro-Am'Might consider others
