Shogun serial # database?
#276
Finally finished the build of the 500.
#278
Quoted: 4722 Post(s)
Liked 3,044 Times
#281
Liked 3,044 Times
#282
Early 80s Shogun 2001 touring bike that has been my daily rider for the last 6 years: m1e33728
#284
Liked 3,044 Times
#285
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
I believe my Shogun 500 is a 1985, serial # is Y5F1400.
(I've tweaked the rear rack to be parallel to the top tube, because I know how persnickety some of you are!)
#287
Liked 3,044 Times
#288
Liked 3,044 Times
#289
Bikes: 1987 Schwinn Circuit, 1986 Schwinn Passage, 1987 Shogun Katana, 2018 Giant Anyroad Advanced, 2013 Karate Monkey
Quoted: 125 Post(s)
Liked 269 Times
Might as well drop my SN in S5W6274.
It is a 19" 500 touring frame with cantilever posts. Tange 900 CR-MO double butted.
#290
Bikes: -1982 Kuwahara Apollo 24" Cruiser -1982 Kuwahara KE-1/KYZ -1983 Tange Shogun Hot Heart -1984 Kuwahara Bravo -1984 Diamond Back Viper/Pacer 500 -1985 Kuwahara Road Bike -1986 Kuwahara Magician -1987 Kuwahara Magician EX
Quoted: 9 Post(s)
Can I join the club?
1983 Tange Shogun Hot Heart BMX.
Serial T3A2046
Serial T3A2046
#291
Quoted: 339 Post(s)
Liked 632 Times
Hi all.
Just brought home a Shogun bike from the Bike Exchange.
It appears to be mid eighties touring model with Deore derailleurs and a triple crank.
Can anyone here steer me to catalogue scans and /or specs. I haven't done anything except remove the pedals which must have been glued in and the crank threads buggered because i had to use heroic effort to finally get them off including removing the left side crank arm and putting it in a vice to hold it while I used the big wrench to unscrew the pedal.
It looks like this will be a nice project .
Tell me good stuff about the bike, pleeeese!
I promise to send in the serial no. tomorrow,
#292
Quoted: 339 Post(s)
Liked 632 Times
O/k Here is what I found about the Shogun I just brought home.
Model - Shogun Alpine GT
infinity main tubes Cromaloy double butted stays
Magnaloy forks
Shimano light action sis down tube shifters
Shimano Canti brakes
Weight as delivered As seen in picture plus cranks and seat. 25.7 lbs
Serial number S7E 5395
Any info would be appreciated. Catalogue scan?
Magnaloy forks
#294
Liked 3,044 Times
Magnaloy forks
Magnaloy forks
#295
Hi everyone, i am unable to identify a bicycle. The bike has an aero frame and has been repainted. it is very similar to a Shogun Aero or an SR bike ive seen on another forum but has some differences. My Shimano Aero bike has 600ax components, tange levin aero headset, SAKAE CUSTOM road champion handlebars, shimano sf forged rear dropouts, it is gold and seems to have been repainted, the fork is partly chromed and has tange dropouts. the serial is on the low part of seat tube right above th bottom bracket on the left side (S1N0278).
I found some very similar bikes but theres always a little difference...
here are the ones i found that are the closest: gemini aero, sr aero, koga miyata, superia, shimano super aero, shogun, standish..
I hope you will have infos for me. Thanks in advance.
(sorry the site doesnt allow me to add pictures as for im a newbie here)
#296
Liked 3,044 Times
Welcome to the forums.That serial number indicates 1981 manufacture and was used by one of Shogun's contractors. Shogun did market an aero frame during this period.and a model could sometimes have small variations from year to year or from one contractor to another, so it might be a Shogun. However, until we have pictures, all it remains is a possibility.
#297
But i wonder if you can confirm me that shogun bikes could have a serial number on the seat tube as i mentionned. All the pictures of serial numbers i have seen are on the bottom bracket..
#298
Tange Levin Aero headset, Tange dropouts
#299
Liked 3,044 Times
I went back and checked the database. Unfortunately, not everybody with your code format provided pictures but for those that did, the serial number was on the under side of the bottom bracket shell.
Your frame is semi-aero style, in that the seat and tubes are not aero profile along their entire length. They are aero profile in the middle and round at the ends. This is a cost concession to permit the use of conventional lugs, standard front derailleur clamps and round seat posts. I've only see a handful of Shogun aero bicycles and none are an exact match for yours, though the the stay cap treatment is similar.
You also mentioned the possibility of an SR. I have one serial number for an SR aero frame in my database and it is definitely from a different manufacturer.
The bottom line is that I can't tell you which brand your bicycle was marketed under. The S/N format is consistent with that of a Shogun contractor but I haven't seen an exact match. About all can say is that it was manufactured in Japan in 1981 and late enough in the year that it could be a 1982 model.
#300
Although i would have loved to know what brand my bike is, i learned a lot about generation AX and asian data. I still want to restore the bike and it will probably be doing something similar to the bike in the picture of the shimano guy in the wind tunnel in the 81-83 catalogue. I really like the blueish grey of the bike in the catalogue and about the same as the Shogun Aero. Shimano aerodynamics decals will be easy to find. I wouldnt want to badge it as Shogun if was not 100% sure. But damm, to me it seems so close to it !!
Other positive point about this, i discovered this forum and really enjoying my time here! Nice to meet you all!
